I am using 2 of these cells in a solar powered light to replace a lead-acid battery, and it works just fine.
(for about one month now, i hope they last longer than the lead-acid battery, that was only one year old and the capacity was only 150mAh instead of 4Ah)
The capacity test on my hobbycharger gave about 6500mAh, but my cheap hobbycharger is not professional measure equipment like HKJ is using.
I don’t have any 32650 light but I imagine the diameter would be very comfortable to hold. Energy density doesn’t match the top cells (unless you limit your search to only match the chemistry), neither volumetric nor gravimetric but 150W/cell pulse with 90W/cell continuos is quite good. Would be a nice choice for some hot rod.
Driver development needs to step up further. If you keep thinking in plain MOSFET switches controlled with ATtiny microcontrollers this is unlikely to happen. Regulation is good, full regulation even better. Keep improving it.
I love regulation! I love FET based linear drivers for their low cost and high power density. I love induction based drivers for their efficiency.
But boosting at 50A input is expensive.
And a 32700 light won’t be superb in lm*h/g or lm*h/mm³. Therefore here I value efficiency less than elsewhere.
But I view these cells as a good match for big toilet plungers. Cheap, probably better grip than N*26650 and 4N*18650, powerful.
Rust in cells can form in humid saline environments, near cold shores for example. A friend of me took a few cells in a trip to the northern lands of Spain and they came home with some serious rust crust, particularly in the more frequently used units. We were cleaning and rewrapping them the other day.
On the other hand a bit of rust is probably no issue for chinese factory quality control departments, and certainly not for their wholesalers/storekeepers. And given my knowledge in this regard, neither is for me.
I’m surprised that there’s not much discussion about these cheap cells. I have ordered many batches from Aliexpress and Ebay from different manufacturers. I have not tested all of them yet, but here’s some initial results:
Noname cells from Ebay: average capacity about 5800mAh
Varicore brand cells from Aliexpress: average capacity about 5850mAh
Liitokala brand cells from Aliexpress: only one tested so far. Capacity 6262mAh
All cells look pretty much the same, but Liitokala has slightly different looking positive pole. Capacity was tested by discharging to 2V using ZB2L3 module with 2 Ohm resistor.
For the price these cells perform great and have pretty consistent capacity. Liitokala might have little more capacity than others, but they cost slightly more. I’m really happy if these really last the 2000 cycles mentioned in the description.
Does anyone else have experience or measurements about these gray 32700 LiFePo4 cells?
I want to buy 4 of these cells, but i would like to know who sells the best ones, or the best value for the price.
Many many AliExpress stores sell them, but even though they all have a gray wrapper, there are different specifications, prizes and even sizes (between 32600 and 32700).
Soooo…. Any advice is welcome.
And what is the value of a review written by someone who doesn't knows where his/her arse is? You know what this means, doesn't it?
The cells are good. Their consistency could be better, I know. But with LiFePO4 this is less important, at least with regards to battery pack assembly as I've already discovered the chemistry is self-balancing.
If you do care much about using them in series, buy twice or thrice the number of cells you need and, with the help of some battery capacity measuring device, sort/bin them low to high and make balanced packs. I recently bought this inexpensive EBD-M05 constant current capacity tester, discharges at up to 5A with 4-wire independent voltage monitoring and does discharge graphs. User HenrysCat has one, check:
It just occurred to me that 3S configuration of these cells can run perfectly on a 2S Li-Ion driver, because low voltage protection will kick in at 6 Volts.
Since the consistency of those 32700 LiFePO4 cells is not the best at least one could drop a bit below 2 V. I see no reason for this to be a problem, though.
Mmm, just noticed I already pinpointed you to the EBD-M05 device.
