WELL, 10 watts from an MT-G2 doesn’t make much heat. Especially from a 9V variant MT-G2. Barely running. 10 watts from an XHP-35 is pretty miserly as well, still making lumens, just running well within it’s limits. See a pattern here?
30,000 lumens, pocketable, and we win the lottery twice a year, right? All fly Lear Jets and drive Corvettes? See a pattern here? Even if the emitter technology headed us that direction, what Alien is going to bring the battery technology up to par? Can’t say it won’t happen, but it’s doubtful I’ll live to see it… never know though. My Dad is 90, remembers lighting their house with kerosene lamps…
Hahaha I guess one can dream right! I kind of figured watts = energy = heat in one way or another. I was just curious as to wheather the newer LED’s were getting exponentially more efficient in energy to output or not really.
I suppose the next step would be to put a laser behind a diffuser lens and see what you get. Maybe a triple; red, blue, green lasers with a heavily frosted optic.
The thing is that we tend to push these emitters up against the ceiling, and of course they’re inefficient up there. We need to lower our demands to conserve that heat and bring them into the realm of efficiency, maybe use 70.2’s in 12V at lower current and use more of them, something like that. Like the SST-40 really shines over an XM-L2, but not so much at lower levels as the Cree is more efficient down there. So we need some lights like this one that are elegant, stylish, more of the gentleman’s EDC than a Search and Rescue master blaster. There needs to be diversity, not an all or nothing approach.
Y’all didn’t think I could see that, did ya? Of course I like making a light do all it can do, but when I use them I typically spend most of my time in level 4 or 5 of 7.
This is one of the things I love about Anduril, it’s two lights in one… the ramp ceiling keeps the light sane, a good all around working light. Double click to find the alter ego…
I haven’t set up anything yet. I’ve been a bit busy testing the light today…
… which brings up a thing people should be aware of for these samples. They seem to have shipped with 10508 or 10509 optics, which are both significantly more floody than the 10511 optic it is intended to have. I heard back from Neal today about this, and Lumintop hasn’t received its order of 10511 optics yet so they used some others they had in stock.
1. No. Zebralights use buck/boost drivers, which are more efficient than linear drivers. The FW3A uses a linear driver.
2. The ramp is not the same as the D4. The full details are in the cfg-fw3a.h file, but here’s a summary:
I like floody. How much more floody is the 10508 than the10511? And can I purchase this 10508 optic somewhere and just drop it in myself without issue? The beam shown on Maukka’s review looked terrific to me!
I’m hoping at least one of the prototype testers can swap a 10511 from one of their other lights and put it on the FW3A so we can see what the pattern really looks like.
With the wrong optic and emitter, we can’t really evaluate that whole aspect of the light. Bummer.
I’m still testing and measuring and taking pictures, so I’ll have more details later… however, here are some initial notes on the FW3A sample I received today:
The good:
Almost everything about this light is made well, and is what I was hoping for.
The grey finish looks nice.
The host in general is high quality with precise machining.
The button feels a lot more solid than earlier versions. I haven’t had any issues at all with missed button presses.
The clip is perfect, with none of the minor machining issues seen on earlier units.
The light is ergonomic and comfortable to hold.
I don’t see any weirdness in the anodizing, like the prototypes had.
Output is steady and stable even at moon level.
All the firmware features appear to work correctly.
Except a couple things noted below, everything appears to be correct, up to spec, and otherwise in order. That’s not a thing I can say often, even about production lights.
The bad:
On mine, there was an issue with the driver fitting into place in the pill. It looks like the pill’s driver shelf wasn’t cut wide enough, so it rested off-center on top of the correct space instead of in the correct space. I fixed mine manually, by filing down the edges of the driver and dremelling the pill a little farther open. This was weird, because no prototypes had this issue, and it looks like maukka’s light doesn’t have this issue either.
Mine shipped with firmware from 2018-12-02 instead of 2019-01-05. I’m hoping the real thing will have a newer version, but there isn’t much changed so either one is okay.
Misc notes:
The optic is a 10508 or 10509, not 10511. So it’s even floodier than the real thing is expected to be. Beam shots on these won’t look the same as the production units.
Lumintop hasn’t received their order of XP-L HI 3D emitters yet, so they used extras they had in stock. On maukka’s, this meant ~5700K, maybe a 2B tint. On mine, it was ~4000K, like a 5A or 5D tint.
I’m not really a fan of warm tints, but this 5A/5D isn’t bad. I like it a lot more than the SST-20 4000K 95CRI light I had for a while, so I think I’ll leave it this way. The only nicer ~4000K tint I’ve seen was a Nichia 219B.
So I’ll be checking on each other sample in detail to make sure there were no other issues. The only important issue was the driver not fitting quite right on mine, but it seems likely this was not typical. Everything else is minor and/or should be resolved simply by waiting for parts to arrive.
Searching around on Google I found the below angles (not official):
The 10511 is called a narrow spot. 22°
The 10508 is called a medium spot. 27°
The 10509 is called a wide spot. 40°
All of the above are frosted.
The 10507 is the non-frosted, clear version with a narrow spot. 18°
I think it’s fair to say that the angles might vary a little based on which emitter is under them. So I would view the above angles as a loose reference guide.
- you forgot to add that it needs a runtime of 8 hours at turbo, too
- and have the ability to make hot chocolate from snowdrifts
- and must be able to use the full 30K lumens in a strobe rhythm that will bring down UFO’s and send grizzlies back to the mountains bawling their eyes out
- if it could also find its way home when lost, that would cool, too
