Lumintop GT micro
mine arrived today
how many Amps do you get @900 Lumen TA?
It starts off a bit under 4A and drops to around 3.4A, showing that the cell is responsible for the initial lumen drop, not the light. There may be better cells out now that would not voltage sag as bad.
Btw what 14500 you used for testing? Just asking because i just have 2A protected and ~3A unprotected… so i need to buy some better ones.
I am using some 600ma cells I got from mtn some time back. Windyfire or something like that? They were reviewed pretty well at the time and I have never had a need for anything better. I only owned 1 14500 light before this anyways.
The cells you have should be ok I would think since higher resistance cells will not pull as much power.
my nitecore 650 mAh (black yellow) make 3,9A on the GT micro (and 3,8A on a BLF X5)
my shockli 660 mAh (yellow) make 4.95A on the GT micro (and 4.1A on a BLF X5)
unfortunately i fried something (i think a 7135) when using big wires in the head from my bench power supply
the led ia always on (230mA) , but ramps up to high (~2A) above that and also jumps to turbo.
@TA: do you have an idea what i did blow?
Thanks for the answer Texas_Ace and M4D M4X
The Windyfire are good mid-high current cells (for their size) according to HKJ tests. They have a discharge curve almost exactly like Efest Purple 650mAh cells which are known around here for being good cells. The new high capacity Vapcell 1000mAh cells lag a lot more (but last longer at the end).
If the higher modes work fine then your first guess sounds good to me, the 7135 fried. This can happen as the ripple from the power supply combined with the long leads can lead to massive voltage ringing. The first thing to go is usually the 7135.
In what stage is this build ? Thanks !
Not totally sure, they have not exactly been giving me regular updates.
The prototype they sent me looks pretty much ready for production though save for the wire change. So I am guessing that production will be started after CNY.
Thanns for the update TA . :beer:
thanks !
Hello which 14500, 3.7V Li ion cell is best suited GT micro feeler, how much mA is good ?
I am going to use THESE, by Windyfire …. because I have them. But mostly because they are great cells. They come flattop or button top… I have some of both.
Windyfire 14500 IMR 600mAh - Flat Top
Unprotected, flat top. This is one of the best “high drain” 14500 cells available, outperforming even the venerable AW and Efest 14500 cells—check out the discharge comparison picture!
Read HKJ’s review of the cell.
Diameter:14mm
Height: 49.1mm
Manufacturer Cell Specifications:
  • Nominal Capacity: 650mAh (0.2C discharge)
  • Charging Termination Voltage: 4.2v
  • Maximum Continuous Discharge: 6.5A
  • Maximum Pulse Discharge: 9.75A
  • Recommended Charge Current: 0.5A or 0.25A
  • Maximum Charge Current: 1A
  • Recommended Discharge Termination: 3v
Hello my dear friend!
Today i give you a first look on the Lumintop GT micro - a 14500 driven, Narsil controlled miniature thrower.
Up to 900 Lumen and a theoretical throw of 500m paired with a great user interface!
www.youtube.com/embed/vQO302LAPGI
Another great review Martin!! Thank you for sharing it with us. :beer:
Really looking forward to this new member of the GT Family……
………… the GT Micro.
Nice to see the GT micro in someone’s hand for a size impression. Thanks for the review Martin.
(in the outside shot session you showed the X5 but you call it the X6)
Hello Teacher thanks for your Info, :+1:
Unfortunately the Windyfire 14500 IMR 600mAh cells is not Available in Germany, (Germany (NO BATTERIES) | Germany has been temporarily suspended.)
That’s why I ordered these cells. Enercig (Tensai) TN1450HP - 650mAh 3,6V - 3,7V Li-Ion-Cells. - 6,5A/13A
https://www.akkuteile.de/lithium-ionen-akkus/14500/enerpower/enercig-tn14500hp-650mah-3-6v-3-7v-pluspol-flach-li-ionen-akku/a-100117/
When and where to buy??? I’m in.
My pleasure gtxxl. :slight_smile: . The ones you ordered should work great. :+1:
