Same. Light looks awesome — count me in for one!
Just want to make sure I’m still on the list. I originally signed up for 3 then later canceled 2 but I’m only able to find the two cancelations listed.
I do still want one light, am I still down for one?
Edit: 1406 is still there. Thanks!
This makes me a bit worried about their QC
These are prototypes, not production, or even pre-production. Lots of short cuts are made in the proto phase, plus things are not finalized yet.
In the Q8 project, we went through a lot of similar trials/tribulations. Believe me, this is wayyy better they are going slowly rather than rushing this out. You should never see or hear about this problem in something shipped that's paid for. Early reviewers also see some bad stuff that gets fixed before shipped.
Exactly, that is the reason for prototype builds… I saw these referred to as ‘Proto4’ in one of the posts. That’s a good sign they are finding and working out any issues before moving on to the next build phase.
No need for concern then.
Even more confusion. In the TLF they are talking about the light not working without the clip because it works as a spacer for the tail cap(?). If that’s the case it might be a good idea to include a spacer ring to replace the clip if someone does not want the clip(?)
Euhm, wasn’t this suposed to be a (pre-)production light? I believe I read this a couple of pages ago and that TK commented that she believes people of lumintop don’t quite get what a production sample is. Anyway, I’ve learned it’s better to wait until the first batch has been send out and tested by the buyers before placing/paying my order.
My bad it was djozz making the comment and maukka found it strange that his “production” sample had a cool white emitter
This has already been discussed so there should be no confusion. This is also why Lumintop wants to glue the tail cap. The tail cap and or clip is not supposed to be removed. It’s supposed to be unscrewed at the head for battery access.
This last round was supposed to be a production sample. It clearly wasnt, though because they don’t have the right led or lens. It also looks like they need to tweak the fitment of the driver. It’s diameter is a tiny bit too big or it’s hole is a bit too small causing some samples to not sit down in it’s machined hole.
The parts issue will be fixed when the leds and optics arrive. The driver fitment issue should be easy to fix with some tweaks.
Where? I am sorry, this thread gets flooded with interest-list entries. We are at post number 6800something on page number 230. I couldn’t find the word “glue” on the first page with the specs. And I don’t think it was a good idea to mix discusison and ordering in the first place. Maybe keep those separated for future projects?
Long story short: I can’t find the discussions about it - could you provide me with a link to it?
The last message from TK said it wasn’t clear if it will be glued or not. See:
And judging from what Bluzie wrote in the TLF, he isn’t aware of the tail cap getting glued either. He wrote for the latest prototype he received (translated from his post here: Lumintop FW3A - Diskussion - Neue Bilder - Wahl des LED Typs | Taschenlampen Forum):
I just asked in the TLF discussion thread about it - interested in their answer.
And I really hope there will be an option to order it without glue in the tail cap like for the E07. I really hate glue in products with a passion.
Use the “search within the thread” button. Post #1124 from The Miller.
I agree that info should be in the specs
I am not sure, but that seems to be about glue on the head only(?) We are talking about glue on the tailcap.
Jason is correct. It has been talked about previously in this thread that the light would not work correctly without the clip.
Do I remember exactly where that was discussed? Nope.
If I can find it without to much trouble I’ll post a link.
But I have read every post & it has been discussed.
That is why there has been the “back and forth” about gluing the tailcap.
Where is the buyer list ? Just want to make sure I’m on it. Thanks
In my testing, it works fine without the clip. The clip isn’t even held tight, which is why there’s an extra O-ring there to keep the clip from spinning freely. What Bluzie saw was probably caused by the driver fit issue, not the clip.
I don’t really recommend removing the clip, but it shouldn’t cause any functional issues. It’ll just roll easily, and it leaves a gap which people might want to fill with a thicker O-ring or something.
Anyway, I thought these were meant to be production samples, but it seems they’re not. However, the optic and LED types should be easy to fix by simply waiting for the parts to arrive. The only actual issue I’m concerned about now is making sure the driver can fit into the spot it’s meant to go in, instead of resting on top.
It is meant to fit like this. This is good:
But what I found on mine was this. This is bad:
It can be fixed by removing a little bit more material from one specific spot inside the pill. Even if they’ve already manufactured and anodized the parts, it’s a thing which could still be corrected without throwing the parts away, since that part isn’t supposed to be anodized anyway. And it was done correctly on earlier prototypes, so I think they’ll be able to get it right.
Okay, thanks for confirming that it works. I was just really confused by the argumentation why this should not work (the clip acting as a spacer). Still hoping that glue for the tail cap is opt-out at least if it will ever make it into production lights.
Wow, okay, that’s worse than I initially thought it would be. Kind thought it would just not be able to touch the shelf completely, but that is really bad. I really would have thought they would notice that while assembling the prototypes. oO Thanks for the drawing!
Interested.
Well that is even better. I was remembering that the clip was essential for the proper spacing.
So the reason Lumintop wants to glue the tail is just to keep the switch parts from falling out since there is no retaining ring?
I wonder if they could put a dab of glue on the switch pcb instead of the cap threads? Maybe it would effect the contact between the pcb and the cap? IDK.
