I assume people know that the optic is a lens and I’m taking about polishing the plastic part made by Carlco and not the glass part.
Plastic = can sand/polish
Glass = leave alone, do not scratch or damage
I assume this. Hopefully people will figure it out.
One of the advantages of using this particular frosted optic is you can leave it stock (and have a really nice looking beam with even color distribution) or simply polish it for additional throw without having to buy any new optics/lenses.
That’s why I said visually. In my experience high CRI 219C looks greener than their measurements would imply. Even when a CRI80 and CRI90 5000K 219C measure similarly, the CRI90 one always looks greener on a white wall while the original R8000 219C looks more often just pure white.
Also, to me, the higher the CCT, the less green the light seems. Maybe I’m just very allergic to that yellow/green tint that plagues many warmish emitters.
Oh I knew what you meant, and was not really trying to correct you.
But you know what usually happens when anything is assumed. … Somebody does just the opposite. :person_facepalming: .
So…. that has been addressed now. :+1:
Edit: Right or wrong…. I think most people call the flat glass part of a flashlight the lens.
Most people, it seems to me anyway, call Carlco Optics…… optics.
I honestly hope you do that or a ’PayPal only email address’ so those that wished could send a token of our appreciation.
A few other could/should do this also, if they wish that is.
Good, from past experience ; that is exactly how it should be done…… on an individual basis. Donators choose & know exactly who they are donating to. . :+1:
I saw maukka’s updates on page 220. The light looks really sharp. Were there beamshot photos of the recent sample posted?
Waiting to hear about how the orders will work because I will likely order more than one. All LH351D 90+ CRI.
I see it has been confirmed it only works with unprotected cells due to length. I only have MTN protected NCR18650GA cells now but I suppose I can buy a few unprotected for this light. Would be convenient if it were compatible with both but it’s ok.
Interesting, I see the 30Q has much less sag at 7A (0.1v less than 18650GA and 0.15v less than 35E), but has less capacity overall and is equivalent at lower currents. And the Sony VTC6 is slightly better than a 30Q.
What is the DD FET current expected to be for this light?
So, button or flat top?
From MTN:
30Q 3000mAh Unprotected button top = 66.6mm
30Q 3000mAh Unprotected flat top = 64.9mm
NCR18650GA 3500mAh Protected = 69.0mm
NCR18650GA 3500mAh Button Top Unprotected = 67mm
NCR18650GA 3500mAh Flat top Unprotected = 65.5mm
18650VTC6 3000mAh 18650 Flat Top = 65.1mm
18650VTC6 3000mAh 18650 Button Top = 66.9mm
Amperage should be under 15A, but I’m not sure how much under. It will vary based on battery and led. We should get some exact numbers once the prototypes get delivered and measured.
You want to use unprotected flat top batteries.
Unprotected button top may or may not fit as they vary in length.
I will likely choose the VTC6 flat top, with 30Q flat top being the second choice. I don’t know how the internal resistance of the two compare but I suspect it is slightly higher on the VTC6 which would be OK if a 30Q works.
As TK said above, the 35E will work really well for run time. The LG MJ1 would be great too. They have more capacity, and are not quite as high drain, which would be ideal for this light, since maximum brightness is not the goal. I will just be using the unprotected flat tops that I already have.
:+1: …… So do we need to inform the guy, in the quoted post below; that broke the glass on his Sofirn SP33 that he is actually seeking a replacement window…. not a replacement lens?? Sorry... I just couldn't resist. . .
