I was just looking at a 4 x xhp35-HI version of the Q8. If you use a driver like Lexels Buck unit it is limited to 8A total, so that is 2A to each emitter. If xhp35-HI, then maybe you would get 6,500 to 7,000 lumen. I’m just guessing here. Maybe the HD version would be higher, but you lose throw.
In exchange for the reduced power consumption, you get a smaller hot spot. Maybe that’s a good tradeoff?
The X65 seems to have a 1500 meter throw range with 5 leds. I wonder if the GT4 can match that?
It could be good for some people, the issue is how many would sell? I am not sure there would be enough sales for them to make this version of the light.
They generally make batches of 500 lights at a time. I highly doubt that 500 XHP35 GT4’s would sell when most would go for the XHP70 version.
If the demand was there it could happen for sure but more then likely this will be a case for custom mods. Luckily this would be a fairly simple custom mod to do, all you would need are some ~26mm+ 3535 mcpcb’s and you could DIY it with XHP35’s without a lot of trouble.
Although personally I think I would go with Boost HX LED’s if I was going to do that once they are available. You can simply run them in series and DIY it just as easy assuming they can stand up to the FET driver. If not then a re-flash with a limited max output should work like the 219C.
That Acebeam X65 doesn't make sense - 12K lumens is not right from qty 5 of those LED's - should be more like 10K lumens. The 423 kcd rated throw sounds low to me, considering head width of 108 mm and high amps to the XHP 35 HI's. Wonder if anyone reviewed/tested this light?
I modded a BOSS1 (100 mm head diam) with direct wiring, dedomed XPL, and got over 700 kcd.
Also I've gotten over 500 kcd on modded Shockers, a 106 mm head diam, 3 C8 size reflectors, dedomed XM-L2's.
Maukka tested one on BLF, but that was before he got his Lisun sphere and fancier equipment. With an older sphere and no calibrated light it was about 11k lumen at turn on and 10,500 at 30 seconds. I just asked him if he ever retested it using his newer equipment.
IDK. It’s good when the forum has some input on the design. It can help prevent them from making simple mistakes.
Luckily, this is a modified version of a well established light and I think Texas_Ace also chipped in on the design so it’s probably not suffering from any mistakes.
Hopefully they will swap to white centering rings for production.
I don’t recall seeing anything bad about the R90C either. I own one and it’s awesome, puts a huge smile on faces every time I show it off, and it’s got the lantern and green batt lights. It’s on sale on BG for like 229 right now. I don’t see the GT4 touching it on price or performance.
