[SALE] lighted TIR boards, D4, D4S, ROT66, MF01 multicolored with low battery waning and LVP
110 posts / 0 new
DavidEF
DavidEF's picture
Last seen: 1 day 21 hours ago
How challenging is it to get the board in the right placement and get the wires soldered back to the main LED board and to the add-on board, and put the optic back in, all without shorting or twisting anything?
- The YKK Philosophy
Lexel
Lexel's picture
Last seen: 1 hour 49 min ago
depends on the light
D4 is the driver often tight
D4S, ROT66 just swap
MF01 needs wires from driver
Cereal_killer
Cereal_killer's picture
Last seen: 4 weeks 1 day ago
Hi lelex, have you published the schematic for your lighted TIR boards?
I’ve designed a TIR light board for a one-off project of mine using all passive components and a comparator but I’d be interested to see how a “smarter” solution was designed and laid out.
Lexel
Lexel's picture
I am using pretty much same as you a comparator and LDO generating a reference voltage
I basically drew on some paper a scematic which is lost generally starting a new design on an already functioning board and keeping all nets as they were
on newest boards like E07 I have added a fet to get the comparator working down to 3V battery voltage so that MCU diode drop is not increasing the lowest voltage
even the parasitic drain of LDO and comparator is very low
clientequator
clientequator's picture
Last seen: 2 weeks 2 days ago
I am build my own gfs16 pcbs and you can see how loneoceans made his led board. I do not see the schematic there yet but it looks like it use two nanopower comparator and one voltage reference to have 5.5uA super low standby current. I think because no LDO is used, the standby current is much lower.
http://budgetlightforum.com/node/59550
The two bank of leds are switch on and off by small mosfet with battery indicator. I have order the pcb and parts to make my own led board also. With board file and part list, not too difficult to trace out layout to generate schematic.
Lexel
Lexel's picture
he uses a Maxim with integrated reference that has a parasitic drain 2-3 times more than my solution
I asked him if I can use his board as a starting point to do my own, but I ended up making some things differently including another comparator(mainly because its cheaper and lower standby drain)
clientequator
it look like that is the older version when I order part. The rev B use only one voltage reference and two comparator I see for 5.5uA standby current (from page)
Cereal_killer
How does that work? TIR board positive direct from LED+ and the ground from the FET drain? FET gate controlled by the MCU aux LED output?
clientequator
Hello Mr. Lexel,
I am trying to add some side light to my flashlight. You seem to have a lot of pretty color led. Can you please share us the part number for the led colors you are using?
green
blue
ice blue
pink
WW
red
CW
orange
yellow
emerald green
purple
Thank you Mr. Lexel!
EDIT – sorry for asking question, I found answer on aliexpress!
https://www.aliexpress.com/item/10Valuesx100pcs-1000pcs-0603-Ultra-Bright-SMD-Red-Green-Blue-White-Yellow-Warm-White-Orange-Pink-Purple/32358219506.html
Thank you
Lexel
Lexel's picture
I order from this Aliexpress shop
https://de.aliexpress.com/store/1758868?spm=a2g0×.10010108.0.0.456e161f...
but you can not except same efficiency or colors over different orders they seem to change
red and green latest batch were less efficient and Pink color changed less purple but more efficient
Ryzbor
Ryzbor's picture
Last seen: 50 min 41 sec ago
Will this board with only red aux on full power produce enough light tu use it as a usable moon mode?
virence.com rosy 3500K R9080 Wizard Pro, MF01 Mini 4000K R9080 (needs more 219B), super rosy 3000K E21A mix Skilhunt H04 on it's way
Lexel
Lexel's picture
Not with a reasonable standby current
sbslider
sbslider's picture
Last seen: 39 min 41 sec ago
I finally got my board installed in my D4. I like it!! Not easy to install, but not that much harder than flashing my D4 with Anduril.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
Cereal_killer
Does the D4 board fit any 20mm quad mcpcb or does it somehow only fit the D4?
Pöbel
Pöbel's picture
Last seen: 8 hours 30 min ago
Yes!
I used LED4Power Quad DTP Board
I should fit all 20mm quad boards which are quad TIR compatible, as this ensures the same hole spacing
contactcr
Last seen: 31 min 46 sec ago
I dont think it makes a difference that it’s a D4 but the tolerances for where the LED +/- are may not work for anything but a Noctigon 4XP. I guess YMMV. Maybe Lexel has tested others.
Edit: I see it works on L4P board. Looks less likely to work here:
Pöbel
Pöbel's picture
true. That I did not think of! Sorry for my misleading post.
Cereal_killer
Perfect, thanks guys!
xevious
xevious's picture
Last seen: 14 hours 26 min ago
This is… seriously intriguing & inspiring. Grad
I wasn’t going to go with an Emisar… have Fireflies E07 on my horizon. If there’s definitely not going to be one of these TIR boards available for the E07, then I may have to shift gears. Wink
Lexel
Lexel's picture
technically you dont need to screw down the aux board,
having it simply floating between optics and MCPCB, a few mm up are no problem to get the L4P board soldered,
you could also use some 3mm hole spacers to lift iut but got it screwed down
the E07 has already my board in the stock light, so there is no real need for me to order this board size
with LVP D4S, ROT66 and MF01 aux board from me available
D4 is simply stabilized with LDO, but can be build also without to support low mode
hodor
hodor's picture
Last seen: 3 hours 38 min ago
Really nice boards Thumbs Up But tbh a lot of this goes over my head!
I disassembled my D4 recently to flash Anduril and found it very tricky to work with given the extremely limited space. I’m not sure I’ll have the skills or patience to take it apart again to add the aux cables. I really like the aux leds in my D4S though so I could be tempted.
The D1 TIR looks interesting as well. Do you have any more info on that?
Any plans to make one for the imminent release of the FW3A? Smile
Lexel
Lexel's picture
D1 is not TIR its reflector with aux boards placed inside the gasket
I sanded that board to about 0.1mm thickness
the board with indirect gasket leds is not tested yet
contactcr
Send me one and i’ll destroy my D1 for science:
LED Light Pipe + Dremel + UV Glue = ???
Lexel
Lexel's picture
its meant to indirect light the white gasket
direct light version looks like this
contactcr
I know, but why let it go to waste? The D1 doesn’t get that hot anyways I can make some holes, lol
edit; I mean in some cases they help cooling too..
Tom E
Tom E's picture
Last seen: 7 hours 57 min ago
Lexel - I's like to order a couple, maybe more, of these boards. I need one for my ROT66 (early version no AUX LED's), a D4, another quad, possibly an MF01, and possibly when you get the D1 ready. How does this work? pm you?
JasonWW
JasonWW's picture
Last seen: 16 min 38 sec ago
He will pm you for order details. Payment is through paypal.
Click this to go to signature links.
Pete33
Last seen: 9 months 6 days ago
Would this install in a D4 far surpass a newbies capacity? Super interested, but it might be a bit much to bite off.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 25 min 47 sec ago
It is not easy to install. The driver is hardly pressed in and there is verry less space for wires and soldering.
You will need a tiny wire for battery- on the aux-board. Battery+ is the same as LED+.
Lexel
Lexel's picture
Wieselflinkpro wrote:
It is not easy to install. The driver is hardly pressed in and there is verry less space for wires and soldering. You will need a tiny wire for battery- on the aux-board. Battery+ is the same as LED+.
Usually most people do a reflash to D4S Firmware and use LED pin on driver for +
