13583 posts / 0 new
chadvone
chadvone's picture
Last seen: 10 hours 18 min ago
^ Thanks teacher.
DB Custom
DB Custom's picture
Last seen: 1 day 8 hours ago
I really love the Eagle Eye X6 flashlight, have far too many of them… all in different configurations. I priced an AR coated Sapphire “Window” in 35mm at $195 each. Having a “window” could indeed drive the price WAY up!
maukka
maukka's picture
Last seen: 7 hours 7 min ago
Posted my review in a separate thread: http://budgetlightforum.com/node/65619
TMaxxJJ
Last seen: 1 hour 40 min ago
Been watching this for a while now!
Please put me down for two, one of each.
cabfrank
Last seen: 1 day 4 hours ago
I suppose going off topic in this thread is completely acceptable, or maybe the norm, so just out of curiosity, Dale, what is your brightest EE X6, and which is your current favorite? I ask because I have a couple I love as well. Wink
Klayking
Klayking's picture
BlueSwordM wrote:
@Klayking
1. The Zebralight would still be more efficient than buck/boost driver. LED efficiency would be better than a single 3V emitter light, but driver efficiency will not be as good.
2. It should be higher since it’s using a 1+7+FET driver, instead of 3+FET.
Thanks for the explanation!
autoxer
Last seen: 1 year 2 weeks ago
After seeing the awesome updates I am totally regretting canceling my second light.
Please go ahead and add me in for another light, bringing my total back up to 2 lights.
And thank you again!!
iamlucky13
Last seen: 5 hours 41 min ago
Klayking wrote:
1) If we were to compare the FW3A to a similarly sized flashlight known for efficiency, such as the Zebralight SC64, would the FW3A be roughly as efficient? One of the main reasons I’m hyped is because of the higher regulation on the FW3A vs an Emisar D4, but I’m not very well versed in how it all works so I’m trying to gauge efficiency by using examples of well known flashlight models in the community.
2) In ToyKeeper’s Emisar D4 review, she listed all of the ramping steps. These seem to be the same on the Emisar D4S and I was able to use them to configure my D4S’ stepped levels very specifically. Will these steps also be the same on the FW3A, as it is running Anduril? I’d like to be able to set my ramp ceiling right at the highest regulated mode for efficiency, and it is nice to know where that is exactly.
1) The Zebralight will be more efficient due mainly to their buck drivers, versus the linear regulators in the FW3A. Here’s some examples of measurements Maukka has done:
SC64C (90 CRI XP-L2): 140 lm/W on lower output, 106 lm/W on high.
http://budgetlightforum.com/node/58833
Emisar D4 (80 CRI 219C): 84 lm/W at regulated channel, ~67 lm/W on medium FET
http://budgetlightforum.com/comment/1168204#comment-1168204
There is, of course, a ~2x difference in price, and you trade Anduril for a different UI (although one that is still well-liked by most users).
  • Edit – Since Maukka now has numbers in his review, the FW3A with XP-L HI showed 93 lm/W at max 1×7135 channel, and 85 lm/W at max regulated level.
2) The default ramp ceiling for both smooth and discrete modes for the FW3A build of Anduril is the maximum regulated level.
If you want both channel boundaries, for the FW3A specifically, you can set the minimum ramp at level 1, the maximum at level 130, and 7 steps. This will result in mode 4 being the maximum 1×7135 channel, and mode 7 being the maximum 7×7135 channel.
contactcr
Last seen: 2 hours 29 min ago
It’s not really a fair comparison. XP-L2 is very efficient, 219C not as much.
LH351D right up there with XP-L2 in efficiency and the additional 7135’s add more efficiency to the medium modes.
This frosted lens will also be a few % worse too. In any case the Zebralight will still probably be more efficient but the FW3A will be closer and have a better range of efficient modes as well.
Cobra502
Last seen: 8 months 3 weeks ago
And half the price with a far superior UI and rear tail clicky.
DB Custom
DB Custom's picture
My brightest X6 is 10,660 lumens, my favorite is the solid copper one-off with it’s Nichia NVSU333A UV emitter, but only by a slight margin. The Tritted Titanium X6 is pretty close…
shirnask
shirnask's picture
Last seen: 58 sec ago
Please add 2 more for me making a total of 6 Facepalm
(I’m giving away all but 2)
Yeah, I’m sticking to that story
LOTL
Last seen: 1 hour 1 min ago
My first group buy and post on BLF.
In for 1!
saypat
saypat's picture
Last seen: 9 hours 27 min ago
… one could get a lot less for more money, WHY is this so affordable? Shhhhh, quiet!
raccoon city
raccoon city's picture
Last seen: 15 min 29 sec ago
saypat wrote:
... one could get a lot less for more money, WHY is this so affordable? Shhhhh, quiet!
quiet_you
cabfrank
10,660 is obscene!
DB Custom
DB Custom's picture
So, if I were to buy an FW3A, how many lumens would be too many lumens? Wink
Yourrid
Yourrid's picture
Last seen: 2 hours 55 min ago
DB Custom
DB Custom's picture
LOL, maybe the other direction… high CRI lower output emitters, high capacity cell for run time. Quality over quantity.
What? It could happen!
DavidEF
DavidEF's picture
Last seen: 13 hours 35 min ago
There you go… put a handful of Yuji emitters in there! How about the BC-3030?
- The YKK Philosophy
Yourrid
Yourrid's picture
For me, it’s about output first and foremost. If we could pack 30,000+ lumens into a package the size of an Emisar D4 with a 18350 tube that (somehow) doesn’t get hot SUPER quick, that’s what I’d like to see.
Question for you Dale: of all the emitters you’ve used over the years, is there much of a difference in heat created by different emitters running at the same wattage? Does a XML2, XPL2, XHP35 etc heat up the same at say… 10 watts? I wonder if there will ever be technology that would give us LED’s that don’t get hot as quickly and could give us 30,000 lumens in a pocketable flashlight.
Tom E
Tom E's picture
Last seen: 14 sec ago
LOTL wrote:
My first group buy and post on BLF. In for 1!
Welcome to BLF! You got in on a good one, and at a good point.
JasonWW
JasonWW's picture
Last seen: 7 hours 4 min ago
This sounds less like a flashlight and more like a camera flash. Lol
DB Custom
DB Custom's picture
WELL, 10 watts from an MT-G2 doesn’t make much heat. Especially from a 9V variant MT-G2. Barely running. 10 watts from an XHP-35 is pretty miserly as well, still making lumens, just running well within it’s limits. See a pattern here?
30,000 lumens, pocketable, and we win the lottery twice a year, right? All fly Lear Jets and drive Corvettes? See a pattern here? Even if the emitter technology headed us that direction, what Alien is going to bring the battery technology up to par? Can’t say it won’t happen, but it’s doubtful I’ll live to see it… never know though. My Dad is 90, remembers lighting their house with kerosene lamps…
Yourrid
Yourrid's picture
Hahaha I guess one can dream right! I kind of figured watts = energy = heat in one way or another. I was just curious as to wheather the newer LED’s were getting exponentially more efficient in energy to output or not really.
I suppose the next step would be to put a laser behind a diffuser lens and see what you get. Maybe a triple; red, blue, green lasers with a heavily frosted optic.
Or just carry around a MT09R Thumbs Up
DB Custom
DB Custom's picture
The thing is that we tend to push these emitters up against the ceiling, and of course they’re inefficient up there. We need to lower our demands to conserve that heat and bring them into the realm of efficiency, maybe use 70.2’s in 12V at lower current and use more of them, something like that. Like the SST-40 really shines over an XM-L2, but not so much at lower levels as the Cree is more efficient down there. So we need some lights like this one that are elegant, stylish, more of the gentleman’s EDC than a Search and Rescue master blaster. There needs to be diversity, not an all or nothing approach.
Y’all didn’t think I could see that, did ya? Silly Of course I like making a light do all it can do, but when I use them I typically spend most of my time in level 4 or 5 of 7. Wink
This is one of the things I love about Anduril, it’s two lights in one… the ramp ceiling keeps the light sane, a good all around working light. Double click to find the alter ego… Big Smile
DBSS
Last seen: 2 days 16 hours ago
I’d like to grab one please
WeeG
Put me down for one, please.
ToyKeeper
ToyKeeper's picture
Last seen: 3 min 40 sec ago
ActiveAl wrote:
ToyKeeper, I would like to donate a small gift to show my appreciation. Where do I send it? Thanks.
I haven’t set up anything yet. I’ve been a bit busy testing the light today…
… which brings up a thing people should be aware of for these samples. They seem to have shipped with 10508 or 10509 optics, which are both significantly more floody than the 10511 optic it is intended to have. I heard back from Neal today about this, and Lumintop hasn’t received its order of 10511 optics yet so they used some others they had in stock.
1. No. Zebralights use buck/boost drivers, which are more efficient than linear drivers. The FW3A uses a linear driver.
2. The ramp is not the same as the D4. The full details are in the cfg-fw3a.h file, but here’s a summary:
  • 1 to 65: 1×7135
  • 66 to 130: 8×7135
  • 131 to 149: 8×7135 + FET
  • 150: FET only
saypat
saypat's picture
I like floody. How much more floody is the 10508 than the10511? And can I purchase this 10508 optic somewhere and just drop it in myself without issue? The beam shown on Maukka’s review looked terrific to me!
