It seems the TS70 is very much like the Thrunite TC20, but has 6 brightness levels instead of 5. It has the same nice UI of single click on/off and press/hold to cycle through the levels.
I was gonna say the same thing. It looks like a copy of it. Even the design is very similar.
nice packaging!
Convoy New L6
XHP70.2 4300lm 5000mAh Powerful Long Range Strong LED Flashlight
Specification:
Brand | Convoy |
Material | Aluminum alloy |
LED & Colo Temperature | N4-7A: 3000K P2-5C: 4000K P2-3C: 5000K P2-1A: 6500K |
Power | 40W |
Lumen | 4300lm |
Voltage | 6-8.4V |
Range | 200-300m |
Modes | 5 modes |
Reflector | smooth reflector |
Waterproof | IP68 |
Color | Black |
Length | 255mm |
Weight | 778g |
brand | model =my link to use | code | price | shop |
Convoy | NEW L6 4300Lm | see deals list | 45.00 | banggood |
Hello my dear friends!
just follow this LINK and find a new collection with many great offers from flashlights and other LED products!
there is a nice collection (MF04 only 169.- / MF01 just 78.- / S2+ 9.99)
do not miss the (up to) 66% OFF collection !
Any idea if the Convoy L2 with XHP50.2 LED will be available in BG or GB (and hopefully have a nice coupon code too?)
I notice there’s no 5000K XHP50.2 in the official Convoy Ali store though… and that the L2 requires 2x 26650s to work. (I wonder if 2x 26350 will fit the L2 short tube… but that’s a topic for another thread…)
EU & US Warehouse Chinese New Year 11% Off Coupon: b8a2e2
EU Warehouse Promotion:
US Warehouse Promotion:
Any chance of getting a deal on the new 2019 Jetbeam RRT01 ?
Thanks
I look into that after the holidays
+1
Crap I bought it yesterday… any chance you could get an even better one than the current one for the MS12?
thats crazy “cheap” for that light
right after the CNY banggood.com releases the:
(click thelinks or pictures to go to the shop)
Astrolux FT03 ($45.95)
with Code: MVXBJ -> $ 28.99
SST40-W 2400lm 875m (190 kcd)
UI: NarsilM v1.3
USB-C Rechargeable 2A
26650 21700 18650 LED Flashlight
Battery: One 26650 cell (or a 21700/18650 cell) Cells are not included.
Driver: Texas Avenger FET Driver with charging
Reflector: High quality smooth reflector
Lens: Glass with anti-reflective coating
Body: Aluminum alloy with Type III hard-coat anodizing
Button: Silicone rubber
Ingress rating: Equivalent to IPX7, do not immerse in liquids
Impact resistance: Up to 1.5 meters
Weight: Approximately 295g without cells
Dimensions: 170mm*69.5mm*34.5 (length*head diameter*body diameter)
keeppower |
10.70 USD
use code AC18 ;)
a Bunker tour
veröffentlicht am 12. February 2019 in Allgemein von m4d m4x
here is a deal for the NEW
Convoy S2+ SST20
RA> 95 / 4000k
use this SHOPLINK and the code: BGCS2G to lower the price to US$ 12.99
Specification:
Brand | Convoy |
Driver | 7135 biscotti firmware |
Low warning voltage | Yes |
Reverse polarity protection | Yes |
Lens type | Ar-coated glass |
Reflector | Soft |
Memory mode | Yes |
Tailstand | Yes |
Height | 118mm / 4.65inch |
Width | 241mm / 9.49inch |
Type | 7135 x 3 7135 x 4 7135 x 6 7135 x 8 |
Conductor | current output 1050mA current output 1400mA current output 2100mA current output 2800mA |
Weight | 76g |
Fasttech showed max lumens for the 8 chips at 650
I assume your refering to the sst20 output?
Yeah, it’s about the same or a little better than the Nichia 219B. Still noticable less than the XPG2, xpl or xml2, but maybe a nicer looking beam. I’m not too familiar with the sst20.
Of course.
The SST-20 4000k and below is a 2mm2 high CRI R9580 LED.
It is quite the LED.
