I hate Zoomies… but I Had to get one :person_facepalming: …it’s cute….I like the clip….and it’s 14500 compatible, I’ll throw a Flat White in it…… :disappointed:
Edit: where is my manners… :person_facepalming: Thanks bikenber73 :+1:
Yep, prolly a press fit fet/resistor driver, but hopefully it dosen’t have a the hollow pill, even then I can make a press fit aluminum or copper press fit slug for it… :+1:
No, not the 12X. For the teslacom 2 cell light on discount, I was able to get the bezel off with a strap wrench, no glue, and got full access to the LED and drvier - got them out easy enough. I'd rate it as moddable for me, though the driver would have to be mounted/piggybacked somehow in there, but certainly doable.
I took the xml out of mine and put an SST-40 in it. Didn’t appear to make a lot of difference visually. Have not tested output yet. May change it again. It is a 20mm mcpcb so it’s pretty easy to swap. May even try an xp-l hi to tighten up the beam.
