Overview: All Eneloop batteries 2005-2024
Noticed eBay has eneloop lites for reasonable prices shipped from lithuania. Think they are legit? I like the idea of lower capacity that’s why I use rayovac aaa instead of eneloop mostly.
Do you have a link?
Just type in eneloop lite in eBay and bunch will show up in the USA at least.
Link tp lites 4 x Panasonic eneloop LITE AA 950mAh batteries Ni-MH Rechargeable HR6 BK-3LCCE 5410853052739 | eBay
Also have aaa. Hope link works.
AAA are 550mah 6 Panasonic Eneloop Lite Rechargeable AAA Hr03 Batteries 3 BLISTER 1.2v 550mah for sale online | eBay
Yes, that looks like a legit seller from Lithuania. Premiumpleasure.
Hmmmm…. I wonder what kind of stuff they are selling the batteries for?
ordered some of the aaa lites. Now to see how long it takes to ship from Lithuania. After 3000 cycles will give my opinion of them in about 40 years.
LOL.
Will put it down in my calendar on February 5, 2059.
Talk to you then!
Got my order. That was pretty fast. Now to start testing.
Great.. Looking forward to some test results!
Does anyone know the expected lifespan of Eneloops when they’re only run through a few cycles per year? How are older cells holding up under these conditions?
Probably many many years.. I am pretty sure 10+ years....
From everything I have come across until now.
I’m getting great service from AA, AAA not so much. I think that form factor is less robust.
Yeah, we’re still figuring that one out. I have several Eneloops from the year they came out (2006), and they’re all still good. Maybe lost 5–10 of their capacity. They have somewhere between 100-200 cycles on them.
Out of over 300 Eneloops, I’ve only had 1 cell go bad on me for no reason. It’s from 2009. Still works, but has very high internal resistance and only 1300mAh capcity (at a low discharge rate). I’ve had 2 others go bad the same way, but that is from too many cycles (several hundred cycles).
Anyway, in general, you should easily expect 10 years out of your cells if you only cycle them 1 or 2 dozen times per year. I expect the real answer will be closer to 20 years, but I’ll have to wait another 7 years to see.
Once the cells go bad, they’re no good for high-drain applications (like flashlights), but they’re still fine for low-drain stuff, like remote controls.
That’s why i’m trying eneloop lites. Think lower capacity nimhs have all the advantages EXCEPT capacity.
Guys, I need your advice:
I’ve got 4 Sony LSD AAA batteries ( NH-AAA-B4GN 840mAh), that are rewrapped 1st and 2nd gen Eneloop PRO batteries according to eneloop101 website. Recently, these batteries stopped being charged by my Panasonic BQ-CC17 smart charger (charging leds keep flashing), which usually means the internal resistance of these batteries is too high. Unless I got counterfeit batteries, this shouldn’t have happened, because I purchased them in September 2016 and they have always been charged with the aforementioned smart charger.
I’m aware of the trick of doing an initial charge with a dumb charger and then completing the charge with a smart one so it will not reject the sick batteries. However, this trick has been not working with a Panasonic cordless phone charger, that can output 6.0V/400mA. I charge the batteries on the cordless phone charger and some hours later the batteries are supposedly charged, but only a few minutes after charging them with the BQ-CC17, the leds start flashing and charging stops.
My question is: is the trick not working just because I’m using a cordless phone charger, or even a dumb charger won’t be able to prevent the Panasonic charger from rejecting the batteries? I wonder whether the BQ-CC17 is a very picky charger or the Sony batteries are really sick even after less than three years of use and being properly cared. It would suck to buy a dumb charger and find out that the smart one will still reject the batteries.
The issue is that the internal resistance of the cells has crept up to a point that the BQ-CC17 detects that they are no longer good cells, so refuses to charge them. It does this for a couple of reasons:
1. High IR could indicate that you are trying to charge alkaline cells, so the charger rejects them.
2. The BQ-CC17 uses a 25% duty cycle for each slot. It actually charges AAA cells at 600mA (and AA at 1200mA), but does it 25% of the time, for an effective charge rate of 150mA (or 300mA for AA). 600mA is too fast a charge for cells with high internal resistance, so it rejects them.
Anyway, trying to charge your cells first with a dumb charger won’t help if you later want to finish with the BQ-CC17. Your only option is to use a dumb charger for the full charge, or try a different smart charger that can use a real charge less than 600mA.
IMO, I’d just use a dumb charger (everyone should have one for these purposes). It may be tough on the cells, but they’re not good cells anyway.
Finally, they may not be real Eneloops than Sony uses, or they may not be grade A cells. You’re right that it’s unusual for real Eneloop cells only 3 years gold to develop high internal resistance, unless they’ve been used for hundreds of full cycles.
Thanks for the comprehensive explanation, I’ll get a cheap dumb charger and see if the BQ-CC17 can finish the charging. I mostly used the AAA batteries on the cordless phone, I wonder if they were cycled for hundred of times.
