What did you mod today?
It shows, nicely done! You can send it to Texas for evaluation… :wink:
:wink:
We have a friend over there in Moffat that hasn’t been to visit in a while, maybe I could convince her to come and she could bring it with her. She might even be persuaded to bring some of that fantastic candy from the Moffat Toffee Shoppe. :smiley:
That’s only about 50mi from me, the toffee shop’s on the way too :smiley:
My Mom and Lettie have been friends since 1943, Lettie worked at the toffee shop many many years. Lettie was originally from London, married a man from Moffat and they lived there all their married lives. Jim passed some years back… My Mom and Dad have been there visiting and loved the country, I’ve always wanted to go but have never managed it…
Nice to hear of old friendships like that.
Well, if you ever do visit, go between June - August, the only time there’s a chance of warm/ good weather but still likely to experience all the seasons in a single day :smiley:
Thanks. Is there a “Mare’s Tail Loch” nearby, or something like that? My Dad has told stories of hiking up to it and some of the family/friends didn’t go because it was a long steep trail. Would like to see that and then some. But not on a cold dreary day. :stuck_out_tongue:
I’m not familiar with the area though I did have a girl from Galashiels a few years ago which is fairly close, nice clear skies at night there, I never knew there were so many visible stars :slight_smile:
Here’s loch Skeen and some of Mares tail walk.
Can you see the toffee shop? :smiley:
I live somewhere between Arthurs seat & the castle in Edinburgh.
Beautiful valley! And the castle has an appeal all it’s own… thanks for those. Now you’re going to have to build a Grey Mare’s Tail light in honor of the moment. :smiley: hahahahaha
I replaced the battery in my new Convoy T2 with a ladda 2450.
Is that considered a mod? I’m slightly worried that it may not be . . .
Congrats on your meatball powered mod! and welcome to the forum
Barbarian! But don’t worry about it :smiley:
Here you go ;)
CRX Copper & Brass Mares Tail Nichia 219B - Beta-QR - AAA - Fw Clicky Tail Sw - 72lm.
Copper & brass construction
Copper shell, Brass core
Nichia 219B-V1 emitter
12mm ARC glass window :D
OP reflector
Copper & brass hand made pill
Beta-QR 2 mode driver
Starts in low mode
Copper forward clicky tail switch
Rubber switch boot underneath
AAA/ Eneloop cell compatible
Lockout-able
Max - 72lm/ 15lm OTF
Length – 85mm
Width – 15mm
Weight – 65g (with Eneloop AAA)
Ewww. But it works!
Folomov 18650S with an Attiny
LOL…can I have it? :wink:
Seriously though, love it! GITD and little lighty thingies all over a light just make it 10x better. Nice work!
Ah, you make me smile, thanks :slight_smile:
Installed Lexel’s aux LED board in my D4 last night:
It was too bright for me. The blue LEDs seemed as bright as moonlight mode! I added a random resistor taken from an old driver to dim it down. This helped quite a bit.
Mods I am still contemplating for this light:
  • The random resistor I added to the aux LED circuit is wired to the aux LED board between the positive lead and the board. I’m thinking of moving this resistor to a more secure location on the driver between the negative lead and the ground pad on the 7135 chip.
  • The aux LED board is currently wired directly to positive so is always on. I need to look at that walkthrough and figure out how to enable aux LED support in the driver so the driver can control the aux LEDs.
  • I’d like to try to make a lighted switch on this D4 with one or two LEDs. The plan is to drill a hole through a bare portion of the switch cavity for the LED switch wire. Inside the switch cavity I plan to mount an LED or two plus resistors. Not sure how well this will work. Possible complications include the resistors and LEDs being felt by the finger through the switch button, which might require dremeling a cavity for them.
  • I plan to replace the black switch boot with a clear or white one so the switch light is visible. To make the new switch boot I plan to cut up a standard clicky switch boot. However, I do not know if this will be flexible enough. One concern is that I might not be able to sufficiently shape the new switch boot to provide the right tactile feel.
Very nice.
Yeah that’s what I used for a lighted switch on the D4, two 1206 green LEDs & two resistors, quite a difficult job mucking about with trying to get the switch right.
If you could dremmel out space for the compnents that would prob be better but you’ll have a lot of experimetation with this :smiley:
I actually used copper tape with the SMDs & wires soldered on and some 12mm acrylic tube to give a lighted ring effect, lot of trial & error there.
Nice mode CRX,
Have you tried to make that switch “capacitive”, like measuring conductivity between “button” and body!?
Thought about that method before and did a little experimentation but gave up when I couldn’t find suitable switches easily.
