Interested in one with LH351D !
I think it will be difficult to measure current. You can’t take an easy tailcap reading.
One possiblity is with no optics you can extend one lead for the LED and feed that through your clamp meter.
But it seems the optic clamps the LED-BOARD on the shelf?
You need an assistant who press with tweezers the board manually down?
:+1: … He certainly will. …
I don’t think it will be too hard. Use one hand to hold your main jumper wire to the threads and the other end to the battery.
Then use your other hand and a wire or piece of metal to jumper power to the inner tube. It might be tricky to get two fast touches so as to activate Turbo, but it looks doable.
I also think it’s strange that my “production” sample has a cool white (>5700K) emitter.
You lucky thing ,that’s my favourite tint :heart_eyes:
I’m in for one please!
I am confused - is the inner tube fully anodizer even on its ends? How does it make contact?
Put me down for one, please.
what is the inner tube needed for? im confused.
Muggle mode has an output range of 5-240 lumens.
It’s the conductor for the tailcap e-switch.
It’s not anodized, just looks black in the photo.
It’s so good to see this alive
It is looking fabulous
For those who may be interested in a GAW of this light, check my signature and, if it is the case (see rules in post#1), get IN for the GAW
I’m already in for one but count me in for one more.
I don’t suppose this is possible, but since the FW3A is being shipped with a frosted lens leaning towards flood, and it is meant as an EDC light, for which a mixed beam would arguably be more suitable, what are the chances of having an extra lens type or two for variety as an optional extra to be selected when ordering if so inclined?
I certainly wouldn’t want to start sanding my ONLY lens, I would rather swop and experiment with spares, but separate orders mean more shipping and receiving fees, not cost effective on such small purchases.
It’s a narrow beam, lightly frosted lens which makes the beam look much nicer plus gives a little extra spill light. It should not lean towards being floody. Here is the 10511.
I doubt Lumintop would offer extra lenses, but maybe Neal would.
The problem is what other lens would they carry? MTN E carries 5 different ones and there’s probably more than that.
Maybe a clear version of the narrow beam, the 10507? I guess it would be the next most likely one people would want. Just keep in mind that it can produce some ugly artifacts which is why it’s not used in the first place.
With a 10507 optic the beam is basically just a circle, almost like a narrower version of how a zoomie looks in wide mode. At the edge of the circle it has an off-colored corona, and then outside of that is a barely perceptible spill area in the shape of a triangle. So for practical purposes it’s a hotspot-only beam with no significant spill, and the hotspot has a thin warm corona around the edge. It looks a lot like a blurry projection of the sun.
With a 10511 optic the beam is totally smooth and has no sudden changes in tint, temperature, or brightness. So I’m keeping the 10511 in mine.
I still think 10511 is Where It’s At.
For XP-G2, the official specs are:
- 10507: 4.8 cd/lm
- 10511: 5.5 cd/lm
For XP-G3, the ratings are lower:
- 10507: 3.1 cd/lm
- 10511: 2.7 cd/lm
Nichia 219c has similar ratings:
- 10507: 3.3 cd/lm
- 10511: 2.9 cd/lm
Not sure why the relative throwiness reverses sometimes, but the 10511’s throw increases if you polish the frosted part by rubbing it on fabric or something… and afterward it still has less corona artifacts than the 10507. It’s too bad they don’t seem to come in a non-frosted 10511 variety.
Here are a few configuration estimates, taking into account the optic specs and an estimated lumen count:
- 219c w/ 10507: ~3000 lm, ~9.9 kcd lux
- 219c w/ 10511: ~2950 lm, ~8.5 kcd lux
- XP-G2 w/ 10507: ~2500 lm, ~11.9 kcd lux
- XP-G2 w/ 10511: ~2400 lm, ~13.2 kcd lux
- XP-G3 w/ 10507: ~3600 lm, ~11.1 kcd lux
- XP-G3 w/ 10511: ~3500 lm, ~9.5 kcd lux
- XP-L HI w/ 10507: ~3350 lm, (no cd/lm data available, guessing ~18.7 kcd lux)
- XP-L HI w/ 10511: ~3300 lm, (no cd/lm data available, guessing ~20.8 kcd lux)
These are all totally theoretical though, using numbers from Carclo’s specs and measurements of similar lights. They’re probably pretty far off from reality. Mostly I just wanted to show that there are a variety of sweet spots for different use cases. The FW3A’s specified config is one of those sweet spots, but other options might be interesting later too.
Mostly, I just think the 10511’s beam looks a lot smoother, and the difference in throw is usually small. Here’s how they compare in two of my lights… 10507 on the left, 10511 on the right:
http://youtube.com/watch?v=UnWO8iN4Fzg
(in case the quality of the embed is low, here’s the direct link: https://www.youtube.com/watch?v=UnWO8iN4Fzg )
Toykeeper, could you maybe put your beam shot comparisons of the different lenses, or a link to them, somewhere in the beginning of the thread? That way people can find them easily.
Sorry, I can’t find the post. I’m pretty sure it was you. Maybe it was someone else. I remember they were like backyard night shots showing the hotspot size and amount of spill light.
What is the DD FET current expected to be for this light?
I’d guess 10-15A.
Although the 35E and 18650GA are rated for 8A and 10A respectively for continuous drain, they seem to handle 15A reasonably well for short periods of time.
The 30Q and VTC6 might be better choices if you plan to run on turbo a lot, but the heat generated by the FW3A in turbo will be more of a limit than the battery.
Please put me down for 4 more (total of 6)
I think that was different emitters, not lenses.
The video you quoted is fine for showing the smoothness and edges of the beam but it doesn’t portray what happens at several meters. The 10511 gets pretty wide and doesn’t show a strong hot spot like it does in this short distance.
The glass covering in a flashlight that protects scratching of the optic or reflector and allows for protection from water and dust ingress is a lens, simple as that. Anyone arguing this is a troll.
Edit: Of course nothing is simple and depending on how technical one wishes to go there are variables, but in ordering a replacement for your flashlight it will be called a lens.
