Differences in off-the-shelf parts, as long as the expected parts will be implemented in actual production, don’t concern me too much.
If this is a production test of the custom parts: machining and final driver, tail PCB, MCPCB, etc, that still seems significant enough to reasonably call a production test.
The firmware difference is a bit of a puzzle though. I hope they didn’t have 1800+ drivers built and flashed with an older version of the firmware.
There isn’t much difference between the version it came with and the latest version. The only user-visible differences are:
Double-click from off no longer turns off before going to the ceiling level.
I added a potential workaround for moon flicker issues, but those have only been reported on Fireflies lights, not on any other brands, so it probably doesn’t matter for the FW3A.
Here’s the effect of different Carclo optics to throw. My sample had the 10508 installed by default, but the production light should have the 10511. This was measured at the 1x7135 level and scaled to maximum output for repeatability.
Also, added stepped ramp default (78 lm) runtime https://i.imgur.com/uTsDSDI.png and measured maximum output with 50% drained 30Q (1980 lm @ 0 sec, 850 lm at 30 sec)
Double click from ON always goes to turbo, not ceiling. Double click from OFF goes to ceiling max first. Previously when you double clicked from OFF, the light turned on and off quickly before going to ceiling. This is the case with my review light with old firmware as well.
The FW3A on turbo with a 30Q heats up to about 50°C when the thermal limit is set to 55°C. It stabilizes at around 46-48°C. This is a good setting for not burning your hand. Also loving how quickly the heat transfers to the battery tube from the head.
In case we do end up with the slightly older version of the firmware (not that it sounds like a big deal), the FW3A has accupuncture style flashing holes, right? At least, I think that’s what I heard but I don’t have time to check at the moment. I’ll search some posts later when I get time, assuming nobody has already answered by then. Reflashing should be somewhat easy if this is the case though.
Happy to report that the beam is very pretty with the 10511 optics. No discoloration in the middle of the beam. Just some radial artifacts at the edge of the beam, which are not even visible on a white wall unless you rotate the light.
Sounds about right. It uses a window of 10 C as its target zone. If it can get the temperature anywhere in that window, it stops trying to adjust the output. So with a limit of 55 C, the window would be from 45 C to 55 C.
If you happen to have some other optics like 10507 or 10509 it would be nice to have some pictures, all from the same distance, to see what they look like. Assuming your not too busy.
