I’ll wait for the Ti version
Easy enough to measure if anyone cares to do that (I have no E07)
Ordered two, but decided to order one from BG, the other from FF, so it won’t really matter who sends faster.
Used your links and codes, thanks!
Thanks pal! Appreciated.
Ordered two, but decided to order one from BG, the other from FF, so it won’t really matter who sends faster. Used your links and codes, thanks!
Code for bg ? Thanks
Got my 3rd E07 from Neal and he shipped much faster than Fireflies direct.
the MCPCB have little thermal paste but not enough spread evenly. Had to add more for extra heat transferring
Is it too late for some sort of Code? I’ll take one if there is still valid option out there!
Thanks
Code for the FF store has expired. Can I ask for a banggood code?
And one more question. Is the flashlight glued? I mean head bezel, driver, etc.
Sent. [quote=TSO] Is it too late for some sort of Code? I'll take one if there is still valid option out there! Thanks [/quote]
Hello, can I get code for BG? Thanks
Where can the XPL HI V3 3A NW 5000K version be had? It’s listed in some of the descriptions but there’s no option to select it.
interested in BG group buy code — thanks FreeMe!
I’m in Clear anodizing confirmation
BG group buy code still available? Thanks @ freeme.
Got my grey e07 from neal. It flickers on moonlight. No matter which battery i use. Anyone else experience this?
Apparently it’s a known issue (I believe I read about it in the FW3A thread that all 3 FF lights do that).
My clear E07 didn’t do it with the stock SST’s but all you should have to do is set the ramp floor a little higher (try one step at a time).
just curious, are u calling moonlight the bottom of the ramp?
Is there an ETA for shipment for the next version that addresses the thermal paste and TIR positioning issues? Thanks.
With Anduril, the bottom of the ramp is moon. It doesn’t have a separate moon level like NarsilM does.
About the flickering, it seems to vary per 7135 chip. Some do it, some don’t. I think I may have found a workaround though, and it’s included in recent builds.
