I look around and see some other lights I am interested in, but say NO to them as this light offers so much for so little money. Let’s hurry up and get this light so I can buy some others
Try a year and 9 months.
But patience grasshopper, we’re all waiting and there are a select few working on this that we all have to thank for their tremendous effort and dedication to the community.
Buying flashlights is like buying guns. Once you think you’ve found the perfect one and buy it another one will turn up in a short amount of time that promises to be the last one you’ll ever buy. I have guns that I never shoot and flashlights that I never use other than wall shots. So in the end buy whatever strikes your fancy at the moment knowing that it will soon be destined for the storage bin
After you’ve been around here for a while you learn to have some patience with the development progress of these project lights. They do take a while to get things right. It’s not like the forum members or the people in China have nothing else to do and can move a project from being a glimmer in someone’s imagination to a completed-available-for-purchase project in a short period. It will all come together when everybody involved in the design and production has completed their part.
A special boost driver would be required with higher LVP than normal Li-Ion. Such driver would need to handle 30W+ and probably costs as much as the entire flashlight.
LiFePo4 18650s also have low capacity which makes it impractical for such high current draw.
With regard to capacity, sure, it would be about half… That’s acceptable to me. … And they do make high-drain LiFePo4 cells (~20A continuous, 70A pulse)
As for boost drivers and such, I’m going to start a new thread and flesh this out some more. I have some ideas… I mean, I know it’s possible to do this cheaply given all the 1 x AA lights out there — though probably at a much reduced throughput (far less than 30W).
The only reason 1 x AA boost drivers are so cheap is because they are for 1 x AA. We are just now getting some aftermarket boost drivers that are powerful - about 50w. They are still expensive, though. It might be many more months or 2020 before we get a range of sizes. So I would not hold my breath for a FW3A specific boost driver.
It will accept LiFePO4 cells no problem. The driver will not mind. You do need low voltage leds to go with it though, not the XP-L or LH351D. If you can manage fit SST-20 leds or Luxeon V’s, you are good to go. It will cost you output on turbo (that was insanely bright anyway) but the lower modes will work until the batterie is mostly drained.
It may also be a good idea to modify the low voltage threshold in the firmware, but otherwise… yeah. It should work fine with LiFePO4 if it has an appropriate emitter. For example, some color XP-E2 emitters have particularly low Vf.
If only there was an option to have my FW3A made with those colours :heart_eyes:
Since its no longer “straight off the lathe” it’d be incredible to have a colourful option :innocent:
