TK's Emisar D4 review
5353 posts / 0 new
sbslider
sbslider's picture
Last seen: 14 hours 54 min ago
sbslider wrote:
iamlucky13 wrote:
Cpeng wrote:
At direct drive the FET isn’t burning off any voltage, you really can’t get any more efficient then that (at the same current level) with a buck boost because now you have an inductor in series with the LED in addition to a FET, (unless you have a bypass FET). I would like a buck boost, but peak power is kind of the selling point of an Emisar D4. My use case doesn’t require longer run time and I’ll take my zebra if I do require it. I’m not going to say that its worthless to develop a buck boost D4, and I would probably buy one, but I wonder what I would have to give up in size, brightness, etc.
I’m not an electrical engineer, but I would think eliminating the forward voltage of the FET would provide a significant improvement efficiency. For the D4, I see the number “09NE2LS5” on the FET. From the datasheet I found on that, it looks like it is 0.78V at 30A. This one, like most FETs, shows only minimal improvement in that Vf at lower currents – roughly 0.7V at 4A.
I’ve found the efficiency of the D4 generally fine for my needs though. I wouldn’t view improving further as a high priority.
Eliminating the forward voltage of the FET would definitely improve the efficiency, but the FET is the controlling element for lower light levels also.
A quick web search showed me a FET with 12milli ohm, 50A rating in the package used on the D4. FETs are like voltage controlled resistors, but once they are “on”, they are a fixed resistance. So 0.012V * 30A is 0.36V, and 0.012*4A is 0.048V. Not sure where the measurements above are measuring, but it seems like there is a fixed resistance in series with the FET being measured which is why the voltage does not change linearly with the current. Or, somehow at lower currents the FET is not being fully turned on at the 4A current. If the measurements include PWM and are being done with a digital volt meter, then all bets are off as to the accuracy of the voltage measurement.
Oh, and I am an electrical engineer, but I don’t get to play that role much these days, more of a project lead now. It’s fun to go back and frolic in the math now and then. Big Smile
This has been bugging me since my last post, finally got back to look at this. I realized that you posted the part number and quoted the data sheet, while I quoted a different random data sheet. The part number listed is actually much better than the one I found.
I did not find the data you quoted (on voltage versus drain current), but diagram 6 (on page 8 of the linked data sheet) does plot the resistance of the part versus current from 0 to 50A (part is rated to 100A constant, 400A peak!!) The resistance is very flat for a given gate bias voltage, but does vary for different gate bias voltages. Since the D4 does not have a power converter in it, the gate bias voltage can be no higher than the battery voltage. So the on resistance is like best case about 0.001 ohm (1 milli ohm) but does not vary with the drain current.
I am not posting this to say “I told you so”, but more just to clear um my own thinking on this, and share those thoughts with others who might be interested. Beer
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
vresto
vresto's picture
Last seen: 20 hours 1 min ago
why to choose sst 20 version? what is really better with this led?
EDC-Amutorch X9 XHP50 nw,Sofirn If-25A cw
Headlamp-Thrunite TH30 nw
lionheart_2281
lionheart_2281's picture
Last seen: 1 hour 22 min ago
CRI
Firelight2
Firelight2's picture
Last seen: 1 hour 24 min ago
I played around with my SST20 4000K 95 CRI D4 last night and compared it to my XPL HI D4. My impressions of the SST 20:
  • It is possibly very slightly throwier on a full cell at full power. I didn’t verify with my luxmeter though.
  • It puts out a lot less light than XPL HI. The hotspot might be marginally brighter, but is a lot narrower than the D4.
  • I suspect SST20 draws more current than XPL HI. With the SST20, the head got hotter noticeably faster.
  • Output also dipped a lot faster than with XPL HI. The thermal sensor kicked in to reduce output within 10 seconds. With Anduril installed, and XPL HI I could set my Titanium D4 with bare polished aluminum head (pretty much the worst possible heatsinking combo for a D4) at a max ramp setting of 46 clicks. The light would take quite awhile to ramp down. When I swapped in SST20, I had to set the max ramp at 51 clicks and even then the head still got hot and ramped down within 20-30 seconds or so.
  • My battery voltage depleted noticeably faster with SST20, also suggesting that it draws more current. Run the SST20 D4 for 30-60 seconds at turbo with rampdown, then let it cool and turn it on next to an XPL HI version and even the hotspot of the SST20 is noticeably dimmer than XPL Hi.
  • At all lower and intermediate power settings the SST20 displayed an unpleasant greenish tint. The tint is definitely above the black-body line. I found lower power on my XPL HI D4 to be much more pleasant and didn’t look greenish. This is a shame, because at turn-on on max-turbo the green isn’t evident and the beam looks great.
Having tried the SST20 4000K 95 CRI side-by-side with 4000K 5D XPL Hi, I have now concluded that XPL Hi is much superior. The benefits of higher CRI and lower cost from the SST20 are massively outweighed by the XPL Hi’s benefits of better color temp, higher peak output, higher sustained output and longer battery life.
Nev
  • I suspect SST20 draws more current than XPL HI. With the SST20, the head got hotter noticeably faster. Output also dipped a lot faster than with XPL HI. The thermal sensor kicked in to reduce output much faster. Within Anduril installed, and XPL HI I could set my Titanium D4 with aluminum head at a max ramp setting of 46 clicks. The light would take quite awhile to ramp down. When I swapped in SST20, I had to set the max ramp at 51 clicks and even then the head still got hot and ramped down within 30 seconds or so.
  • At lower power settings the SST20 had a noticeable unpleasant greenish tint. The tint is definitely above the black-body line. I found lower power on my XPL HI D4 to be more pleasant.
I agree ,that’s what I thought, it’s still very nice though ,I probly would of kept the sst if I didn’t compare it to the XPLHI.
Mike K
Last seen: 1 day 32 min ago
Thanks Firelight2! That helped me a lot on deciding between the two. Smile Thumbs Up
vresto
vresto's picture
Yes for mé the same
BlueSwordM
BlueSwordM's picture
Last seen: 5 days 12 hours ago
Nah, use the light outside and you’ll see why higher CRI is always better.
Also, don’t forget the SST-20s high CRI have a lower forward voltage than the XP-L HIs, so more current is consumed.
And it’s also going to last longer on regulated modes because of this too.
Nev
it is nice outside but I prefer the XPLHI.
sbslider
sbslider's picture
I disagree. Vf has nothing to do with battery power consumption on regulated modes. The battery voltage appears across both the current regulator and the diode. If the regulator is working, the current through the regulator is fixed. Battery power is simply battery voltage times regulator current. If the diode Vf is higher, more dissipation in the diode, less in the regulator. If the Vf is lower, less dissipation in the diode, more in the regulator. I would argue the diode can handle the dissipation better then the regulator. If Vf went to zero or very low, one would burn up those little regulator chips pretty quick, as they have no real heat sink.
Firelight2
Here are some factors in how useful and pleasant I find an LED’s output to be, in order of importance (in my opinion):
  • Output – measured in lumens. The purpose of a flashlight is to illuminate something. Shear output matters a lot. A light with 100 lumens just doesn’t have as much punch as one with 500. What’s the point of having a light with fantastic color temp, tint and CRI if it’s not bright enough to illuminate what you want it to?
  • Intensity – measured in lux. or lumens per fixed unit of surface area. An LED with higher intensity has better throw. Important for some applications.
  • Color Temperature – warm, neutral or cool white. Different people have different preferences. I find 4200-4300K to be ideal, but will accept anything 4000K-5200K.
  • Tint – above or below the black body line. Tints above the black body line tend to look greenish, those below look rosy. Most people, myself included, find rosy tints to be better.
  • CRI – how well the light represents color at the given color temperature and tint. Most neutral tint LEDs are 70-80 CRI. High CRI LEDS tend to be 90+. I can immediately tell the difference between a 65 CRI and 90 CRI, but when it comes to neutral tints I find that I can only tell the difference between 80 CRI and 95 CRI if I hold the two lights side-by-side and compare beams. Because, CRI is so subtle I find it to be by far the least important of the 5 factors when it comes to picking a light. I’d much rather have 80 CRI with beautiful tint, than 95 CRI with horrible green tint. I find CRI without good tint to be pointless.
sbslider
sbslider's picture
Thanks for the feedback, I was considering trying out the SST20 in my D4. Might still some time, but not in nearly the hurry now.
Pöbel
Pöbel's picture
High CRI always comes at the cost of efficiency. So your findings are true and they were predictable.
If cri is not important for you the lower cri SST20 LEDs would have been a much better candidate as they are way more efficient while rivaling the XP-L HI in output and beating them in throw.
I personally prefer High CRI but dislike the green in the SST20 4000k variety.
djozz
djozz's picture
Last seen: 4 hours 49 min ago
Running some very rough numbers with lots of assumptions gets me this:
  • D4 SST-20 6500K, spec’ed at intl-outdoor at 4200lm. That is 1050lm/led, so about 1280lm for the bare led, which is at 86% of max and they run at about 4.5A per led.
  • D4 XP-L Hi, spec’ed at intl-outdoor at 4300 lumen, that is 1075lm/led, so about 1310 bare led lumen, which is at 62% of max, and they run at about 4A per led.
So the XP-L Hi version runs 2A less in my calculation while putting out a bit more light. The experiences above suggest a larger current difference though, so something is off, perhaps int-outdoor’s specs or my numbers Silly
Firelight2
Regardless of CRI I find the SST20 to be much worse. In my D4, the SST20 is noticeably inferior for my needs in the most basic test: output.
  • The SST20 D4 ramps down much faster than my D4. I like burst modes, but in the D4, the SST20 starts out with a slightly brighter hotspot, but within 10 seconds of turn-on it is already much dimmer than a D4 with XPL HI.
  • SST20 might be more efficient, but what’s the point if I’m not able to take advantage of that efficiency and see results in-use because of the higher heat generated.
  • I hate greenish tinted lights. I find tint of the SST20 at anything less than max turbo to be unacceptable.
Firelight2
My modded D4 looks pretty, but has the worst possible configuration for heat management. It is more susceptible to rampdown from overheating than probably any other D4:
  • Polished Bare aluminum head (not as good as copper at transmitting heat and can’t hold as much as copper. Shiny bare aluminum has lower emissivity than dark anodized aluminum).
  • Titanium body tube and bezel (not as good at transferring heat from the head as aluminum.
It is possible that a stock aluminum D4 wouldn’t see such an extreme difference in results.
Pöbel
Pöbel's picture
yes, of course. Sans the tint these are direct results of the High CRI variant being considerably less efficient.
Your reasoning that these are not a good choice for your needs is sound.
I was merely saying that this outcome could be expected and people should only choose high cri if they appreciate the better cri so much, that they are willing to accept the impact in virtually any other area of LED performance.
Firelight2
Agreed.
For those who absolutely must have high-CRI in their flashlight and who don’t care about other factors, the SST-20 is a good choice. It offers considerably higher output at high-CRI than most other LEDs on the market.
It might also be a great choice of emitter for small single-cell throwers like the D1 or D1s. With only one emitter, plus more thermal mass, those lights are much more likely to be run at max power. And max power before rampdown is where the SST-20 truly shines.
DB Custom
DB Custom's picture
Last seen: 3 weeks 6 days ago
I had gotten the high CRI SST-20’s in my E07 due in part to no additional cost and planned on replacing them anyway. I got a Manker E14 today with 2 ruined Nichia emitters and so I replaced the Nichias with 4 of these 20’s.
At low output the green is excessive. At higher power level it clears up quite nicely. On a VTC5A it pulls around 50A at the tail. Pretty big draw on these small emitters! Not that Luminus emitters are known gor high efficiency…
Definitely a tighter beam that part is welcome, lower modes are virtually useless for me though.
BlueSwordM
I wouldn’t say excessive.
It’s extremely hard to find emitters that have good rosy tints below 350mA for LEDs* due to how photon emission at different wavelengths work, but it depends on the tech used in the LED and the tint bin.
Basically, the tint shifts to green at low currents in LED emitters since the blue light emitted from the die can be more efficiently converted to green compared to red colors.
It gets better for high CRI LEDs and lower CCT LEDs, but the problem still presents itself. The closer you are to perfect color reproduction(akin to the sun), the less this issue arises at lower levels.
That’s why at the same color temp and same tint curve deviation, an SST-20 4000k 95CRI can look better in the tint department compared to an LH351D 90CRI.
*That only works for LEDs. For HIDs, and incandescents, it’s the complete opposite. The LES gets rosier as the power draw gets lower.
chadvone
chadvone's picture
I notice a little green in my SST-20 4000k 95CRI when next to my 5000k XP-L Hello.
On its own I don’t notice any. My mind could be blocking it, like a bad experience.
DB Custom
DB Custom's picture
But I DID use the word excessive because I do NOT like what I shine a light on to look green. Not our brownish cream colored floor tiles, not our beige carpet, not my son or anything else I look at. Green is an absolute no go for me, period and end of that story. So this E14 that just came today will get the emitters swapped again ASAP tomorrow.
All 7 of the SST-20’s that I removed from my E07 will be in the trash probably less than 12 hours from now. (as it’s bedtime here and I have something that I have to take care of first thing in the morning)
Edit: For reference I ordered my E07 with 5000K NW SST-20’s
BlueSwordM
I think our eyes are just different, or perhaps the tints of certain LEDs are just worse than others even in the same tint bin.
DB Custom
DB Custom's picture
Don’t forget, I’m a photographer and I deal with processing colors correctly in a very big way. Thousands of pictures at a time from a full frame Canon sensor on a professional Dell monitor that’s color corrected. Proper color is very important to me, it’s a way of life.
chadvone
chadvone's picture
Green is a no go for me also.
My 4000k don’t make my kids look green Smile
BlueSwordM
@DB Custom, ahhh.
You didn’t say you had 5000k 65CRI SST-20.
These actually have slightly worse color rendering than even XP-L HIs.
The 95CRI 4000k SST-20s are another completely different world.
DB Custom
DB Custom's picture
A photo of my daughter, printed on Kodak Metallic Paper at 24×36. These pics taken moments ago with my i8 locked at 4352K and with 2 lights at approx the same output. Bet it doesn’t take you much of a guess as to which one I’ll be throwing the emitters away…
FWIW, the emitters in both lights are 5000K
BlueSwordM
Holy crap, these are the greenest emitters I’ve ever seen.
These look almost as bad as XHP50.2/XHP70.2s.
Luminus really should’ve made 5000k 95CRI SST-20s, huh, or even 5700k?
DB Custom
DB Custom's picture
Luck of the draw perhaps. But yeah, they didn’t stay in my E07 very long at all. The nice tint, on the left, is the E07… with LH351D 5000K W6 emitters.
Beam profile is nice, Turbo tint is nice, but at lower output level just a fail on an FET driver. Maybe I’ll try em on Neven’s regulated driver and see how that goes, probably the same though…
DB Custom
DB Custom's picture
I ordered the 4000K 95 CRI SST-20’s in the PL47, didn’t like those either, gave the light to my Son-in-Law for Christmas. Wink
