Medical flashlight 1-2 AAA /AA
First - Welcome to the BLF forum!
What don’t you like about the MT06MD and the Klarus P20 (though the P20 has mode memory, so wouldn’t start on low, unless that was the last mode used?
The P20 appears to have a lower low and higher high in my samples - I just compared them again last night.
Second - miło widzieć rodaka :smiley:
Powitać!
MT06MD - 2nd mode is too bright for mouth inspection i.e. klarus - he kicks in on mid mode as far as i remember and mid mode is 70 lumens?
25 lumens of IYP365 could be even 20.
Pozdrawiam Rodaka, słownik telefonu doprowadzi mnie zaraz do łez …
Medical? Do you mean it should survive a pass through an autoclave to sterilize it?
No, IT wont be autoclaved. I mean i AM searching for best tissuse color quality.CRI DOV etc with lower power.
I don’t think you can do better than this light, its already very popular for medics. For maximum CRI and very low light you can use a minimag light with old incandescent bulb.
Massdrop sells Lumintop tools that always start on low mode, @about 3 lumens, medium is about 20 lumens
for medical use, I encourage you to consider a copper Tool, although they are heavier, because copper is naturally germicidal and even kills MRSA.
your IYP is really an excellent light, if you like the 2xaaa size, I think you did the best you can do, regarding the LED from a stock light, particularly because newer models no longer offer the 219b
The Optisolis and E21a LEDs that Clemence offers are in a class way above the Nichia LEDs in the Lumintop Tools.
I strongly recommend the lights Clemence is selling, if the lumen levels meet your needs. The color of the beam, and the fact that it can be diffused evenly without a hotspot glare, makes them absolutely the best, and most exceptional choice you could make, in terms of light spectrum and beam quality.
(about money: I agree it is unfortunate that shipping is expensive, maybe you should buy more than one, to reduce the unit shipping cost… LOL… then you sell one to a friend, and become a Hero who brings High CRI Light to illuminate your corner of the world ;-))
Yeah the Lumintop lYP 365 is imho a very good high cri light if you got the nichia219B instead of the newer more greenish tint 219C.
I like the driver in the 365 and am fond of swapping the head off them and putting them on the single AA light .doing this makes the low lower and improves the overall feel of the single AA tool flashlight . I'm guessing your complaint is the fact the light starts on medium instead of on low mode ? People have complained about this forever but I think it's easy to just get used to it . on a clicky light it's simple to make a quick click/tap. if you want med from there just click click .. off /on ..from there tap tap to high . if the driver is really bugging you than there are members here who can swap out drivers for you or you can just buy a driver and diy .
Jon thnak you for your post. Tons of information. I just dont know who Clemence is, forum user? Edit : Virence you mean?
Boaz yeah but when u need to double click all the time its a pain … additionaly i wanted 2nd one for my GF and she wouldnt be Happy. I thought about driver since i have nice solarforce mod from someone and i have some electronic skills tho i lack equipment to solder it precisely.
Clemence tools look amazing but its there anything else ? With shipping cost and taxes they will be super expensive :frowning:
This is the first light to check out, could just be the light you are looking for and it is just $10
(it used to be cheaper but it is still a good price)
https://www.gearbest.com/led-flashlights/pp_554388.html?wid=1433363
Yes, thank you for your reply. It does look good and i checked it. IT would be perfect just it only support 1 mode. So in terms of eye examination it sadly would be more like blindness maker :frowning:
50 lumen is what it does and that can indeed be quite blinding. What is the required output for eye examination? (edit: I see 2-3 lumen in the OP)
Yes low mode in lumintop can be called a bit too bright for me. I need option for Face and flashlight to be close to the patient since i need to check reaction or movement. Holding flashlight half meter away is away from being comfortable.
I’m thinking about waiting for lumintop answer about driver change. It will cost 13$ for me with shipping cost etc. Clarence flashlight will go up to around 60-55$ each. Unless there is such a difference in light that is worth paying for?
I have found regional FL maker and just saw on BLF that he uses hi cri LEDs so maybe he will be able to help.
Than you everyone a lot !
The Klarus P20 has mode memory, so it will come on in low, if you turn it off in low. I verified this last night.
If a 1 lumen low and a medium of either 10 or 25 lumens would work for you, you might look at the Zebralicht SC63c 1AA light.
This light doesn’t have a 2-3 lumen option.
Seems nice, nice modes with configifation. But its in Clemence FL price so i would rather stick with his moded jetstream. Thank you
the IYP low spec I saw is 1.5 lumens (all lumens levels Im talking about are for the High CRI), and Boaz informs it drops if fed with only 1 battery
that suggests that a Tool body with the IYP head would be below 1 lumen
whereas the Tool is 3 lumen
clemences LEDs are far superior, and his diffuse beam is far more appropriate, as a hotspot with spill is not helpful at close range imo. and iirc the Virence/Clemence Jetu has a 0.9 low in Optisolis and 1.2 lumen in E21a
if you buy the optisolis, and youre happy, that cost would be the same as trying a Tool, plus your IYP, if neither works for your low mode needs
the Klarus btw says 4 lumen spec, so if you think the IYP is brighter than you want, the Klarus and Tool will be brighter, hence less to your liking
as far as starting on low first, well… the Virence does that too, but, its a twisty, so now you have yet another feature to weigh
imo, the IYP is the most cost effective solution, and the only thing you seem to want to change actually, is the mode sequence… that simply is not an option, unless you spend more money.
so, I suggest you try to sort your priorities
  1. How Low do you want to go?
  2. Twist or click
  3. 1 battery or 2
  4. Low Price
good luck with your decision, for the price and convenience, I still vote IYP
I dont think a single battery light fits a doctors pocket as well as a 2AAA, and imo, twisty is not ideal for girlfriends :wink:
tough choices, I know, you cant always get what you want…
unfortunately there is no perfect light
Wow thank you for such an informative post. You mean Tool head can be changed with iyp? That would be something. I can say that 3 lumens would do the job if i cant find anything else. I think i will try Tool. Thank you!
