IDK. It’s good when the forum has some input on the design. It can help prevent them from making simple mistakes.
Luckily, this is a modified version of a well established light and I think Texas_Ace also chipped in on the design so it’s probably not suffering from any mistakes.
Hopefully they will swap to white centering rings for production.
I don’t recall seeing anything bad about the R90C either. I own one and it’s awesome, puts a huge smile on faces every time I show it off, and it’s got the lantern and green batt lights. It’s on sale on BG for like 229 right now. I don’t see the GT4 touching it on price or performance.
Yes, the R90C will put a lot of pressure on this light now. This light made more sense back when I first had the idea 2 years ago. Then it would of been the only real light in the class.
On the plus side it should put some pressure on lumintop to get the prices down as low as possible. There are a few possibly options that could reduce the cost significantly, but still way too early to guess at the final price.
One thing I don’t like about the R90C is that it lacks active thermal regulation. The output only goes down but doesn’t go back up as it cools. The R90C has no heat fins so it doesn’t dissipate heat very well so output drops pretty fast.
same as with ms12, a useless fan inside that doesnt really make much sense, i really hope lumintop can do a better job on the heat management part and keep a decent price.
That’s not correct. The R90C has passive cooling, no fan.
I used it recently during a power outage. I turned it on turbo as a candle indoors, with no other cooling, it lasted a very long time before it kicked down and was quite hot so it has no issue like an early step down. Turbo was more than I needed. I would not want it to automatically return without hitting the switch, this is close to 20k lumens. I switched to using the lantern feature, very good in power outages.
You misunderstood. SKV89 said “active thermal regulation.” This means the software that controls the temperature. Active thermal regulation means the software can reduce, as well as increase, the brightness.
Mortuus was just saying the MS12 is similar. No one said the R90C had a fan. I hope that clears things up.
If I understand correctly, the pinout may be something like this…
* Reset -|1 8|- VCC
* eswitch -|2 7|- voltage divider
* AUX LED -|3 6|- PWM (FET)
* GND -|4 5|- PWM (+1)
This leaves only one pin to control the button LED and the front-facing aux LEDs. To make it control the front-facing aux LEDs separately, it would need to sacrifice the button LED or eliminate the voltage divider somehow. However, if that was resolved, it should be able to have a separate mode for the aux LEDs. They could be recessed into little reflectors or something, and given enough power to maybe have their own separate ramping mode. Perhaps replace muggle mode with red LED mode. But that would also increase the price, for features which may not be worthwhile.
No, he said “same as the ms12”. Same means same in my book. Thanks for clarifying the active thermal regulation; I don’t see it as benefit, would rather not have it personally and I prefer to hit the switch like I said rather than have my torch go up and down on its own
ok i meant that imalent clearly has quality issues, so fan or not they suck on thermal management stuff, thats what i meant im hoping lumintop will do a better job since it will also run passive but with huge heatsinks…
With Narsil you can set the thermal regulation to a custom temperature, set it to a timed limit or turn it off completely. All big advantages in my book. Thermal regulation that kicks in too soon or too late or not at all can really bug me.
I was just trying to help explain what Mortuus said since I understood him. I guess I failed. Oh well.
