Thank you for all that info! Does this mean the lowest it will go is 3.6 lumens? Thank you!
I’d like to sign up for 1 XPL-Hi version.
No, that’s just the lowest mode on the default stepped ramp mode. It will go much lower.
Thank you sir for the information!
To get more throw then, I may order the 10507 Carclo Lens - 3-UP Narrow Spot Optic from Mt Electronics at the same time I order the FW3A. This seems like a simple-enough mod. Thanks again!
Edited:
[quote=ToyKeeper] Any standard Carclo triple optic of the right size should work, such as the ones sold at MtnElectronics. This includes 10507, 10511, 10508, 10509, and 10510. The 10507 optic makes the most throw, but also makes virtually every emitter look ugly. So the default is 10511 because it provides the most throw available without causing strong beam artifacts. It can also be polished to increase throw, while still producing a nicer-looking beam than 10507. [/quote]
It appears that the 10511 optic may be a good choice also.
I just can’t believe the amount of work that goes into these projects. I’m assuming that we’ll have opportunity to donate to those who have worked so diligently once the light is available?
Speaking of which, I believe I am currently in for 2 lights (#934 & 935). I would actually like to up this to 6 total, 3 of each emitter option.
Thanks again, everyone!
Please put me down for an additional light, one with each emitter please
I may have to get 2 instead of one. Add one more for me. (one of each emitter)
Please mark me down for two, one of each emitter. Thank you!
I guess to clarify for me, being down for 2 lights, I would get one in each emitter
THANK YOU for the concise and speedy reply! And for your very detailed info so far!
I would like to update mine to one of each emitter as well.
A big thanks to everyone involved with putting this together!
AFAIK, the initial post doesn’t differentiate between reserving different emitter options. You’ll be put on the list for as many lights as you want, and you can pick which emitter when you order.
I’ll be honest. I know this was kind of put on the back burner so to say and I have not received any updates and this may have something to do with the system logging me out after a period of time. That’s on me and I blame no one else. I did get sidetracked with an another GB that went wrong resulting in everybody having to pursue PayPal claims. My last post was almost a year ago. Having noticed activity, I’m trying to catch back up and it will take some time.
Thanks to everyone who is making this come to light.
Getting excited for this all over again!
Hi, after all this time watching, I can’t resist anymore
Please write me down for one.
And thanks to all the people involved
Please count me in for one XP-L HI
Thanks
I’d like some confirmation the bezel and driver will both be easy to remove in the production version. Lumintop has been known to add surprise glue and that would be a travesty for the FW3A.
Me too!
4 should be enough….
I am very pleased to know that it’s Lumintop working this project. They are very reliable. I like their products.
Please add me for one more, two in total!
Thank you
