Last night I got an SST20 4000K 95 CRI Emisar D4. Promptly swapped its star into my modded aluminum-titanium D4.
After testing it and playing around with it, I concluded that the SST20 was considerably inferior to XPL HI for this light, so today I swapped the old star back.
Sorry! Just finished it but Iām at work in night shift. When I get home the sun is up. When I leave home the sun is up too. So I need to wait sunday night because that day I finally staying home.
The dedomed XP-G2 S4 2B done 300kcd what I removed now.
Instead, it was my day off today, so I got round to testing a led tint for TA, swapping main led and switch leds in a Sofirn SC31, and just tonight swapping in a Luxeon V led in a small Supfire 16340 light that was modded before with BLF-A6 driver, spring bypass and colour-changing tail. It is now a pocket rocket waiting for that new ultra-high current 16340 cell that Vapcell was trying to source for us.
In the meantime I bought two cheap Enercig 16340 cells from NKON that are rated at ā14Aā on the website. I asked Arjan (from NKON) if that was a typo (because his Enercig 18350 cells were also rated ā14Aā) and he answered that it was just the information he got. I got them in today, and without being able to test them like HKJ does (they do measure 715mAh on the Opus ), I easily got 1160 lumen out of the little Supfire with one.
I put a 3500k XHP50.2 in my Amutorch TC750 Shadow. Wasnāt real happy with the cooler tint it came with. Think it was around 5700k or so. I like the new tint but there is a lot of tint shift from the center of the hot spot to the bleed. Only noticeable up close though.
Thanks for that info djozz!
Could that be a āreasonableā high drain battery, an alternative to the AW IMR16340 15C 550mAh (Red)?
Now I am also curious because of the Enercig TN14500HP 650mAh , which might be a good alternative to the EFEST IMR 14500 Purple (despite HKJ tests show some inconsistency between the tested batteriesā¦).
Monday, I just built a modest Sofirn C8f with XPL-Hi V3 3A. It will be a gift, with Mtn's 17mm fet+1 driver. I'm getting better at teaching people the D4 firmware.
My problem... It is a very nice light. I had to test it, of course, and now it will be hard to give away.
My other problem was getting 18awg through the holes in the shelf, and then doing the spring bypass with it... I had to strip the length of the spring plus the board width because the insulation didn't fit through the driver's positive LED-wire hole. It was designed for maybe 20 or 22 awg, but I am stubborn. So I soldered the base of the exposed lead to that hole, and the end to the spring. Should have just gotten high current springs....
Iām completely unsure. This ebayseller (sells a lot of Enercig and Enerdan products, maybe an Enerdan factory store?) mentions a maximum discharge current of just 2.1A, which would imply that this cell is ok but not great. However I get the impression that it does better than that. Without HKJ-style testing we will not really know.
Edit:
*the āquick testā function on my Opus gives huge variation from slot to slot and from time to time, from 109 to 250.
*capacity test (500mA) was resp. 705 and 712 mAh
*the amp reading at startup in my little Luxeon V light: 3.23A for the old red Efest V1 700mAh, 5.45A for the Enercig (but what is the capacity at 5.45A?).
*the output at 30 seconds: 520 lumen for the old Efest, 990 lumen for the Enercig. The Enercig showed much less drop than the Efest, but perhaps the Efest got tired over the years?
Thanks for taking the time to write and test djozz! Much appreciated!!
Wish HKJ could do some test on these cells to check how they really perform, as so far it seems better than advertised!
About that seller, can it be another battery and not the one you have? Iāve noticed that the Enercigs have similar names (apparently) but then they differ. (as in NKON site)
Again, thanks and I will keep an eye on these! And also on the Enercig EC-14500HP 650mA, that seem to perform well on high Amps (better than windyfire IMR and efest IMR)!
Today I decided to modify Lumintop SDmini. The last time I changed his diode. Now the driver. I pulled out of the GTmini with a broken switch and put it in SDmini. Effect? Wow. A fantastic compromise of size, power, range ā¦
When the temperature control was turned off, after 6 minutes in the turbo it reached the temperature of 78 degrees Celsius. Hot, but it does not bother me. The most important thing is that now I have full control.
These are my measurements:
The original UI was terrible. Bad spacing and long holding to turn off. Led only CW. But now itās the perfect flashlight, small, powerful, with a great UI. He deserves a place on my shelf
Totally agree - the modified SD Mini w/FET+1 and NarsilM has been my go-to EDC for quite a while, just wish Lumintop didn't stop selling/supplying them. It's quality all the way from the anodizing, to reflector to lens, and in a perfect hand size, pocket size, package.
Today I modded the room accent light my son and I built for his room a week or two ago.
He likes the thing so much he wasnāt even using his lamp anymore (which his mother and I wernt thrilled about, always looking like a rave going on in there) so I thought why not put some white LEDās on the thing so it can be his room light too so heāll keep the white lights on.
I also cleaned up the wiring and hid the RGB driver in the wheel hub and then finished off by running a new wire in the wall to make it so the wall switch controls the outlet this is plugged into instead of the room lamp (at his request).
To make it so we donāt have to suffer dj Robbies light show anymore the white lights are always on (if the output is on) but the RGB ledās are still controlled by the remote and can even be powered off.
Did another project this evening; updated my zeusray.
My phone was dead so I donāt have any pics of the driver build but itās a HQ10D driver running Bistro and somehow I managed to reflow the CW SST-20 and solder the led wires without getting a single splatter of flux residue anywhere so I snapped a pic of that.
Didnāt measure lumens, donāt care about those from a zoomie but throw is 29,770Cd. Not anything special but this is a light I loan out to people, my kids or my fishing buddies, so itās plenty for that and being limited to 3.5A on turbo and having temp protection itās pretty idiot proof.
I also made a new āthrow distanceā column in my light spreadsheet and wrote a quick cell algorithm so I donāt have to calculate throw distance manually anymore! Highlight of my night lol.
I hardly ever post here but seemed like a good place to put this .
I have been playing with the new model Jet-Beam RRT-01 for about a week now. The light will except a 16340 or 18650 battery.
I got to measuring the outside of the battery tube and noticed it was only about 2mm bigger than a 18350. Well thatās about the same diameter tube as a Sunwayman V11R.
If Jet-Beam can make a 18350 fit in a 20.3mm tube then so can I. I hadnāt played with the lathe in a while so I thought this would give us some time to get reacquainted.
Bored the Sunwayman V11R tube to fit a bigger, badder, more capacity 18350.
Took me about 30 minutes to bore, took my time.
Took me twice that for setup, I had to make sure both ends were running true so I didnāt end up with a hole in one side.
I figure thereās about .7mm left in the smallest part of the tube.
The driver has been modded and the led swapped for a LH351D 4000k 90cri making a little over 1000 lumens plus a lighted switch and now powered by a 18350 Aspire battery.
