Yes and no. I really like having the data to evaluate. However, it’s also possible to get the audiophile disease where you get lost in evaluating, and forget the real goal is to use and enjoy the product (it’s only a small percentage of audiophiles, of course, but they’re the ones who get noticed).
I’m currently thinking what I should do personally is just order each of the different emitters that potentially interests me on MCPCB’s, try them out on my work bench, and decide from that what my dream light is.
I will put E21A and Optisolis modules for DIY-ers to experiment themselves but take note:
- Jetusolis and JetuE21A lens holders are NOT interchangeable. I modified the lens holder of JetuE21A so much that you can’t use Optisolis with it. There’s a potential one could easily crush the Optisolis put in the JetuE21A.
You can use E21A/E17A LED modules in Jetusolis but the beam will be about 50% narrower and you’ll lose ~20% output.
I went back to look at this picture again, because it’s really cool to see the phosphors glowing under UV light, and I noticed something I missed before:
The E17A’s are all glowing, except what I assume is a blue one.
So I looked up the datasheets to see the spectrum graphs, and sure enough, they aren’t narrow monochromatic peaks, but relatively wide peaks. These are phosphor-converted color LED’s (except the blue).
I’m guessing the appearance is not the intense, highly saturated look we’re accustomed to with color LED’s, but more like a filtered incandescent? I’ve never quite liked LED Christmas lights as much as filtered incandescents, so I think that could be a good thing.
You’re right. Although these colored LED aren’t as bright as normal colored LEDs, they have much wider spectrum coverage. I was surprised too how well I can see under the Red, Green, and Amber E17As. Unlike Blue which has very specific uses. Amber E17A renders color better than LPS and one could mistaken it from 1800K warm white if the object shone don’t contain too much colors. I also prefer PC Red for retaining night vision, because I can still somewhat see different colors better than with true single spectrum red color. Green although very relatively harsh to the eyes, brings out details extremely good and has the best color recognition among the other colored E17A. I can’t use the blue for too long, it hurts my eyes. Blue E17A, just like many failed dedomed LEDs in my collection, very useful for illuminating anything that normally glows under UV.
Received a jetusolis 6500°k and 5000°k today (ordered on janv 24 (3 weeks ago)). Thank you clemence !
I usually don’t like cool white then each time i turn on the 6.5k, i need time to get used to it.
Once adapted, i have zero problem to consider it as one reference for colors rendition for myself. I will use it amply for inspections in the next days.
I really appreciate, at least, being able to check colors with a beam without a neutral or warm tint.
I can stand cool white…i’m cured !!
Thank you for your work, tests and dedication to high cri.
Is there an E21A and optisolis, both 6.5k beamshot somewhere ?
What to expect of a triple E21A 6.5k in the FW3A ?
Is it too much to hope for a tir lens combined to your Wizard/Tiara E21A module that would fit the FW3A ?
EDIT : blue tones with the jetusolis 6500°k look real good
I only have Cree XPE2 Green from my Armytek Dobermann to compare with. You can see the difference between Cree XPE2 pure green LED and phosphor converted green E17A. The much wider spectrum coverage makes for better color rendering other than green itself. Depending on the applications, this could be a bad or good thing.
Note: you can clearly see which is Red, Blue, or Yellow under PC Green E17A. It’s impossible to check colors under Green XPE2 (except for the false orange bottle cap which actually pink under white light)
I can’t stand low CRI cool white, it’s too harsh with no real benefit. With very high CRI cool white, the harshness pays off. Truest whites, clean colorful objects. Here’s the beamshot, taken from the product page:
If someone can give me a detailed technical drawing of FW3A MCPCB, I can do that. What I learnt: E21A only benefit from nano-ceramic MCPCB in tightly packed setup. For conventional wide spaced triple or quad, we only gain 300mA extra peak current which already very inefficient. My early test with heavily cooled direct thermal path confirmed that too. Below OEM rated current (1400mA), E21A is very tolerant to any MCPCB types. Looks like it’s time to make another triple and quad E17A/E21A MCPCB!
I remember reading the FW3A will be using the Noctigon 20mm triple mcpcb and will be compatible with Carclo optic. Are you planning to make a traditional quad for the E21A/E17A to fit Carclo optics?
However, the FW3A is FET driven for its highest outputs. Isn’t that a concern with the E21A due to their low forward voltage?
Texas Ace tested an E21A quadtrix as peaking around 2.5A per emitter. I assume you want to stay below the peak, but the FW3A is likely capable of providing more than that.
The actual peak current of E21A is 3,3A for both R70 and R9080. But in R9080 the curve is almost flat from 2,5A to 3,2A. Making it’s not worth the heat/risk upping to more than 2,5A.
You’re right about the FET. E21A is better suited for more refined current controlled drivers.
Those above was a single E21A R9080 tested on a copper DTP. Indium solder will provide a teeeeny bit more current. Not worth the hassles …
With “normal” non DTP MCPCB, four E21A packed closer together can only output about 1A max per LED. With nano ceramic MCPCB such as VR16SP4 we gain back the 2,5A max for each LED.
Efficient buck/boost cc drivers that can be readily bought for e-switch lights seem non-existent unless you build it yourself or you’re willing to sacrifice an expensive light which has one. One option might be loneoceans’ boost driver driving triple in series if somebody can make those available with appropriate e-switch firmware.
But for the meantime, I personally wouldn’t mind an FW3A with triple E21A running on just the 1+7 7135 chips with FET disabled or removed. IMHO It would still be totally worth it despite the added heat and loss of output and efficiency. But that’s coming from an E21A fanboy whose willing to sacrifice everything else for these emitters. I blame Clemence for that .
You’re welcome and thanks for your support. I also keep 3000K and 6500K Maukka calibrated Jetusolis for my reference lights.
Next project in the making …
