Amazon Deal Alerts & Discussion Thread
The S1 R II is $85, only 15% off. Not a compelling deal.
Summer and Autumn are at $59. The winter one that I was looking for is $85 which is a joke.
@ rcwiily…. Thanks for the link. :+1:
Yeah peg… I do not feel compelled at all in fact. :wink:
I’ll be honest, I felt a little compelled…
ThorFire CT01 $3.50
https://www.vipon.com/product/5895746-ThorFire-Mini-Zoomable-CT01-Super-Bright-Led-Light?ref=ss_5895746_2_title
I hate Zoomies… but I Had to get one :person_facepalming: …it’s cute….I like the clip….and it’s 14500 compatible, I’ll throw a Flat White in it…… :disappointed:
Edit: where is my manners… :person_facepalming: Thanks bikenber73 :+1:
Report back what the guts look like?
Thanks for the tip bikenber73. Picked up a few for the grand neices & nephews to play around with…. :wink:
Yep, prolly a press fit fet/resistor driver, but hopefully it dosen’t have a the hollow pill, even then I can make a press fit aluminum or copper press fit slug for it… :+1:
Hope the switch is better than typical SK68's - ordered one to find out. Thanks
Ordered one for a gift. Thanks
From some random muggle review ~1yr ago:
I got two to play with. Thanks for the heads up bikenber73. :+1:
:slight_smile:
Y’all talking about the teslacom 12x SRK? I have one.
No, not the 12X. For the teslacom 2 cell light on discount, I was able to get the bezel off with a strap wrench, no glue, and got full access to the LED and drvier - got them out easy enough. I'd rate it as moddable for me, though the driver would have to be mounted/piggybacked somehow in there, but certainly doable.
I took the xml out of mine and put an SST-40 in it. Didn’t appear to make a lot of difference visually. Have not tested output yet. May change it again. It is a 20mm mcpcb so it’s pretty easy to swap. May even try an xp-l hi to tighten up the beam.
It also has a stackable coupon fo 10% off bringing the price down to $2.80 :wink:
Hm? 3.50 - 0.35 = 3.15. Must be that new math… :laughing:
Anyhoo, mine showed a 12% off coupon, but it only applied to 2 of ’em, and I wanted 3. :confounded:
They look nicer’n the usual ’68 clones. And if actually Thorfire and not someone claiming their name, they should be decent quality, even for zoomies.
Figure with an eneloop it might be nice for carrying in the car, etc., anywhere I wouldn’t want to keep a Li cell.
it goes like $6.99 - 10% = 0.69 then you apply the coupon so it would be 3.50 - 0.69 = $2.81
