Maukka! Very nice beam shots and comparison! It’s really cool to open both pictures and click back and forth in full screen to compare….so cool to watch the minute differences in shadows etc. Looks as though the D4 beam is ever so slightly wider, which makes sense…but not much wider. Unless the angle of the lights was just a touch different when pics were taken (can see shadow of small twig on lower right in foreground move up and back just a bit…like the D4 was just an inch or 2 more forward than the FW….but again…probably just the wider beam of the D4).
I’m babbling…sorry…again…THANK YOU! Very nice shots and comparison.
I was joking lol, based on the discussion on what to call the Carclo and the glass pane in front of it… it was always planned to have a triple Carclo TIR optic and a glass window/lens in front for protection. So no, none of this discussion would drive the price up
I’m getting really hyped for this now! I have a couple of questions about the FW3A that I’m curious to know answers to. If anybody can chip in with their wisdom, it would be much appreciated!
1) If we were to compare the FW3A to a similarly sized flashlight known for efficiency, such as the Zebralight SC64, would the FW3A be roughly as efficient? One of the main reasons I’m hyped is because of the higher regulation on the FW3A vs an Emisar D4, but I’m not very well versed in how it all works so I’m trying to gauge efficiency by using examples of well known flashlight models in the community.
2) In ToyKeeper’s Emisar D4 review, she listed all of the ramping steps. These seem to be the same on the Emisar D4S and I was able to use them to configure my D4S’ stepped levels very specifically. Will these steps also be the same on the FW3A, as it is running Anduril? I’d like to be able to set my ramp ceiling right at the highest regulated mode for efficiency, and it is nice to know where that is exactly.
Many thanks to everyone on the FW3A team. What a fantastic device you have conceived!
Thanks folks, I remember reading the original specs quite some time ago, but can’t remember the specifics now. Unfortunately, I didn’t realise at the time there was a link to the specific carclo optic used, and I’m nowhere near technically proficient enough to know this stuff offhand. Thanks for the help.
As someone else mentioned, I’d be keen to buy a spare clear optic if this became an option. It does sound though from what Toykeeper, Jason and everyone is saying the original optic is the way to go.
1. The Zebralight would still be more efficient than buck/boost driver. LED efficiency would be better than a single 3V emitter light, but driver efficiency will not be as good.
2. It should be higher since it’s using a 1+7+FET driver, instead of 3+FET.
Wow chadvone, looks like your in the middle of a ‘Deep Freeze’… Your whole state is below 0° for the whole day today…. :person_facepalming: … I imagine you are well aware of that tidbit of info though. .
It is much warmer in most of Alaska than Iowa, as well as most of the Midwest USA today.
Turn those lights to TURBO & keep those hands warm….
Good luck & hope the pipes don’t freeze & burst.
Edit:…… “below 0° ” = Below Zero Degrees Fahrenheit ( 0° F ). As in —18, —11, —9, —17, and so on for their High temps today. Lows tonight will be in the negative (-) 20’s & 30’s F. .
It hurts me even thinking about that…. :person_facepalming:
