We work with a project manager who actually works for Oceaneering Space Systems, so at least he's in the NASA offices and we can talk with him now. The other regular NASA engineers are all basically locked out now, barred from entering the building, as we were told. Guess that will end on Monday, least ending for a while.
The strength of the GT4 is that it is specifically designed for passive cooling with still high sustainable output. Adding a fan would make the design less simple (= bad for a tool), comes with a big waterproofing challenge, and adds a moving part that is likely to fail over time. And it is noisy.
300 watts!
That thing can dissipate 300 watts?
I don’t think so without the inevitable thermal throttling after about 2 mins<.
besides who would go swimming with a light like that. one would need a flotation device.
That light has been done before by Acebeam and Imalent, except they added a fans.
Yeah take my money but I want to be able to use the thing for more than 2 minutes at 20kl, or tell the costumers that max sustained output is really 12kl or whatever how much thousands less it can run passive until LVC.
BTW, Lumintop I believe makes some the best lights, I think they could pull off a cooler running solution to the GT4
what makes the gt4 different then acebeams x45 that does 18k lumens and has also 4 x xhp70.2 emitters? and on highest it can run like 3 min or so before stepdown ? but the gt4 has more massive heatsinks so it should run longer and handle the heat better. I dont think adding a fan is a good idea, its clumsy and doesnt really help much its better having a giant heatsink body instead.
lets just wait for lumintops runtimes after CNY and see how it will perform.
The GT4 will be like the GT and GT70, setup for easy mods down the road. Although CFT-90 will not be a factory option for sure, just far too complicated and costly to be practical.
I am positive that there will be custom mods with this though.
$15 per 70.2 vs $100 per cft-90. Also maybe $25.00 for 70.2 driver vs unknown amount, but I would estimate at least $100.00 for cft driver. Also, don’t forget that the 70.2 will have more output but lower luminance than the cft90 at max current. So most likely at least 400.00 more than asking price for base gt4 for a cft90 light would be what I would expect. If custom sourced it will be more.
Not as simple as that. The highest bin currently available to buy is around $116. Then you somehow have to cram at least a 400W driver in that head. Luminus claims a maximum current of 27A for the CFT-90. and it has been tested at over 40A but with active cooling. I think it’s better to just have one CFT-90 emitter and take advantage of the increase cooling of the GT4 head so the LED can be driven to its full potential, instead of having four under-driven LEDs. Even with one, it won’t be a long-sustained max output. But I think it would be far better with this as a host than the original GT.
