Nope. A 30Q fits fine, but it will not be getting any host changes before production. Use unprotected cells only. Personally, I recommend the 35E cell, because it gives more runtime at every level except turbo, and the FW3A is not designed to operate at turbo for very long. It’s not a hot rod.
I didn’t mean to suggest the light support protected cells… I was just concerned about varying length of unprotected cells, similar to what is going on with the e07 and the 21700 cells.
If I understand correctly, the E07 issues aren’t really about the host design as much as the solder blob on the springs. Some have thicker blobs than others, which can cause battery fit issues at random. But the FW3A does not have bypassed springs, so it should be more consistent.
I wonder about this, too – I realize it was always planned to be a lighter anodizing, but I personally prefer the darker gray, it just looks sexy ;D
Also I’d like to know how the knurling compares to the BLF A6, since the A6’s is somewhat smooth, not as sharp as some other lights I’ve held. Not like the knurling would make or break the deal for me, I’m just curious!
Thanks again to Toykeeper and everyone involved! You’re awesome.
Huh, how about that! I’d have bet money the ano color actually changed lol. I guess most of us know those brown boxes with the white foam, so comparing to those I’m expecting a somewhat lighter gray. Thanks for clarifying!
Yes, all versions of the light will use this frosted lens. It can be polished clear for less spill light and more throw if that’s what you want. Or simply replace the lens.
