China is WELL KNOWN to Bootleg EVERYTHING. I collect toys, and other things. These guys have ” guts ” to bootleg so well. Unless real collectors will not know difference.
Could it be the Klarus lights are all made in China, and sometimes the assembly line just overruns a little bit past the ordered quantity, using whatever odd parts are laying around to produce a batch of cheap surplus/knockoffs?
Let me google that:
I've the same question about my G20 that I've just received today and something just wasn't looking right... I just didn't knew what it was.
That being until I've noticed the different (round) side switch bezel and other small details...
Flashlight was bought from AliExpress: KLARUS G20 USB Rechargeable LED Flashlight 3000 Lumens LED Dual Switch Lantern LED Torch Flashlight Latarka Handheld Linterna
So... beware..
Side switch - round bezel, (instead of square with rounded corners) made of Aluminum (?), flush button cap instead of a convex shape, hollow cheap feel and kinda "wiggly"..
Anodizing - Looks more like paint and comes off quite easily, like... paint. Came with some small scratches from the get go. Just like it's the case with exfoliated paint on a badly prepared surface.
Tail switch - decent feel but kinda stiff and hard to press - wouldn't notice that if not looking for something, would probably just assume that it's the way it should be (idk... maybe it actually is.. :| )
Body battery compartment - about ~1.5mm of play between the battery and the body I'd say - Isn't that just a little bit excessive ? Idk..
Tail cap - so tightly fit that I wasn't able to unscrew it with all my force and the help of rubber pads and using some pliers (handles side) as leverage, squeezing as hard as I could
USB cable - looks cheap as chips as any other "5 at 1$ deals" made in China...
LED - Looks like an XHP70.2 while the original (?) should be using the older XHP70... :| (?)
Boost - lasts for 10 seconds sharp before stepping down, no matter what..
Font on head below the charging port - much bigger and plain different than the original seen everywhere on the internet sources, reviews, etc.
[EDIT]
Oh man... just realized... my G20 has 4 brightness levels AND Turbo.. So instead of Low 15LM, Mid 160LM, Hi 650LM and Turbo 3000LM, I have Low, Mid, Hi, Extra Hi (?) and Turbo :|
[/EDIT]
Ok, some pictures then.. ?
Look up the Klarus G20L. That side switch is from the G20L, it also uses an XHP70.2. Looks like maybe an updated G20 version from Klarus
Chuckle.
Blame it on the subcontractor who stocked the parts bin.
I suppose I'll need to contact Klarus with a serial number and some other details to see what is what..
Yes,that does indeed look like the G20L switch, but still.. that's kinda shoddy. Also I don't understand the different emitter type and different modes. Not that I would complain about such upgrades if that is actually the case but what I'm worried it's that those aren't upgrades/changes of a newer revision but just tells that it's not the real product from Klarus. Anothertthing I can't understand, is what's going on with the tail cap not being able to unscrew it no matter what. Looks like it's welded in place or glued on. So far this is my first Klarus light, but in comparison, the quality looks questionable and of a lower standard than even my Sofirn lights, which supposedly are of a budget brand..
hey there and my first post here. OP, looks like you have an updated G20. check out klarus website and they updated the emitter and it says XHP70.2 P2 but the picture of the light still the old one. also, from looking at your pics above. your emitter is 70.2! you have 2 dots on the corner
i ordered one from amazon yesterday and i hope ill get the same one as yours!
Hi. Does it also specifies 4 + 1 modes instead of the 3 + 1 that is on the old (?) version ? Anyways, I've got a full refund for mine from AliExpress under the suspicion of counterfeit. Also because I had to damage the thing to get the tail cap off.. which was glued with epoxy - old one isn't..(?)
Now that is truly weird.
Does it still have push and hold to turn off? If not, I’d prefer the clone.
Mine surely does. And yes I hate that as well, the UI is plain stupid as far as I I'm concerned.
Can you open the tail cap on yours, or is it glued with the blue epoxy as well ? If so, I would rather have the original one which had unlocked threads. Greased, if anything..
Glued tailcap. Also, im reading your post about “boost” are you talking about momentary mode? Yes it will stay 12 secs thats how they designed it. But if its manually put in turbo it will stay on turbo for a long time as advertised.
How would you put it in the "manual turbo" tho... ? Mine only has the momentary... ?
Low, med, high, turbo. You have 4 steps.
RTFM….
Yes, I do have 4 steps, then the momentary turbo which is brighter than the 4th step, so my 4th step isn't turbo..
Its the effect on your eye because you keep on cycling modes.
Do this. Set the side switch to turbo the turn it off. Then you can compare them quickly by using momentary tail switch then side switch. You will notice they are both the same brightness
What I was doing was going up to 4th level, going to the momentary turbo from there, with the cut-off (hold > off > turbo) release the button, then it would return to the 4th level without any cut-off (turbo > release > 4th lvl) So there wasn't any eye adaptation period from turbo back to 4th lvl of brightness.
[quote=80T]
What I was doing was going up to 4th level, going to the momentary turbo from there, with the cut-off (hold > off > turbo) release the button, then it would return to the 4th level without any cut-off (turbo > release > 4th lvl) So there wasn’t any eye adaptation period from turbo back to 4th lvl of brightness.</
The turbo is the 4th level! Now the step down when doing momentary for 12 sec is not high or turbo. Im assuming its like more than 650 lumens maybe a thousand lumens.
But for manually putting to 4th level/turbo it will stay 3000 in regards to the temp. Mine stays long when im outside since the weather here in CT is god damn cold freezing.
