New VirEnce MCPCB for E17/E21/119/144/233U
344 posts / 0 new
Bob_McBob
Last seen: 2 days 10 hours ago
Very nice!
djozz
djozz's picture
Last seen: 8 hours 38 min ago
Do I see some layers of asbestos cloth on top of the iron?
Nice work on the indium soldering!
clemence
clemence's picture
Last seen: 4 days 22 hours ago
Yes, I put asbestos cloth and then drywall on top of them for my palm rest for better control. As a side bonus it makes the iron heats faster, very effective insulator.
- Clemence
BlueSwordM
BlueSwordM's picture
Last seen: 14 hours 57 min ago
Hmm, isn’t that toxic?
clemence
clemence's picture
Because I lost my rock wool insulating brick. This asbestos supposed to be temporary replacement.
- Clemence
Rdubya18
Last seen: 11 min 22 sec ago
Well , YOU make it look easy ! Smile
djozz
djozz's picture
This is white asbestos which is the less dangerous form. As long as you don’t saw or sand the stuff, producing asbestos dust, you should be ok.
My (late) mother used to warm the croissants on top of an asbestos simmer plate on the stove. But I will more probably die from her chip pan: she never replaced the fat for 20 years, when the level got low she just added new fat.
BlueSwordM
So it’s like Beryllium Copper Big Smile
As long as I don’t saw or sand BeCu, I’ll be fine.
virencelights
virencelights's picture
Last seen: 7 hours 58 min ago
waiting for 16mm to be in stock again.
thanks.
Virence Custom Built; ArmyTek Viking Pro E21A 6500k 9080 Quadtrix, Jetbeam AAA 9080 E21A 9080 5700k, Jetbeam AAA Nichia HCRI Red Led.
TrueRMS
Last seen: 2 hours 19 min ago
If I were to solder 4 nichia 119’s onto an VR21SP4 would they be spaced correctly for a Carclo quad or because of how the LED’s will center on the pads will the led to optic cone spacing be wrong?
clemence
clemence's picture
No, they won’t fit Carclo quad. But you can do it with E21A. They still produce great beam although placed offset from the optic center
[Clemence]
Agro
Agro's picture
Last seen: 10 hours 36 min ago
Clemence, have you considered making 3×3 E21A MCPCBs? Would be expensive but compatible with 7070 optics (aside from low height) and producing a lot of high quality light. Smile
clemence
clemence's picture
Yes, this is in my to do list since last year
[Clemence]
Agro
Agro's picture
Smile
SKV89
Last seen: 4 hours 13 min ago
4×4 E21A would be better Big Smile
JaredM
JaredM's picture
Last seen: 48 min 39 sec ago
Clemence, would taking pre-orders for future products in your store help with speeding up development time? If so, I would gladly pay ahead for some 3×3 E21A along with Carclo triple compatible e21a boards.
Just a thought. Excited for what your doing! Keep up the good work! Big Smile Thumbs Up
clemence
clemence's picture
Jared, it will need hundreds of pre-orders to fuel a single MCPCB model.
[Clemence]
The_Driver
The_Driver's picture
Last seen: 4 days 19 hours ago
Please make a E21A pcb for the BLF Lantern!
clemence
clemence's picture
Max current? voltage? Diameter?
[Clemence]
The_Driver
clemence wrote:
Max current? voltage? Diameter? [Clemence]
I asked the designer of it here
Total current is 4.9A, so 0.6125A per LED (two strings of four LEDs are in parallel, so there needs to be a bit a tolerance for the max current per LED). Generelly it's very low powered.
I bet quite a few people might be interested in this. The interest list for the lantern alrrady has over 2000 entries!
clemence
clemence's picture
For lantern with no directional beam needed, I suggest 757 LEDs. Depending on the space available you can populate lots of them to get very high efficiency at much cheaper price. The options are.
A.
NF2W757GV3F1:
- R8000: 2000K, 2200K, 2700K, 3000K, 3500K, 4000K, 4500K, 5000K, 5700K, 6500K
- R9050: 2700K, 3000K, 3500K, 4000K, 4500K, 5000K, 5700K, 6500K
Note: $0,1/pc. Very efficient at extremely cheap price
B.
NF2L757GF1:
- R95: 2700K, 3000K, 3500K, 4000K, 4500K, 5000K
NF2W757GF1:
- R95: 5000K
Note: $0,3/pc. Priced very close to Optisolis, CRI slightly higher than R9080 unlike Optisolis, they can be mixed freely
C.
NF2L757GF1 (Optisolis):
- R95+: 2700K, 3000K, 3500K, 4000K
NF2W757GF1 (Optisolis):
- R95+: 5000K, 6500K
Note: $0,5/pc. CC and WW can’t be mixed in parallel. Currently, the highest possible CRI for LED
D.
NVSLE21AT
- R9080: 2000K, 2200K, 2700K, 3000K, 3500K, 4000K, 4500K, 5000K, 5700K, 6500K
NVSWE21AT
- R9080: 5000K, 5700K, 6500K
Note: $1/pc. The most efficient and expensive compared to A ,B, and C. Light quality slightly lower than B
[Clemence]
contactcr
Last seen: 2 hours 45 min ago
It should be noted, for this purpose, that it’s max 2.34A (7*7135) per channel and that is with all solder bridges connected. The factory default will likely be even less:
You can add/remove the solder bridges to enable/disable current. He could even add more LEDs to reduce current per LED as long as it’s symmetrical.
contactcr
No point doing A) since it will come with Samsung LH351D 90CRI 3000K and 5000K
C) wont be a problem I guess cause it has 2 separate channels
Tally-ho
Tally-ho's picture
Last seen: 2 months 5 days ago
To increase current : 7135 piggyback
SKV89
A.
NF2W757GV3F1:
B.
NF2L757GF1:
NF2W757GF1:
- R95: 5000K
C.
D.
NVSLE21AT
NVSWE21AT
[Clemence]
I would be interested in a new board but only if it is E21A because the E21A comes has the famous 9080 2000k option that can mimic candle light. Since the other options only go down to 2700K, it doesn’t add much more to the stock 3000K to 5000K LH351D 90CRI, despite the Optisolis has superior color rendering.
The_Driver
SKV89 wrote:
I would be interested in a new board but only if it is E21A because the E21A comes has the famous 9080 2000k option that can mimic candle light. Since the other options only go down to 2700K, it doesn't add much more to the stock 3000K to 5000K LH351D 90CRI, despite the Optisolis has superior color rendering.
Exactly! The 2000K 90CRI+ with tint on BBL (!!!) variant is the main reason. 6500K for the other end of the spectrum makes it "perfect" and the tint more reddish.
Cost will be high either way because of shipping, the board etc.
staticx57
Last seen: 43 min 55 sec ago
Just be careful, this has positive and negative reversed on the silk screen. It is common positive but common negative.
ma tumba
Just wanted to share. I put a single 6500k optisolis into an ultrafire u-f10 which is a cheap but very high quality aspherical. The goal was to have a perfectly uniform wide beam: more uniform and more concentrated than that of a mule. Works GREAT
adam7027
A.
NF2W757GV3F1:
B.
NF2L757GF1:
NF2W757GF1:
- R95: 5000K
C.
D.
NVSLE21AT
NVSWE21AT
[Clemence]
A: probably not enough Rf (and R9) for extra ‘warm’ CCTs, otherwise similar to 351D offerings (more available CCTs though)
B: would be very tempting for making a tint mix between 2700K and 4500K
C: too bad, that no tint mixing is possible between ‘L’ and ‘W’ group – some people would find 2700K to 4000K tint mixing a bit narrow
D: probably the best option – would let very useful tint mixings to happen (more than one) – a mood variant with 2000K to 3500K, and a base variant with 2700K to 5000K
If DBSAR would make Sofirn to have Nichia variant of BLF LT1, that would be awesome (probably I would just buy those).
clemence
clemence's picture
I think its better to just make the lantern as designed. We can always start a GB for this MCPCB with poll later. I need at least 300pcs committed order to make it
Is the lantern still far from realization?
[Clemence]
