OSRAM CSLNM1.TG & CULNM1.TG 1mm², CSLPM1.TG & CULPM1.TG 2mm²
So would you have to cut the reflector base down to lower it for the D1 to Focus better? Or raise the LED into the reflector?
I think it is really an issue with the shape of the reflector not being parabolic, unfortunately. As it is now, when looking into the reflector from far away, the inner part (2-3mm) is not lit up. But it is not behaving as other reflectors do when adjusting the height, in my experience. I can’t get the inner and outer parts to reflect the LED light forward at the same time, at any height.
The result is still not terrible. Based on some frontal area estimations, I think the focus problem allows only 80% of the frontal reflector area to be used, for this LED. With the D1S I estimated the reflector to have 1270mm^2, and I got around 240kcd at 7.5-8A. the D1 reflector I estimated to have 530mm^2 and so I would expect to get 100kcd, but I’m only getting around 80kcd.
Hmmm. I’m having an issue but with a different light, an ArmyTek Doberman, the reflector is amazingly deep, and is sitting on the mcpcb, terribly out of focus, maybe their way of de-focusing the XP-L with it’s shitty corona. Shimming up only makes it worse, no matter what LED I have tried so far.
With my GT Mini and White Flat I had to set it directly on the MCPCB and trim the base slightly to get it to focus. I also had to trim the edge of the base slightly so it would not interfere with the solder joints for the leads, and coated the leads with tape as to not short out the light. I got a nice pencil beam - then I showed it to my uncle and he wanted it badly, so I gave it to him!
The reflector was sitting on the mcpcb, no issues with contacts I installed a larger 20mm board. I would have to cut the bottom off the reflector or pillar the LED into the reflector. I have done this before, but I hate dusting up a reflector. This is my 9th Flat White build ( well would of been) and this reflector is not made for this emitter, plain & simple. :smiley: So I put a LH351D-W6 5000k in it for 1780lm and done.
How about blackening the centering ring, and everything else but the refelctor, with a felt tip pen?
The reflector is sitting on the mcpcb, (no centering ring) which is white, I did run a black Sharpie over it. :+1: The Doberman came with out a centering ring, the reflector has 2 outer support rings that are relatively tight to the head’s inner diameter, so centering is tight, just the reflector to me isn’t right to focus even on domed LED’s let alone dome-less LED’s. But the W6 is putting out some pretty impressive lemons, and it’s fair to midland when using it outside, so I’m done wasting time on it. :smiley: But thanks anyway’s!
What gasket did you use for the l2 and what did you do for focus?
Removed gasket. Just one layer of kapton tape around led to not scratch MCPCB with reflector. Reflector sitting on that. Wires soldered insane flat. Reflector bottom sides grinded a bit to clear wires.
Oke and centering just twisting the bezel?
Yes but it needed to put some tape one side of the head inside to push the reflector sideways.
I asked Simon from the convoy store if he could get some gaskets made for 9mm reflector hole and he said could.
(1mm² led)
What should be the inner diameter of the hole inside the gasket?
Which reflector is this for? We really need some centering rings for the Osram Flat Whites to fit the L2, C8 and S2’s. Hoop is supposed to be making them but haven’t heard anything in a month or 2. Not sure about the L2 either.
The gasket from int outdoor is for 7mm reflector.(convoy s2+ etc)
The c8 and i believe the L2 use a 9mm reflector hole.
I bought a solid tube of pom plastic and will try to make some gaskets myself. If it works out I will report here.
I talked about WF1 with Simon a week ago and he told me he will get some testing samples after chinese new year and maybe consider putting them in C8. I will help him in every way I can after my 6-7 WF1 builds conclusion and led measurements.
Sweet! Thanks. Can you communicate the dimensions of the gasket with him?
I told him to just ask me if he need any measuring. I will do it.
I would be interested in 10 or more of those centering rings. Looks like I have a few people who want me to build pocket throwers for them.
I ordered some POM plastic to make myself some gaskets. All hand work and no fancy tool avaible. Its a little to loose in the reflector but I will make some more later.
Geez, this is dedication
