New VirEnce MCPCB for E17/E21/119/144/233U
Yes, I put asbestos cloth and then drywall on top of them for my palm rest for better control. As a side bonus it makes the iron heats faster, very effective insulator.
- Clemence
Hmm, isn’t that toxic?
Because I lost my rock wool insulating brick. This asbestos supposed to be temporary replacement.
- Clemence
Well , YOU make it look easy ! :slight_smile:
This is white asbestos which is the less dangerous form. As long as you don’t saw or sand the stuff, producing asbestos dust, you should be ok.
My (late) mother used to warm the croissants on top of an asbestos simmer plate on the stove. But I will more probably die from her chip pan: she never replaced the fat for 20 years, when the level got low she just added new fat.
So it’s like Beryllium Copper :smiley:
As long as I don’t saw or sand BeCu, I’ll be fine.
waiting for 16mm to be in stock again.
thanks.
If I were to solder 4 nichia 119’s onto an VR21SP4 would they be spaced correctly for a Carclo quad or because of how the LED’s will center on the pads will the led to optic cone spacing be wrong?
No, they won’t fit Carclo quad. But you can do it with E21A. They still produce great beam although placed offset from the optic center
[Clemence]
Clemence, have you considered making 3x3 E21A MCPCBs? Would be expensive but compatible with 7070 optics (aside from low height) and producing a lot of high quality light. :slight_smile:
Yes, this is in my to do list since last year
[Clemence]
:slight_smile:
4x4 E21A would be better :smiley:
Clemence, would taking pre-orders for future products in your store help with speeding up development time? If so, I would gladly pay ahead for some 3x3 E21A along with Carclo triple compatible e21a boards.
Just a thought. Excited for what your doing! Keep up the good work! :smiley: :+1:
Jared, it will need hundreds of pre-orders to fuel a single MCPCB model.
[Clemence]
Please make a E21A pcb for the BLF Lantern!
Max current? voltage? Diameter?
[Clemence]
I asked the designer of it here.
Total current is 4.9A, so 0.6125A per LED (two strings of four LEDs are in parallel, so there needs to be a bit a tolerance for the max current per LED). Generelly it's very low powered.
I bet quite a few people might be interested in this. The interest list for the lantern alrrady has over 2000 entries!
For lantern with no directional beam needed, I suggest 757 LEDs. Depending on the space available you can populate lots of them to get very high efficiency at much cheaper price. The options are.
A.
NF2W757GV3F1:
- R8000: 2000K, 2200K, 2700K, 3000K, 3500K, 4000K, 4500K, 5000K, 5700K, 6500K
- R9050: 2700K, 3000K, 3500K, 4000K, 4500K, 5000K, 5700K, 6500K
Note: $0,1/pc. Very efficient at extremely cheap price
B.
NF2L757GF1:
- R95: 2700K, 3000K, 3500K, 4000K, 4500K, 5000K
NF2W757GF1:
- R95: 5000K
Note: $0,3/pc. Priced very close to Optisolis, CRI slightly higher than R9080 unlike Optisolis, they can be mixed freely
C.
NF2L757GF1 (Optisolis):
- R95+: 2700K, 3000K, 3500K, 4000K
NF2W757GF1 (Optisolis):
- R95+: 5000K, 6500K
Note: $0,5/pc. CC and WW can’t be mixed in parallel. Currently, the highest possible CRI for LED
D.
NVSLE21AT
- R9080: 2000K, 2200K, 2700K, 3000K, 3500K, 4000K, 4500K, 5000K, 5700K, 6500K
NVSWE21AT
  • R9080: 5000K, 5700K, 6500K
    Note: $1/pc. The most efficient and expensive compared to A ,B, and C. Light quality slightly lower than B
[Clemence]
It should be noted, for this purpose, that it’s max 2.34A (7*7135) per channel and that is with all solder bridges connected. The factory default will likely be even less:
You can add/remove the solder bridges to enable/disable current. He could even add more LEDs to reduce current per LED as long as it’s symmetrical.
