[M4D deal ALIVE] Lumintop GT micro
they are testing the prototype afaik to get those numbers
€dit got the
Specifications
Emitter: Cree XP-L High Intensity, neutral white or cold white, mounted on copper DTP MCPCB
Flux: ~1000 lm
Throw: ~400 m & ~50Kcd
Firmware: Tom E’s open-source GPL NarsilM v1.3 adapted by Texas_Ace
User interface:
[1] By default the GT micro is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 2.5 A TURBO mode is also provided.
[2] A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 predefined mode-sets can be selected.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Battery: One 14500. Cell is not included.
Driver: Texas Avenger FET driver
Reflector: 29 mm ID, aluminum, smooth finish
Lens: Glass with anti-reflective coating
Body: Aluminum with Type III hard-coat anodizing
Button: Tactile with back-lit rubber boot
Ingress rating: Equivalent to IP65, do not immerse in liquids
Weight: Approximately 70g without cells
Dimensions: 36 mm Ø head x 105mm length
I’m glad they skipped the nimh.
Is there a spring on the driver end? My recently acquired Vapcell 14500’s doesn’t work with some button head drivers.
Thought I signed up for this, but I don’t see it in my subscriptions, so I’m in for 1 NW please
you need to leave your contact email in the sheet to receive the buying information ;)
Filled in for one cw , thx
Any update on this?
nope
silence from Neal :(
I just got mine…seems sweet so far…OOPS wrong thred…lol…i hope they ship soon
Hello my dear friend!
Neal has finally listed the Lumintop GT MICRO on his shop (please use this link)
use the code: GTMICRO to get 25% OFF
i made a short introduction video of the smallest member of the GT family too:
YouTube
and lumintop store has a coupon code: SPR20DIS 20% off for over $10 , end date:April 30th
Ordered, Thanks Martin
Thx nw ordered
ordered 1 nw and 1 cw. Thanks Martin
One cw ordered- thanks Martin
Ordered CW.
Cheers Thanks to All Folk’s In This.
Ordered one NW thank you
Ordered one NW. Thanks as always!
ordered, thanks.
protected or unprotected batteries for this?.
Description says 2.5 amps in Turbo, is this really true?
Need more juice than that.
Hoping this is just cut and paste from BLF GT specs.
Thanks!
