Yep, prolly a press fit fet/resistor driver, but hopefully it dosenât have a the hollow pill, even then I can make a press fit aluminum or copper press fit slug for it⌠:+1:
No, not the 12X. For the teslacom 2 cell light on discount, I was able to get the bezel off with a strap wrench, no glue, and got full access to the LED and drvier - got them out easy enough. I'd rate it as moddable for me, though the driver would have to be mounted/piggybacked somehow in there, but certainly doable.
I took the xml out of mine and put an SST-40 in it. Didnât appear to make a lot of difference visually. Have not tested output yet. May change it again. It is a 20mm mcpcb so itâs pretty easy to swap. May even try an xp-l hi to tighten up the beam.
Hm? 3.50 - 0.35 = 3.15. Must be that new math⌠:laughing:
Anyhoo, mine showed a 12% off coupon, but it only applied to 2 of âem, and I wanted 3. :confounded:
They look nicerân the usual â68 clones. And if actually Thorfire and not someone claiming their name, they should be decent quality, even for zoomies.
Figure with an eneloop it might be nice for carrying in the car, etc., anywhere I wouldnât want to keep a Li cell.
HmmmmâŚ. mine always takes the percentage discount of the total full price before the Vipon discount. As AlexGT showed above.
I always take the slower Free Shipping option because I donât have PRIME.
BUT notice, if you do pay for shipping & the particular shipment is taxedâŚ. SHIPPING COST IS ALSO TAXED.
Yeah, unless Iâd be buying 8 of âem, Iâd get hit with shipping (no free shipping option at all). Bought myself a Rammstein shirt Iâve been eying for a while, and that put me over.
Normally, I keep a few items Iâd want at some time, but not immediately, so in case I need something to put it over the free shipping threshold, itâs there.
