I try not to update the list more than once per week, and the last update was only two days ago. The timestamp at the top of post #4 shows when it was last updated.
A flower is simply the effect of rearranging some of the chemicals in dirt into a different form, and people see them all the time… but I still like to stop and smell them.
It’s odd because he used a unprotected flat top which should be 65mm long. The 30Q should be 64.9mm long. The FW3A has springs on both ends. In theory it should work.
False alarm. It seems the driver is not positioned corectly.
Yes, but the issue isn’t really about the battery… Bluzie seems to have gotten one with the same driver fit issues I had, and I’m pretty sure that’s the source of the problem(s).
I sent quite a bit of detail to Neal, and mostly just need to wait for him to work things out with Lumintop.
Just want to make sure I’m still on the list. I originally signed up for 3 then later canceled 2 but I’m only able to find the two cancelations listed.
I do still want one light, am I still down for one?
These are prototypes, not production, or even pre-production. Lots of short cuts are made in the proto phase, plus things are not finalized yet.
In the Q8 project, we went through a lot of similar trials/tribulations. Believe me, this is wayyy better they are going slowly rather than rushing this out. You should never see or hear about this problem in something shipped that's paid for. Early reviewers also see some bad stuff that gets fixed before shipped.
Exactly, that is the reason for prototype builds… I saw these referred to as ‘Proto4’ in one of the posts. That’s a good sign they are finding and working out any issues before moving on to the next build phase.
