Itās odd because he used a unprotected flat top which should be 65mm long. The 30Q should be 64.9mm long. The FW3A has springs on both ends. In theory it should work.
False alarm. It seems the driver is not positioned corectly.
Yes, but the issue isnāt really about the batteryā¦ Bluzie seems to have gotten one with the same driver fit issues I had, and Iām pretty sure thatās the source of the problem(s).
I sent quite a bit of detail to Neal, and mostly just need to wait for him to work things out with Lumintop.
Just want to make sure Iām still on the list. I originally signed up for 3 then later canceled 2 but Iām only able to find the two cancelations listed.
I do still want one light, am I still down for one?
These are prototypes, not production, or even pre-production. Lots of short cuts are made in the proto phase, plus things are not finalized yet.
In the Q8 project, we went through a lot of similar trials/tribulations. Believe me, this is wayyy better they are going slowly rather than rushing this out. You should never see or hear about this problem in something shipped that's paid for. Early reviewers also see some bad stuff that gets fixed before shipped.
Exactly, that is the reason for prototype buildsā¦ I saw these referred to as āProto4ā in one of the posts. Thatās a good sign they are finding and working out any issues before moving on to the next build phase.
Even more confusion. In the TLF they are talking about the light not working without the clip because it works as a spacer for the tail cap(?). If thatās the case it might be a good idea to include a spacer ring to replace the clip if someone does not want the clip(?)
Euhm, wasnāt this suposed to be a (pre-)production light? I believe I read this a couple of pages ago and that TK commented that she believes people of lumintop donāt quite get what a production sample is. Anyway, Iāve learned itās better to wait until the first batch has been send out and tested by the buyers before placing/paying my order.
