Lumintop GT micro
Thanns for the update TA . :beer:
thanks !
Hello which 14500, 3.7V Li ion cell is best suited GT micro feeler, how much mA is good ?
I am going to use THESE, by Windyfire …. because I have them. But mostly because they are great cells. They come flattop or button top… I have some of both.
Windyfire 14500 IMR 600mAh - Flat Top
Unprotected, flat top. This is one of the best “high drain” 14500 cells available, outperforming even the venerable AW and Efest 14500 cells—check out the discharge comparison picture!
Read HKJ’s review of the cell.
Diameter:14mm
Height: 49.1mm
Manufacturer Cell Specifications:
  • Nominal Capacity: 650mAh (0.2C discharge)
  • Charging Termination Voltage: 4.2v
  • Maximum Continuous Discharge: 6.5A
  • Maximum Pulse Discharge: 9.75A
  • Recommended Charge Current: 0.5A or 0.25A
  • Maximum Charge Current: 1A
  • Recommended Discharge Termination: 3v
Hello my dear friend!
Today i give you a first look on the Lumintop GT micro - a 14500 driven, Narsil controlled miniature thrower.
Up to 900 Lumen and a theoretical throw of 500m paired with a great user interface!
www.youtube.com/embed/vQO302LAPGI
Another great review Martin!! Thank you for sharing it with us. :beer:
Really looking forward to this new member of the GT Family……
………… the GT Micro.
Nice to see the GT micro in someone’s hand for a size impression. Thanks for the review Martin.
(in the outside shot session you showed the X5 but you call it the X6)
Hello Teacher thanks for your Info, :+1:
Unfortunately the Windyfire 14500 IMR 600mAh cells is not Available in Germany, (Germany (NO BATTERIES) | Germany has been temporarily suspended.)
That’s why I ordered these cells. Enercig (Tensai) TN1450HP - 650mAh 3,6V - 3,7V Li-Ion-Cells. - 6,5A/13A
https://www.akkuteile.de/lithium-ionen-akkus/14500/enerpower/enercig-tn14500hp-650mah-3-6v-3-7v-pluspol-flach-li-ionen-akku/a-100117/
When and where to buy??? I’m in.
My pleasure gtxxl. :slight_smile: . The ones you ordered should work great. :+1:
Interested please.
Definitely in for one or two, imagine this with a White 1 :money_mouth_face:
Any update on this ?
I tried searching in here and didn’t see an answer. Should we get flat or button top for this light?
Thanks for the suggestion on a cell.
Larry
I can’t say for sure, I would ’think’ either one would work. Maybe M4D M4X can answer that question.
the driver has a raised button with 5mm diameter - so i think most cells would work
but if the shrink does cover the button ....
I think a Flat Top Cell, on the driver can work.
From the looks, a button top is safest. That might be large enough to go off the edges of a flat top contact. There’s enough room in the spring travel for a couple mm of length?
That’s a 5mm button on the driver, a flat top cell is easily 8mm inside the wrap, no problem. :wink:
The cut offs on the via’s are at a minimum 8.6mm, and they should be below the level of the button anyway….
look here Lumintop GT micro interest list
