Watched it a few times, not 100% sure but in that youtube clip on HKequip page it looks to me like there is a click stop at the off position and at the high position. well I hope to have mine very soon and will let you know.
Oh good so no pocket turn on then. Yep, I’ll let you know.
Another control ring light that will get you shot at the other forum is the Niteye Zip20, also Niteye had a few other control ring lights, not small tho - Niteye12 &15, Niteye MSA10 & MSC20, Eye30 & Eye40 - then I think it became Jetbeam stuff, RRT26 & RRT-3 etc.
The first control ring light that I can remember (and I owned one and it was on CPF) and can’t remember the name but was made by a guy that eventually disappeared with peoples $$ as they were a little buggy - you twisted the control ring 1/4 of a turn and it sprang back each time to change the levels, it was space age magic at the time somewhere around 2006/7ish I think.
Was it the same product from the same guy that rumoured to be copied irresponsibly by Niteeye? I remember CPF encouraged it’s member to boycott Niteeye. The clone was later pulled off the market. AFAIK the model looks similar to the now super expensive coolfall jewelry. Correct me it I’m wrong.
You are right it was coolfalls 007 light - it wasn’t so much that it was copied as everything out there is copied eventually, it was that niteye didn’t ask if they could or pay royalties to coolfall - but hey they are almost all sold out of the 1000+ made.
You said he ran with people’s money. Did you mean the original maker or Niteeye? I never knew that part.
Looks like now he (coolfall) has established with good reputation.
Oops no no not niteye that did a runner, it was the light with a magnetic controller ring I can’t remember the name of it - it was a one of a kind, he was making a MKII and that’s where he and the $$ disappeared. Trying to find it but couldn’t on CPF, think it’s on CPFmarket place that is now gone.
Just remembered another light I wanted but didn’t get when I could now can’t, the Sunwayman M25C Ti.
AAAAAAH! thats it I had a brain fart it was Neofab, bringing out the Legion II was when he disappeared, a few got one and most didn’t.
It’s here and here
Amazing how times have changed. A 742 otf lumens custom light back then used a (MC-E) quad emitter, 3 18650’s and a large host, the Worlds brightest single led flashlight.
Now a off the shelf Wuben E05 will do 900 lumens from a single 14500 with a single emitter and is about the same size as one 18650. Olight S1R II does 1000 lumens from a 16340 making it even smaller. What will the future bring?
Thanks. I can appreciate stability being important, as a visible drift after setting the brightness would be seriously annoying. I’m guessing that the emitters are carefully chosen for the magnetic control ring interface driver so that it’s very stable. Curious to see if that means a limited emitter choice results, and if at least a couple higher CRI emitters are within that range.
With microprocessor miniaturization, there would be some physical limits that are ultimately unable to be crossed (e.g. atomic level). The progression curve on increased processing power curve has started to lessen. I’m very curious to know if a similar kind of physical threshold limit awaits LED emitters, given the visibility aspect. Heat is still a difficult limiter to master. Perhaps some other composition will be discovered that can result in an LED emitting even more light with less heat.
It sounds odd because it’s a perfect fit for my RRT01 old version and aspire 18350 1100mAh. The battery has small side rattles when inserted in the battery tube and stop rattling when both parts are assembled. :+1:
It’s becoming more challenging for sure. I modded a Ultratac A1 running a boost driver (mtn-bst2) with a single 14500 with a xhp50.2 making right at 2000 lumens. So there is still some room left for improvement. The heat is becoming the challenging part. The electronics seem to be passing all the other obstacles. The GXB172 driver is another fine example.
the reason the flat top battery does not work is that the head of the RRT-01 has a physical reverse polarity protection, a raised white plastic ring around the positive post in the head. The ring is preventing the flat top from reaching the positive post.
A small magnet would solve the problem, to extend the flat top so it makes contact. However, I have never tried using a magnet, Ive only read about it online. Others report solving the problem with a blob of solder on the battery… never tried that either, myself.
My concerns about a magnet is that neodymium can catch fire, and that it loses magnetism when it gets hot. My solution is to buy a battery that works, the 1200mAh 18350 Keepower. Or I use 16340 cells.
No the Original turned the Opposite way, Right Hand Threads to tighten the Head and the Ring turned to the Right for more Brightness which was the opposite direction iirc?
MascaratumB
Thank You for the Heads Up.
This light looks like it’s a Larger Diameter than the old style. With the Ring turning the other direction I Don’t know if I could get use to that very easily? My Sunwayman Rotery Lights turn to the Right for More Lumens Like the Old style JetBeam. That would take some getting use too. But it still looks Good.
It is odd but true mate!! :weary: I tried it a lot of times and I couldn’t get the Aspire or the Keepower 750mAh to work on the old RRT01 I got from you :zipper_mouth_face:
It really has to do with this:
I believe that if I “shave” that plastic ring or if I put a small disc on the top of the batteries, it will work, but so far I couldn’t make them “light the light”!
I am using an OTR 16340 700mAh in it!
Sorry about that last post showing up So Late I previewed what I had typed then pressed Save, But apparently it didn’t post until Just Now?
The Light does look good and it’s Sure to have some Nice UpDated features.
