teacher
(teacher)
February 1, 2019, 1:55am
326
I am going to use THESE, by Windyfire …. because I have them. But mostly because they are great cells. They come flattop or button top… I have some of both.
Windyfire 14500 IMR 600mAh - Flat Top
Unprotected, flat top. This is one of the best “high drain” 14500 cells available, outperforming even the venerable AW and Efest 14500 cells—check out the discharge comparison picture!
Read HKJ’s review of the cell.
Diameter:14mm
Height: 49.1mm
Manufacturer Cell Specifications:
Nominal Capacity: 650mAh (0.2C discharge)
Charging Termination Voltage: 4.2v
Maximum Continuous Discharge: 6.5A
Maximum Pulse Discharge: 9.75A
Recommended Charge Current: 0.5A or 0.25A
Maximum Charge Current: 1A
Recommended Discharge Termination: 3v
M4D_M4X
(M4D M4X)
February 2, 2019, 12:09am
327
Hello my dear friend!
Today i give you a first look on the Lumintop GT micro - a 14500 driven, Narsil controlled miniature thrower.
Up to 900 Lumen and a theoretical throw of 500m paired with a great user interface!
www.youtube.com/embed/vQO302LAPGI
teacher
(teacher)
February 2, 2019, 1:13am
328
Another great review Martin!! Thank you for sharing it with us.
Really looking forward to this new member of the GT Family ……
………… the GT Micro .
djozz
(djozz)
February 2, 2019, 2:10pm
329
Nice to see the GT micro in someone’s hand for a size impression. Thanks for the review Martin.
(in the outside shot session you showed the X5 but you call it the X6)
gtxxl
(gtxxl)
February 2, 2019, 6:37pm
330
teacher:
Diameter:14mm
Height: 49.1mm
Hello Teacher thanks for your Info, :+1:
Unfortunately the Windyfire 14500 IMR 600mAh cells is not Available in Germany, (Germany (NO BATTERIES) | Germany has been temporarily suspended.)
That’s why I ordered these cells. Enercig (Tensai) TN1450HP - 650mAh 3,6V - 3,7V Li-Ion-Cells. - 6,5A/13A
https://www.akkuteile.de/lithium-ionen-akkus/14500/enerpower/enercig-tn14500hp-650mah-3-6v-3-7v-pluspol-flach-li-ionen-akku/a-100117/
Reignman
(Reignman)
February 2, 2019, 7:24pm
331
When and where to buy??? I’m in.
teacher
(teacher)
February 2, 2019, 8:04pm
332
My pleasure gtxxl. . The ones you ordered should work great. :+1:
dotBLF
(dotBLF)
February 11, 2019, 8:26pm
334
Definitely in for one or two, imagine this with a White 1
lmcmann
(lmcmann)
February 18, 2019, 9:19pm
336
teacher:
I tried searching in here and didn’t see an answer. Should we get flat or button top for this light?
Thanks for the suggestion on a cell.
Larry
teacher
(teacher)
February 18, 2019, 9:23pm
337
I can’t say for sure, I would ’think’ either one would work. Maybe M4D M4X can answer that question.
M4D_M4X
(M4D M4X)
February 18, 2019, 10:48pm
338
the driver has a raised button with 5mm diameter - so i think most cells would work
but if the shrink does cover the button ....
gtxxl
(gtxxl)
February 20, 2019, 1:53pm
339
I think a Flat Top Cell, on the driver can work.
lmcmann
(lmcmann)
February 19, 2019, 8:41pm
340
From the looks, a button top is safest. That might be large enough to go off the edges of a flat top contact. There’s enough room in the spring travel for a couple mm of length?
DB_Custom
(Dale)
February 19, 2019, 8:49pm
341
That’s a 5mm button on the driver, a flat top cell is easily 8mm inside the wrap, no problem.
The cut offs on the via’s are at a minimum 8.6mm, and they should be below the level of the button anyway….
gtxxl
(gtxxl)
February 21, 2019, 8:53pm
342
Smokecutter:
Interested please.
look here Lumintop GT micro interest list
Hello my dear friends!
The Lumintop GT micro is near!
[image]
Unfortunately the driver cannot offer the additional AA / NiMh compatibility without adding downsides as:
low power in AA/NiMh config + HIGH parasitic drain + with 14500 its turbo only
So Lumintop decided to stay with the GT micro in the footsteps of the BLF GT: single LED – HIGH output – HIGH throw (for its size)
(the Narsil AA/NiMh/14500 design is not burried…. there are more proje…
mortuus
(mortuus)
February 23, 2019, 9:05am
343
Saw on facebook that according to Neal its ready to order from him now…
LUMINTOP GT Micro
Price: USD 2.50
M4D_M4X
(M4D M4X)
February 23, 2019, 9:01am
344
