Maglite 3C mod - old school style (picture heavy)
48 posts / 0 new
Cula
Cula's picture
Last seen: 43 min 43 sec ago
Got this old banged up Maglite as a gift long time ago. Bought all supplies for modding and left them on a shelf. There it was sitting for a couple of years and this winter I decided to wake up my modding mojo and give new life to this forgotten gem.
Lots of stuff happened during these few years regarding flashlights. They got cheaper and more powerful and it became very hard to build something that you cant buy in a store with a click of a mouse.
I hope there are still members here who can appreciate this kind of work and love and effort that is put in this build. Me personally, I enjoyed every hour spent building my Maglite.
Let’s start:
Project supplies:
Maglite – gift
4xNichia 219C SM403 – 90 cri 4000K – $18 (got these from a group buy here on BLF in 2016)
LD-2 driver 12 Amps – $12
50mm Ledil Melody 4M Medium angle beam optics – $12
4x Noctigon XP MCPCB’s – $10
AR coated Lenses – $2 (from Kaidomain)
Other supplies (wires, copper, sand paper etc) – $5
1. Here is how it all starts. Old and banged up Maglite, ready to be transformed into something different. I removed anno from tailcap and bezel few years ago when I was experimenting with caustic soda.
2. First Cut. Hope my plan works.
3. 26650 didn’t fit inside. Aluminum pipe wrapped in 80 grit sand paper is used to sand the inside of the battery tube.
4. Took me an hour and a half of sanding to make it wide enough. Problem solved.
5. Removed anno.
6. Second cut. Part of the battery tube that goes inside the flashlights head will be a driver holder and a place for all the wires.
7. Made a aluminum ring to fit inside a tube and used a 17mm brass driver ring bought from Kaidomain. Everything is press fitted.
8. Like this. Two rings are going to be brazed from the inside. That will provide strength, electrical and thermal conductivity for small LD-2 driver.
9. Made a fiberglass shelf for a small electronic switch. Glued it with a drop of locktite.
10. Tailcap mod. Big old spring is going to be replaced with smaller one sitting on a copper circle.
11. 18 AWG wire brazed inside a tailcap, finished spring on a copper circle ready to be glued. No electrical resistance here.
12. Tailcap mod done.
13. Three part body polished and ready.
14. Copper pipe prepared for soldering. I’ll join these two parts.
15. Copper soldered, time to clean this mess.
16. Lots of sanding ahead of me.
17. Getting there. Smaller copper part on top of the pipe is sanded flat.
18. Made a 12mm switch hole.
19. Sanded and polished.
20. Battery tube parts all done.
21. Made a 50×1.5mm copper circle and three 50×2mm aluminum circles joined with arctic alumina epoxy.
22. Four 1.5mm copper washers to hold the optics in place. Had to get very creative to make these small parts.
23. A glimpse of a finished head. There is still lots of work ahead of me.
24. Finished heatsink parts.
25. Plenty of mass and surface to sink the heat from little Nichias.
26. Inside the head.
27. Optic washers glued with locktite.
28. Perfect fit, everything centered.
29. Nichias centered and screwed down using 2mm screws. Took a lot of patience to drill and thread all holes.
30. Inside the flashlight head.
31. Looking good.
32. All wired. Made a mistake here, I should have wired the driver first and Nichias last. I had to de solder everything and start from the driver.
33. Driver wired. Ground wire is going to be bolted to the body of the flashlight.
34. Driver press fitted in his shelf. This part of the battery tube is epoxied to the flashlights head using arctic alumina.
35. Ground wire bolted, time to solder rest of the wires.
36. Testing phase, it works. Nichias perfectly centered using a custom made centering ring. But will it deliver all 12 Amps?
37. All done! Switch is covered with a leftover button from one of my previous builds (From Shadow JM35).
38. Love the looks.
39. Men size flashlight, that’s for sure.
40. To get the perspective of the size: Maglite, Brynite B158 and Convoy S2.
41. Nichias firing. Everything works. Job done!
42. Tailcap measurements. Bit disapointed with Vappower 26650 batteries. They couldn’t deliver 12 Amps, not even a 10. But Samsung 25R, that’s a different story. 12 Amps without a sweat.
I’ll test this puppy thoroughly in a next few days and get back with my thoughts.
Did you like my mod? Please comment.
Cheers Beer
Edited by: Cula on 02/27/2019 - 06:00
Lightbringer
Lightbringer's picture
Last seen: 1 min 1 sec ago
Holy Cats!
MascaratumB
MascaratumB's picture
Last seen: 2 hours 5 min ago
Shocked Shocked Shocked
Me likes!!! Awesome work Wink
Love the mod and the description!!
Now a beamshot is required Wink
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
WillyD
Last seen: 1 month 3 days ago
A little sloppy, but I suppose it’ll do Wink
Jk, beautiful work! Love the polished copper.
nottawhackjob
Last seen: 1 week 5 days ago
Ol’ Lumens would be proud. Craftsmanship & Ingenuity.
Beautiful work.
Thumbs Up
“In many things in order to truly understand the small picture you have to understand the big picture first.”
moderator007
moderator007's picture
Last seen: 26 min 29 sec ago
Very nice work Cula Thumbs Up .
I use to build several of these mag modes. Lots of work but nothing else like it.
I never built a mag quad though, great job.
Some serious hand tool skills you got there, I especially like the copper addition. Wink
Good to see some of these old school (OL) mods here. Thanks for sharing!
djmcconn
djmcconn's picture
Last seen: 8 hours 14 min ago
Beautiful work and thanks for sharing!
KawiBoy1428
KawiBoy1428's picture
Last seen: 6 hours 50 min ago
WOW Shocked Beer Now that is incredible, what a beauty, this is innovation at it’s Finest! Love Thumbs Up
KB1428 “Live Life WOT
djozz
djozz's picture
Last seen: 7 hours 53 min ago
Yes, another incredible and shiny Cula build!! I especially like the copper section screwed in place Love .
Thanks for showing it all to us with beautiful pictures!
ChibiM
ChibiM's picture
Last seen: 16 hours 57 min ago
Very impressive!!
Venom
Venom's picture
Last seen: 9 months 2 weeks ago
Great work and great looking light.
maukka
maukka's picture
Last seen: 1 day 19 hours ago
Wow! That’s a lot of manual work and a beautiful end result.
USA
USA's picture
Last seen: 3 weeks 1 day ago
Nice mod! Or more like an entire creation. I remember your post from the Shadow mod, which was equally stunning.
jacktheclipper
jacktheclipper's picture
Last seen: 2 days 17 hours ago
Grad Beer
ImA4Wheelr
Last seen: 5 days 3 hours ago
Gorgeous creation!  So refreshing to see this build and with details. So many great modding ideas/tips in it.
I have to admit that availability of off-the-shelf, high-performance lights has dampened my enthusiasm for flashlight modding.  But this build helped remind me that there is still joy in handcrafting an entirely unique light.  Congrats Cula!
MRsDNF
MRsDNF's picture
Last seen: 15 min 44 sec ago
Did I like your mod? No.
I loved your mod. Love
Orsm effort and I have to agree with everyone else’s comments here. Well done. Beer
offline
Last seen: 7 months 1 week ago
Very cool, enjoyed the read. Thanks for sharing!
CRX
CRX's picture
Last seen: 6 min 7 sec ago
Nice work Thumbs Up
- LEDs & Other Stuff -  - UI CheatSheets -  - CRX Mods & Builds -  - Stuff for Sale -CRX Hand Made FlashlightsThe only place that fear can exist is in our thoughts of the future.
It is a product of our imagination causing us to fear things that do not presently and may never exist. Fear is a choice.
mmalive
Mr. Old – Lumens looking down from above giving props and blessings for a great MOD man.
Matchoo
Last seen: 12 hours 12 min ago
wonderful and inspiring project!
Cula
Cula's picture
Thank you guys for your kind comments Beer
Didn’t get a chance to test this Maglite thoroughly yet but as soon as I do I’ll post my observations.
Hoop
Hoop's picture
Last seen: 2 weeks 3 days ago
Nice work Cula. Looks real good. Thumbs Up Love mag mods!
Cula
Cula's picture
Tested it thoroughly during a last few days and it meets all of my expectations LOL . Left it at the full throttle for 3 min and then stopped (at room temperature, no air flow), didn’t want to push it any longer. It can handle the heat coming from the emitters, like all of my builds. It is basically a flodder with a very smooth beam (at white wall).
Failed miserably at making a photos of the beam, like I always do Facepalm .
Thanks again for your comments.
I’ll probably sell this one soon and start a new project. It would be a shame to let this Maglite sit on a shelf unused. That happens to most of my flashlights.
Cheers Beer
ARC
Last seen: 2 months 3 days ago
Really nice mod, always have a soft spot for magmods i must get round to making some of my old maglites mine a little bit better too Smile
Slayer1
Slayer1's picture
Last seen: 18 min 57 sec ago
Welcome back Cula! Awesome work as usual. Thumbs Up Beer
DavidEF
DavidEF's picture
Last seen: 1 week 1 day ago
Awesome build! I somehow missed this one. The buyer is gonna have fun with this beautiful work of art!
- The YKK Philosophy
Hugh Johnson
Hugh Johnson's picture
Last seen: 5 days 14 hours ago
Beauty.
DB Custom
DB Custom's picture
Last seen: 1 day 17 hours ago
Looks very nice, feels good to get results after all that hand work doesn’t it? Wink
Marc E
Last seen: 1 day 4 hours ago
Much respect both for your skills and your decision to see it through, and while money might buy better performance it can’t buy the sense of accomplishment i hope you feel with this build.
DB Custom
DB Custom's picture
Just curious, did you use the Arctic Alumina Thermal Adhesive to glue the threads between the head and driver section? If someone tries to turn the head off it will twist the wires….
Cula
Cula's picture
Thanks again for your comments Beer
Yes, Epoxied permanently (arctic alumina).
