More likely, if vibration caused things to shift, it would just turn off.
Oh, did my scenario seem a bit extreme?
BTW, do you think there would be a way to use a similar design in other lights?
The only current(easy) way to get an e-switch tailcap/FET switch is with a battery/super cap setup, so something like the FW3A, but on other lights would be amazing.
I have never had a problem with a Novatac on my bike.
Maybe the FW3A will be just fine as a bike light
djozz, I hope it will. Everyone has there own idea of perfect EDC light, even though I don’t ride like I use to , I still think a light should take some bumps.
How did you know I am drinking?
I bike most days so if anybody wants to send an FW3A I’d be happy to do some testing. All in the name of science, or course.
I was hoping I could do some bike tests on this one, but I had to do some modifications to get the driver to fit correctly… so it’s not a representative sample. I may not be able to test biking properly until production units are being sold. As is though, I’ve noticed it occasionally needs re-seating by loosening/tightening the connection from the body to the head.
My proto2 model hasn’t needed re-seating like this in a long time, but it initially did before I added kapton tape around the inner tube. It had a correct driver fit, but had a too-wide retaining ring and a spring-side ground ring, either of which could short against the inner tube. So it was initially unreliable but that was fixed by adding a small strip of tape.
The most recent, proto4, made the retaining ring narrower and removed the problematic ground pad, so it should be more reliable by default. But the driver on mine didn’t fit right, so it had different issues with similar symptoms.
Anyway, it might end up working fine for biking, or it might not. I don’t have enough info to say for sure yet. Even if it does end up being unreliable for that though, a carefully-placed piece of tape would probably fix it.
^^Adhara, It might not even be an ISSUE, If it is, it’s not an ISSUE with the UI. It possibly could be an issue with the way the switch transfers its signal. Host related.
I am using Anduril in the D4R and have not experienced any switching issues while submitting it to G forces
The 2 fish block is very forgiving.
I guess speculation takes precedence over looking up the answer from published sources.
I think you’re confusing signal debouncing (which Anduril has) with a physical tendency to short out (which the firmware has no control over). This is not a thing which can be solved by changing code on the MCU.
As for signal debouncing though, two of the supported platforms have rather noisy switches… so I had to add pretty strong debouncing code. Especially on my lightsaber, the switch is really low quality and its signal bounces like no other switch I’ve ever seen. The FW3A switch is relatively tame in comparison.
I’m not really worried about bike vibrations causing spurious button presses… I’m more concerned about it causing electrical noise strong enough to overload and reboot the MCU. But it remains to be seen if that will actually be an issue.
On proto2, I can turn the light on and hit it sideways really hard and nothing happens. But on proto4, if I hit it hard at just the correct angle, it shuts off. Like, immediately… not with a delay like it would with a button press. It’s not detecting a spurious button press. And I don’t know what to expect from real production hardware, because this one was modified with a dremel.
How much play is there with the inner signal tube?
A layer or two of fine kapton tape for a snug fit to remove any play and further insulate it from the body/ keep it perfectly centered?
Does the inner tube come out?
We can just add some kapton tape to the inner tube to solve all possible problems?
We don’t even know there is a problem. I am sorry I got everyone worried about something that might not even be.
^ Yes tape can fix anything
One layer of kapton tape was all I could fit. Any more than that and it won’t fit into the outer tube any more.
I don’t know if the tail parts will be glued or not, so I don’t know how easy it’ll be to open. Regardless, that doesn’t seem to be an issue as much as making sure the driver fits into the proper place. Proto1 and proto2 were totally fine in that regard, I never saw a proto3, and proto4 didn’t have quite a large enough space cleared out for the driver.
Detailed info has been sent, but everyone there is on holiday for a while so there is no response yet.
Cool. I’m guessing there is a retaining lip at the switch end of the tube?
Yes the driver cavity being correctly machined is quite an important aspect of this build.
Also, added stepped ramp default (78 lm) runtime https://i.imgur.com/uTsDSDI.png and measured maximum output with 50% drained 30Q (1980 lm @ 0 sec, 850 lm at 30 sec)
What voltage level did you use for the 50%? 3.6V?
I discharged 1400mAh out of a 30Q whose capacity I first measured at 2800mAh. The resting voltage was at about 3.75V.
Yep, you can see the lip in this drawing, meaning it has to slide out from the tail cap end.
Great review, thanks! Very detailed post with all the tech stuff we need
Has anybody modded this light into a quad? Would standard quad parts fit into the head?
