What did you mod today?
8304 posts / 0 new
CRX
CRX's picture
Last seen: 6 min 43 sec ago
Ah, you make me smile, thanks Smile
Firelight2
Firelight2's picture
Last seen: 2 hours 35 min ago
Installed Lexel’s aux LED board in my D4 last night:
It was too bright for me. The blue LEDs seemed as bright as moonlight mode! I added a random resistor taken from an old driver to dim it down. This helped quite a bit.
Mods I am still contemplating for this light:
  • The random resistor I added to the aux LED circuit is wired to the aux LED board between the positive lead and the board. I’m thinking of moving this resistor to a more secure location on the driver between the negative lead and the ground pad on the 7135 chip.
  • The aux LED board is currently wired directly to positive so is always on. I need to look at that walkthrough and figure out how to enable aux LED support in the driver so the driver can control the aux LEDs.
  • I’d like to try to make a lighted switch on this D4 with one or two LEDs. The plan is to drill a hole through a bare portion of the switch cavity for the LED switch wire. Inside the switch cavity I plan to mount an LED or two plus resistors. Not sure how well this will work. Possible complications include the resistors and LEDs being felt by the finger through the switch button, which might require dremeling a cavity for them.
  • I plan to replace the black switch boot with a clear or white one so the switch light is visible. To make the new switch boot I plan to cut up a standard clicky switch boot. However, I do not know if this will be flexible enough. One concern is that I might not be able to sufficiently shape the new switch boot to provide the right tactile feel.
CRX
CRX's picture
Very nice.
Yeah that’s what I used for a lighted switch on the D4, two 1206 green LEDs & two resistors, quite a difficult job mucking about with trying to get the switch right.
If you could dremmel out space for the compnents that would prob be better but you’ll have a lot of experimetation with this Big Smile
I actually used copper tape with the SMDs & wires soldered on and some 12mm acrylic tube to give a lighted ring effect, lot of trial & error there.
Sirius9
Sirius9's picture
Last seen: 11 hours 20 min ago
CRX wrote:
Nice mode CRX,
Have you tried to make that switch “capacitive”, like measuring conductivity between “button” and body!?
CRX
CRX's picture
Thought about that method before and did a little experimentation but gave up when I couldn’t find suitable switches easily.
Sirius9
Sirius9's picture
I was looking at something like this 12V toutch switch for led strip, maybe it could be moded for 4,2V application?
Firelight2
Cereal_killer wrote:
Ewww. But it works!
Folomov 18650S with an Attiny
!{width:75%}https://i.imgur.com/yU5phyB.jpg!
You got your 18650S working with an Attiny? Will it run Anduril?
Cereal_killer
Cereal_killer's picture
Last seen: 13 min 44 sec ago
Ewww. But it works!
Baby steps.
The t85 is a different beast than the 13a… The end goal is a direct replacement FET+1 running anduril!
Firelight2
Ewww. But it works!
Baby steps.
!{width:65%}https://i.imgur.com/Bq47D3x.jpg!
Yes please!
It would be AWESOME to have Anduril in a tailcap mounted driver that doesn’t need an extra electrical connection to the head. With such a driver, it wouldn’t be hard to mod any tailcap clicky light into an e-switch light with Anduril.
when are you going to sell these Anduril tailcap drivers? I’ll take 10! Silly
contactcr
Last seen: 4 hours 55 min ago
Ewww. But it works!
Reminds me of the game Operation.
For this one you will truly need to be a surgeon:
https://www.illumn.com/pre-order-folomov-edc-c1-brass-nichia-e21a-95-cri...
Tamagotchi
Tamagotchi's picture
Project “Aphrodite”.
This flashlight is product of teamwork Tamagotchi and k_4.
Length: 97.75 mm
Head width: 23.6 mm
Handle width: 21 mm
Weight: 49 grams
Carclo 10507, 3x XP-L Hi V2 3A, serial connection.
Driver Caerus II output 2.2A
18650 battery
djozz
djozz's picture
Last seen: 19 min 35 sec ago
Very nice! Love the way the texture on the battery tube is done Thumbs Up
(nails were very nicely done too Party )
k_4
Last seen: 4 weeks 1 day ago
Thanks for your comments .
Smile
Tom E
Tom E's picture
Last seen: 8 hours 9 min ago
It looks fantastic! 2.2 amps keeps it somewhat tame with the heat. What material is that? Looks to be an SS bezel, but the rest I'm not sure of. Probably laum or titanium because of the light weight?
k_4
Hi Tom , it’s all aluminium, 2024 in classification on Europe and USA. Just it is polished … 22 Watts is turbo mode and it’s not long, because PI regulator control the overheat, it just about 30 sec , then power is slowly down and stabilizated on the thermal balanse.
P.s. sorry for my bad English Wink
CRX
CRX's picture
Cool Thumbs Up
k_4
Thanks Smile
chadvone
chadvone's picture
Wow. That is some great work. Good Job Tamagotchi and K_4
Firelight2
Agreed. Awesome job!!!
Where do I place my order for the group-buy? Silly
staticx57
Last seen: 7 hours 21 min ago
That is one sharp looking light Cash
MRsDNF
MRsDNF's picture
Last seen: 11 hours 46 min ago
Love
Firelight2
Trying to make a lighted switch for my D4.
I bought a ton of tiny colored 0603 LEDs from Amazon ($14 for 360 in various colors).
… but now I need resistors for them. Innocent
QUESTION: What resistors should I buy? … preferably a link to suitable resistors from Amazon.
Thanks!
ZozzV6
ZozzV6's picture
Last seen: 6 hours 2 min ago
Ewww. But it works!
I need to know more of this Big Smile
Today I dedomed an XHP70.2 again that will fit in a resistor modded Thorfire S70S with an L6 SMO reflector.
contactcr
So when are you selling these LEDs?
ZozzV6
ZozzV6's picture
If there is a demand for it I can do it but each led is around 20-30 minutes to finish and shipping costs added all things almost triple the led price. I don’t think anybody will pay that much. If there is a significant demand I can make them.
And almost forgot:
Made another C8+ and an Eagle eye X6 with Osram White flat 1mm2
DB Custom
DB Custom's picture
Last seen: 10 hours 43 min ago
Did some simple work on a friends Q8, put 4 SST-40’s on a LED4Power quad board made for the Q8, swapped out the MOSFET for a 404, opened up the reflector aperture’s to fit over the entire substrate of the 40’s, replaced the springs with stacked Blue springs… the Q8 now has a nice defined hot spot and does 11,200+ lumens at start on new 30Q’s. Wink
Tom E
Tom E's picture
Dale - is that a typo? 11200 lumens is 2800 per LED, if I understand that right? SST-40's are good, but...
Still a nice CW mod!
DB Custom
DB Custom's picture
32,600 on my meter Tom, translates to 11,247 lumens. Brand new first time charged 30Q cells. Even if you take off 10% for margin of error, it’s still over 10,000… the numbers are what the numbers are, it’s bright as all get out and Rick will be tickled to death with it.
Edit: Cool white? Not so’s you can tell….
Tom E
Tom E's picture
I got 12.5K lumens in a SupFire L1 (5 SST-40's) at turn on (manufacturer lumens), so I know it's close.
And in a modded SP03 with 3 SST-40's I got 7480 lumens at turn on (manufacturer lumens) and 235 kcd, using VTC5D's (Vapcell).
Checking my notes for the SP03, I realize I added in 26 AWG 3" wire to add resistance, not sure bout the springs.
So, sure looks like 2800/LED is realistic for a fully tweaked setup.
djozz
djozz's picture
Koef3 found in a bare N4 led test 2670 max, and I found in a bare led test around 2500 max for the SST-40 (the heat management of my gear is good but not as good as koef3’s). In a real life flashlight build with 1×18650 I got 2200 lm at startup. The latest bin is N5 so if koef3’s number is taken you can get 2850 lumen max out of a bare N5 led. Reflector and lens will normally eat 15% (also expected for a Q8) so if everything is perfect you can get 9700 lumen OTF from a quad.
These numbers are for a calibration close to maukka’s calibration (=as close to reality as we know it). Perhaps Dale and Tom use a different one?
