EDC AA or AAA pocket budget flashlight
Yep, I agree… excellent choice. If your interested, check out m4dm4x.com; you might find a bit better deal. :wink:
The Astrolux A01 is on sale, and I think it wold be a good chhoice. Also maybe even better is a Lumintop EDC 01. I bought a couple for about $12 for 2.
Both lights are within your stated amount, ans so is the Lumintop Tool AAA.
Jerry
Can anyone recommend an EDC 1*AA , high output 150-250LM, with a color temperature of 3000-4500K, possibly Hi-CRI, no low frequency PWM, quality flashlight in the $10-$25 range?
Thanks very much.
Sorry, I can’t with that CCT.
BUT… if you ever want a pretty neat AAA try the Astrolux A01 Nichia 219B
I just picked up a couple the other day & I am very impressed. Not sure what the CCT is, but it is very pleasant.
I have this, I’m quite pleased. But for other tasks, EDC 1*AA is needed.
Easy. The convoy T2 13.98€ |Convoy T2 AA taschenlampe|Taschenlampen| - AliExpress
You can ask him to put any LED inside.
I would say Jaxman E3. I can’t remember if it has PWM, but ticks all the boxes if you chose the warm white Nichia. It has 3 modes and is a very robust flashlight!
BTW, the Convoy T2, even being a great light, has PWM in some modes!
EDIT: Jaxman E3 has PWM on middle mode (i put some pics here and Jaxman confirmed PWM on middle mode)
If only it wasn’t for the CCT, I’d say the Lumintop Tool AA 2.0 is a dead ringer. Maybe if you wait they’ll come up with a Nichia version like the Tool AAA.
Jack Kellar, Oh yes, I very much want a Lumintop Tool AA 2.0 with a Nichia!
Yes, I looked at him. But: High mode 350Lm and 2.4A, it should be very hot, especially on Nichia. High mode 200Lm for Nichia seems more prudent to me.
> Astrolux A01
Yes, I agree with that recommendation, BUT read the comments on the linked page, as it now comes with the dreaded next-mode memory.
And there are a couple of fixes mentioned — a temporary one, the pencil line mod, which lasts a day or two.
And a permanent one:
BLF will last as long as manufacturers continue to ship crappy flashlights.
My 3 pencil modded ones last since a few weeks now. My kid uses his daily and it still resets after two seconds.
But I agree we should not need to do this at all in the first place.
Does anyone have a source of the needed 100k Ohm SMD resistors?
I’d only need four or five of them, maybe a dozen at most.
The sources I find sell them by the hundred.
Arrow. With their free shipping you’ll get several and pay a cent or two, delievered.
You could always do an emitter swap :wink:
The Lumintop Tool AA Version 2.0 is a great light. It is $3.00 over your max budget. I can not think of a better AA size flashlight in the price range.
https://www.amazon.com/LUMINTOP-AA-2-0-Flashlight-Pocket-sized/dp/B07BLTP9ZD/ref=sr_1_2?ie=UTF8&qid=1549500307&sr=8-2&keywords=lumintop+direct
For the AAA size:https://www.amazon.com/WUBEN-Flashlight-Lighting-Handsfree-Waterproof/dp/B07HRNZ1Q8/ref=sr_1_3?ie=UTF8&qid=1549500519&sr=8-3&keywords=wuben+aaa
$14.00
I can’t remember how “hot” it gets because I used the driver to mod a flashlight for a friend of mine.
Still, using AA batteries won’t get it it too hot, I guess. If using 14500s (not advisable for that light) then it would get hot, but with AAs, not so much!
It is a very nice light, still!
MascaratumB, Respected maukka did a review of Jaxman E2 on Nichia with the same output of 290 Lm and measured the heating of the flashlight: “The head gets to 65°C at 17 minutes and this is as hot as it gets. At this point the handle is at 59°C. Without cooling, the battery tube reaches 50°C at about 10 minutes. I consider this too hot to hold comfortably with bare hands.
Therefore, I fear that E3 will also heat up very quickly.
I can only make the corpse of a flashlight. I am that dude from the old advertising of the TV-shop whose everything falls out of my hands :smiley:
Hum, I don’t know it that will influence on the heat of the head/led, but the Jaxman E2 is an 18650 Li-Ion light, while the Jaxman E3 is an AA/NiMH light.
With an AA on several lights I have, they never got “that” hot, unless when I was using…Li-Ion cells.
I don’t have the means to test the temperature properly, but my guess is that the type of battery will surely influence the heat it produces.
So maukka’s test is appropriate to report those conditions: a Li-Ion battery with Nichia, not an AA with Nichia.
But please correct me if I’m saying/seeing this wrong :zipper_mouth_face:
MascaratumB There is a test of heating the old version of the Jaxman E3 at 200Lm, 40°C in 22 minutes. The difference between 200 Lm and 350 Lm is a 75% increase, which could significantly affect the heating. But of course this is all theory, only real tests can give an exact answer.
