A special boost driver would be required with higher LVP than normal Li-Ion. Such driver would need to handle 30W+ and probably costs as much as the entire flashlight.
LiFePo4 18650s also have low capacity which makes it impractical for such high current draw.
With regard to capacity, sure, it would be about half… That’s acceptable to me. … And they do make high-drain LiFePo4 cells (~20A continuous, 70A pulse)
As for boost drivers and such, I’m going to start a new thread and flesh this out some more. I have some ideas… I mean, I know it’s possible to do this cheaply given all the 1 x AA lights out there — though probably at a much reduced throughput (far less than 30W).
The only reason 1 x AA boost drivers are so cheap is because they are for 1 x AA. We are just now getting some aftermarket boost drivers that are powerful - about 50w. They are still expensive, though. It might be many more months or 2020 before we get a range of sizes. So I would not hold my breath for a FW3A specific boost driver.
It will accept LiFePO4 cells no problem. The driver will not mind. You do need low voltage leds to go with it though, not the XP-L or LH351D. If you can manage fit SST-20 leds or Luxeon V’s, you are good to go. It will cost you output on turbo (that was insanely bright anyway) but the lower modes will work until the batterie is mostly drained.
It may also be a good idea to modify the low voltage threshold in the firmware, but otherwise… yeah. It should work fine with LiFePO4 if it has an appropriate emitter. For example, some color XP-E2 emitters have particularly low Vf.
If only there was an option to have my FW3A made with those colours :heart_eyes:
Since its no longer “straight off the lathe” it’d be incredible to have a colourful option :innocent:
I’ve been surfing the forum for a bit. This is my first post.
I just received, and love, the recent delivery of 2x BLF A6 (black/clear) from BG. Seeing this thread and the new knowledge I’ve gleaned from this forum, I have to get in on this GB! Put me down for one (XPL-HI), please. #1887
Heck, I’m still waiting for the slow canoe from China (FT shipper) that’s carrying my 2x Convoy S2+ (black/clear).
Happy to be here. I’ll post more soon (still in learn mode).
You can change the colour of Ti with voltage.
Some of the Rey pattern look like if they used a flexible PCB with a pattern, wraped it arround the tube and then applyed different voltages for different colors.
Or you have resistors on the flex PCB to get automatically the different voltages.
Maybe they work with one voltage for the body color and than they do the pattern.
Heat works also
Other Ti parts I see look if someone wraped a heated wire around it.
