13576 posts / 0 new
contactcr
Last seen: 3 hours 59 min ago
JasonWW wrote:
Toykeeper, could you maybe put your beam shot comparisons of the different lenses, or a link to them, somewhere in the beginning of the thread? That way people can find them easily.
Sorry, I can’t find the post. I’m pretty sure it was you. Maybe it was someone else. I remember they were like backyard night shots showing the hotspot size and amount of spill light.
I think that was different emitters, not lenses.
The video you quoted is fine for showing the smoothness and edges of the beam but it doesn’t portray what happens at several meters. The 10511 gets pretty wide and doesn’t show a strong hot spot like it does in this short distance.
DB Custom
DB Custom's picture
Last seen: 9 hours 2 min ago
The glass covering in a flashlight that protects scratching of the optic or reflector and allows for protection from water and dust ingress is a lens, simple as that. Anyone arguing this is a troll. Silly
Edit: Of course nothing is simple and depending on how technical one wishes to go there are variables, but in ordering a replacement for your flashlight it will be called a lens. Wink
JasonWW
JasonWW's picture
Last seen: 18 min 47 sec ago
It was a while back, so I can’t be sure. I seem to recall the different amounts of spill light, though.
Maybe someone has some beam shots of just the different lenses to give us an idea of the differences.
I’ll probably keep the frosted lens. My previous lights had clear optics and I never liked the lack of spill light from them. I prefer a reflector type beam pattern and the frosted 10511 seems very similar to that.
Click this to go to signature links.
cdjaney
cdjaney's picture
Last seen: 4 months 6 days ago
He said “ingress”. No correcting that! Well played DB…well played. Big Smile
John 1:5 "The Light shines in the darkness, and the darkness did not comprehend it."
JasonWW
JasonWW's picture
I don’t think anyone was calling the glass part an optic.
We are just saying there are two lenses. Both the glass part and the molded plastic part can be called a lens.
DB Custom
DB Custom's picture
Well, they can be called toast if things go awry, but the people that make them call them optics… this is because they are computer designed to align the transmittance of the lights rays, guiding the egress of photons to a predetermined focus… hence, optics through reflective manipulation.
Streamtronics
Streamtronics's picture
Last seen: 3 weeks 22 hours ago
g_damian wrote:
Why 7135s on the driver in maukka’s picture are in such unusual position? AFAIK it’s not good for heat dissipation.
What do you mean? The way I understood it, the driver has eight 7135 regulators in total – there is only limited space available on the PCB so six of those are located at the bottom (spring side) of the double-sided PCB. Where else would you put them?
They don’t actually dissipate all that much power – when all eight are 100% on, I’d assume the driver dissipating around 2.5 W total (worst case) when the battery is at 4.2 V.
chadvone
chadvone's picture
Last seen: 1 month 1 week ago
Lens, window, now optic. I hope this doesn’t drive the price up.
CRX
CRX's picture
Last seen: 30 min 23 sec ago
Shouldn’t do, as there will just be the plastic optic and glass window, no lens so we’re saving on that LOL
Streamtronics
TIR lens is $30
TIR optic is $35
choose wisely ;D
djozz
djozz's picture
Last seen: 1 hour 54 sec ago
What is probably meant is that the 7135 chips are orientated 90 degrees different from usual, what makes the thermal pads not facing the ground ring anymore and thus the heat has a worse path to the flashlight body.
Those 7135 chips are pretty tough though and I expect that they can handle this.
teacher
teacher's picture
Last seen: 6 months 3 weeks ago
It won’t… SmileNothing ever changed in reality. Big Smile
Lens, as in; my FW3A will have an AR coated lens.
Window, as in; my house & car both have windows.
Optic, as in; my FW3A will have a Carlco 10511 optic.
Hallamski
Hallamski's picture
Last seen: 3 months 3 hours ago
Anyone have a photo or video comparison of the 2 emitters being used? Would be nice to compare side by side.
NWoodsman
NWoodsman's picture
Last seen: 1 month 4 weeks ago
Is it too early to say, “oooohhh imagine how nice a FW3A in 26650 format with a quad would be….”
MascaratumB
MascaratumB's picture
Last seen: 4 hours 3 min ago
Yup, so early as to say “how nice it is in the 18350 format” Big Smile
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
dealgrabber2002
Last seen: 5 hours 34 min ago
When it’s ready, how do we purchase this? Aliexpress?
chadvone
chadvone's picture
TIR lens is $30
TIR optic is $35
choose wisely ;D
Hoping someone post some beam shots before I decide Thumbs Up
1LL1
Last seen: 1 month 4 days ago
I’m down for 1 XP-L
ActiveAl
ActiveAl's picture
Last seen: 5 days 7 hours ago
ToyKeeper wrote:
I  I might set up a Patreon account or something. If I do though, I want to make it clear that it’s just me, not a team thing. I don’t know if I could send money to Fritz if I tried, nor do I know if he would want me to. Past attempts to do a team-funding thing haven’t really gone well either, so any donation thingies will probably be done on an individual basis with no illusion that it’s for everyone.
ToyKeeper, I would like to donate a small gift to show my appreciation. Where do I send it? Thanks.
xevious
xevious's picture
Last seen: 39 min 47 sec ago
Interested – please add me to the list
mortuus
mortuus's picture
Last seen: 5 hours 15 min ago
No i think through Neal again, gt mini worked so atleast. ali is never used for group buys here.
...where Frugal meets with Flashlight!
maukka
maukka's picture
Last seen: 4 hours 1 min ago
Firelight2
Firelight2's picture
Last seen: 5 min 2 sec ago
Nice pictures Maukka.
It looks cold where you are. LOL
chadvone
chadvone's picture
Looks like Iowa. Thank you.
cabfrank
Last seen: 1 hour 36 min ago
Great shots. They make me miss the snow, for a minute.
aggillator
aggillator's picture
Last seen: 4 weeks 1 day ago
I am interested in the xpl-hi version. Is someone able to add me? Thanks.
cdjaney
cdjaney's picture
Maukka! Very nice beam shots and comparison! It’s really cool to open both pictures and click back and forth in full screen to compare….so cool to watch the minute differences in shadows etc. Looks as though the D4 beam is ever so slightly wider, which makes sense…but not much wider. Unless the angle of the lights was just a touch different when pics were taken (can see shadow of small twig on lower right in foreground move up and back just a bit…like the D4 was just an inch or 2 more forward than the FW….but again..probably just the wider beam of the D4).
I’m babbling…sorry…again…THANK YOU! Very nice shots and comparison.
Streamtronics
TIR lens is $30
TIR optic is $35
choose wisely ;D
I was joking lol, based on the discussion on what to call the Carclo and the glass pane in front of it… it was always planned to have a triple Carclo TIR optic and a glass window/lens in front for protection. So no, none of this discussion would drive the price up
raccoon city
raccoon city's picture
Last seen: 5 hours 56 min ago
Snow is proof that where you are is too darn cold!  ;)
cabfrank
That is a very good way to put it. Been there, done that.
