More magic.
There’s no where else to ask, plenty of technical questions in here already, ask away
I described the use of these in the OP, but in short the regulators on these drivers use current sense resistors from 1,2 K ohm and up. That’s a handy resistance value, so on one of them I use a 256 step 10K digital potentiometer instead of a fixed resistor which makes it fully adjustable. When it reaches it’s max current I turn on another regulator with fixed current and reset the adjustable one back to lowest current setting. The CN5710 is rated up to 1 amp, the larger CN5711 is rated to 1,5 amps. I’ve also “converted” the 256 step 10K digipot into a 768 step 30K digipot which makes the regulator adjustable from max down to about 0.05 ~ 0.06 amps in 768 steps.
It’s not one regulator covering the full range, it’s several. Fat3 has 3, Slim4 has 4 and this new L4 version has 8 of them. These regulators also have thermal throttling as opposed to thermal shutdown. I tested it and posted it in here on post #39, it works well: Driver giveaway: Constant current 17mm drivers, winners (finally) announced, post #2. - #39 by Mike_C
No boost. Only current regulation.
I have to ask about this. When exactly does the light turn on? As soon as you press the button? Or as soon as you release it? Currently I have short cuts from off and I don’t want the light to cycle through modes when entering the short cuts from off, so I have a very slight delay for multiple press detection. Narsil and Anduril don’t have this delay? Does that mean they don’t have multiple press short cuts from off, or they cycle through the modes when entering these shortcuts?
For NarsilM, I do it on button release for both 1 click ON, and the 1 click OFF. Anduril does it differently - I think for going ON, it uses the button press, but for going OFF, she does have a noticeable delay but I believe she's trying to fix that.
NarsilM will have small delays for multi click sequences, so for example: a dbl click goes to turbo, but for a triple click I don't want the user to get a blinding flash, so I delay to properly detect when the multi click sequence has ended. My earlier versions did not have that detection/delay and I got complaints.
Ok, just read that post bout doing the thermal test - Wow! That's pretty cool. We'll have to see how that plays out in the real world I guess, unless you already know or you know what to expect. I don't understand everything though, bit I assume this driver will be capable of true smooth ramping? If so, could we still apply the non-linear intensity ramping TK came up with and is used in both NarsilM and Naduril? We use a python script that TK wrote to generate the tables, parameter driven.
Thanks for the explanation.
I do smooth ramping with these drivers. The actual mode values used in my firmware (and stored in eeprom) are current values in mA. For example for 3 amps the mode value is 3000. I use the current sense formula in the datasheet to calculate the digipot position and how many additional regulators need to be turned on to meet the entered current. My ramping is an algorithm that increases/decreases the LED current exponentially based on the current value, and it’s rather smooth. I haven’t settled on the final algorithm yet but it’s good enough to continue on with other things.
I could even go one step further and have lumens values instead of current, but that would mean separate formulas for each LED type. I know, it’s absolutely unnecessary, but this kind of stuff is the fun part of the hobby for me
OK, that's all cool for what sounds like a pretty good smooth ramping, maybe even better than ours because switching channels on ours isn't the greatest, least in NarsilM for a triple channel.
Progress is slowly moving forward. I had a break from firmware development and spent some time designing drivers, among others a driver with a micro USB port that I’ll use for flashing the driver, so no need to even unscrew the head… if it works… But that’s done and OSH Park have the ball on that project, so back to firmware again.
Okidoki, I finally have basic firmware functionality including configuration system for all switch types. I can finally get down to the details some of you have posted. I hope those of you that have posted haven’t lost interest yet and can answer a few inquiries I have about some suggestions. I’ll be asking every now and then.
I’ve only once had a flashlight with forward clicky and I didn’t like it at all so I’ve not used forward clicky since then. Because of that my firmware isn’t really written with forward clicky in mind. However, I’m interested to see if I can make it work. You state that with FC on guppy3drv you can double click for turbo. Does this shortcut only work from cold start? Or can you do two short offs and go to turbo at any time? I am kind of curious on how this double click short cut with clicky switches work, doesn’t it interfere with normal mode changing? If you turn the light on and want to switch modes instantly, isn’t the short cut to turbo going to kick in instead of fast mode cycle? Or dose guppy3drv assume you don’t change modes rapidly? I have support for clicky switch short cuts but having a double click short cut really interferes with normal mode changing. That’s ok if you only have three modes, but then the double click short cut is useless.
^ You have to select your mode from half press momentary. Press-press for turbo then press all the way to click.
Just thinking that if the light is started in lowest mode and you want to step up only one mode brighter but not to turbo/boost, how would you do that? To me it seems the same press sequence would be used.
Leave on just a little bit longer before release and press. Put more time between inputs.
OFF—-Press until light (lowest)— some time—-release/press to next mode brighter—full press to click to lock on.
For Turbo
OFF -Press until light(lowest)—quickly release/press to turbo— full press to lock on.
EDIT- this is how it works for H17f. On Guppy 3drv you might have to quickly release/press 2 time for turbo.
Aha, ok thanks. You basically have to wait for a “multi press detection timeout” before the next press. I have multiple off press detection, but as being a reverse clicky guy it would be fairly annoying to have to wait between off presses with a 4 to 5 mode light. Out of curiosity, do you know exactly how long the timeout is on H17f or guppy3drv? I’ve set mine to half a second.
With H17f and possible guppy3drv there is no waiting on the off presses to change modes. IF you do wait you will either go back to mode memory, or reset to beginning of mode sequence.
Edit, removed video link. Wasn’t working
Sorry, but now I’m confused… you wrote “Leave on just a little bit longer before release”. This means waiting a little bit. Now you write there is no waiting
That youtube link just brings me to youtube.com, not an actual video… I used search function though, I found a few to look at.
Reverse clicky— there is no waiting while off to change modes. Very brief off presses with cycle through the modes.
With a forward clicky, you have wait just a bit when you first press—let the light know its on in low before you release/press to switch to med. If you press-release/press to fast on H17f (possible guppy3drv). It will read inputs as double tap and go to Turbo or what ever the double tap is.
The “some time” is time on.
Edit, I don’t know why video link is not working.
Search—- H17F driver run down with mistakes. 1 cut Chad.
That’s the wait I’m asking about. Do you know exactly how long that wait is? 1/4 second? 1/2 second? 3/4 second? 1 second?
I know. What I am asking is if anyone knows how long “some time” is.
Hi Mike!
I don’t have the light with me right now! Later today I will check how it behaves both with RC and FC switches and will tell you as now I have some doubts, specially when using FC clicky.
I’ll try to make a video with both kind of switches and will link it!
Cool, that would be awesome!
Nice to see progress.
In the meantime…I’m out of the GAW. I intended to use it with White Flat in Emisar D1. This combination doesn’t work well. Now I don’t have a combination of host and LED where this driver would really shine…I waited a bit with retiring because I thought that maybe I’ll think about some good combo. Well, it didn’t happen.
Thanks anyway!
Hi again Mike!
So, I picked my Convoy S2+ with the guppy3drv and made a try with Forward Clicky switch and Reverse Clicky switch.
DRIVER: FET + 7135 Driver - 17mm - MTN-17DDm
FIRMWARE: guppy3drv Instructions
For what is worth, I am using mine in the configuration 10-5-5 (FF > 1 > 5 > 25 > Double for 100%) 4 modes + 100% and without memory activated, so it always starts in FireFly mode.
FC switch:
“Resumé”
a) from OFF, consecutive single half presses cycle through the different 4 levels always as momentary ON modes
b) releasing the switch within the cycling process implies that the it will restart in Firefly mode the next time I half press/click the switch
c) the double half press for Turbo (100%) is active independently of the momentary mode I am in, so I can go Turbo whenever I want
d) HOWEVER, when I am on the modes FF, 1 or 5, if I double click for turbo and after turbo I do a quick release>press again, the light will get back to the last momentary mode used
e) on the mode 25 (4th regular level), if I double click for turbo and then do the “quick release>press again”, the light will restart in the FF mode, not the 25 mode.
f) obviously, a full click at any time “locks” the mode I am in at the moment, so I can only do the double click for turbo when doing half presses. Then I can lock Turbo by doing a full press.
RC switch:
“Resumé”
a) full click turn the light ON in FF mode; another full click turns the light OFF
b) fast full clicks for ON/OFF don’t get me into Turbo; the light only switches ON in the next output level/mode
c) when ON, single half presses cycle through the different 4 levels as “locked” modes
d) when ON, from any mode, a double press takes me to Turbo (100%), so I can go Turbo whenever I want
e) HOWEVER, similarly to what happens to FC switch, when I am on the modes FF, 1 or 5, if I double click for turbo and after turbo I half press/tap the switch, the light will get back to the last mode used
f) on the mode 25 (4th regular level), if I double click for turbo and then tap the switch, the light will restart in the FF mode, not the 25 mode.
Please apologize as I made mistake before the level 25 (4th) so I’ve restarted from there again.
This is curious, I had never tried this, but despite the switches used, they will behave similarly. All and all, in the 4th level, it doesn’t get back to it after Turbo, it will always go for FF.
I must mention that I didn’t use lighted switches, as they may have influence in the driver behaviour.
I hope this was useful and gives you some input on this UI!
As I mentioned, please be aware of the configuration I am using (10-5-5) and no memory.
Thanks for those videos! And chadvone too.
It makes sense expect for one thing regarding FC (e) , RC (f) and your comment: “All and all, in the 4th level, it doesn’t get back to it after Turbo, it will always go for FF.”
I find it a little odd that the behavior is different on the 4th level mode. Is this by design and something you appreciate, or would you rather have it go back to 4th regular level after quick tap from turbo?
Also a question about timing, using RC video for reference. At about 0:07 to 0:16 you do regular mode switching. Then at 0:17 you do double tap for turbo. Is it specified anywhere what the time limit between presses is? Obviously if you do two presses directly after each other with for example 0.1 second interval the light will switch to turbo, but if you do two presses with two second interval the light just switches mode after each press. What is the time limit where two presses are either identified as double tab for turbo or identified as two simple mode switch presses? I think this is the critical part weather my UI will work for you or not. The rest is easy, I support most of it as it is already, but the timing between presses is something that one gets used to. If it’s wrong on another driver it just gets annoying.
