Yes, thank you for your reply. It does look good and i checked it. IT would be perfect just it only support 1 mode. So in terms of eye examination it sadly would be more like blindness maker
50 lumen is what it does and that can indeed be quite blinding. What is the required output for eye examination? (edit: I see 2-3 lumen in the OP)
Yes low mode in lumintop can be called a bit too bright for me. I need option for Face and flashlight to be close to the patient since i need to check reaction or movement. Holding flashlight half meter away is away from being comfortable.
I’m thinking about waiting for lumintop answer about driver change. It will cost 13$ for me with shipping cost etc. Clarence flashlight will go up to around 60-55$ each. Unless there is such a difference in light that is worth paying for?
I have found regional FL maker and just saw on BLF that he uses hi cri LEDs so maybe he will be able to help.
Than you everyone a lot !
The Klarus P20 has mode memory, so it will come on in low, if you turn it off in low. I verified this last night.
If a 1 lumen low and a medium of either 10 or 25 lumens would work for you, you might look at the Zebralicht SC63c 1AA light.
This light doesn’t have a 2-3 lumen option.
Seems nice, nice modes with configifation. But its in Clemence FL price so i would rather stick with his moded jetstream. Thank you
the IYP low spec I saw is 1.5 lumens (all lumens levels Im talking about are for the High CRI), and Boaz informs it drops if fed with only 1 battery
that suggests that a Tool body with the IYP head would be below 1 lumen
whereas the Tool is 3 lumen
clemences LEDs are far superior, and his diffuse beam is far more appropriate, as a hotspot with spill is not helpful at close range imo. and iirc the Virence/Clemence Jetu has a 0.9 low in Optisolis and 1.2 lumen in E21a
if you buy the optisolis, and youre happy, that cost would be the same as trying a Tool, plus your IYP, if neither works for your low mode needs
the Klarus btw says 4 lumen spec, so if you think the IYP is brighter than you want, the Klarus and Tool will be brighter, hence less to your liking
as far as starting on low first, well… the Virence does that too, but, its a twisty, so now you have yet another feature to weigh
imo, the IYP is the most cost effective solution, and the only thing you seem to want to change actually, is the mode sequence… that simply is not an option, unless you spend more money.
so, I suggest you try to sort your priorities
- How Low do you want to go?
- Twist or click
- 1 battery or 2
- Low Price
good luck with your decision, for the price and convenience, I still vote IYP
I dont think a single battery light fits a doctors pocket as well as a 2AAA, and imo, twisty is not ideal for girlfriends
tough choices, I know, you cant always get what you want…
unfortunately there is no perfect light
Wow thank you for such an informative post. You mean Tool head can be changed with iyp? That would be something. I can say that 3 lumens would do the job if i cant find anything else. I think i will try Tool. Thank you!
I do not own IYP, so not sure if Tool head works on IYP body
Boaz says the IYP head does work on the Tool body, hopefully he will inform if the reverse is true, if that is your question
The lego might only work in one direction, if the threaded portion of the IYP head is shorter than the threaded portion of the Tool Head… iow, the pill of the IYP might be set less deep than the pill of the Tool
I know for example that the head of a Worm works on a Tool, but not the reverse…
good luck with your research, Im glad you are following the intricacies of my replies
be careful, cause if you listen to me too much, you are going to end up buying more than just one light… LOL!
Haha, i have already bought few lights and way too much knifes so… I’m trying to be super-carefull! Thank you a lot!
I think i will wait for lumintop, doubt they can change driver but maybe… just checked Tool, it would be cool too but also start from mid
I also have a lot of knives, I see you understand…
note that the Massdrop Tools start on LOW
there is not a snowballs chance in hell that Lumintop is going to modify an IYP driver for you
they give Massdrop what they ask for, as part of a special order, minimum quantity 500 pieces…
Lumintop also gave Reylight whatever mode order they want, again, special order
maybe the pineapple has the features you want?, it does start on Low, the level is really really low, like 0.1 lumen
Same issue with Clemence, USA to europe taxes and shipping costs kills… Well i will see what they say. Checking pinaple
That’s interesting, I’m pretty sure that my IYP365 (about 2 years old) low is 4 lumens, they must have changed the spec after feedback from the medical profession.
That’s possible. Mine is like 1.5 y old
Thought about it but just seen that nexttorch Has its reseller in my country.
Ok manker also looks good. This 50 lumens on mid and 219c not b. But i will think about that, thanks!
Nitecore same - cool, good( tho when i saw better LEDs i wanted better) mid mode too strong
NITECORE MT06MD
That would be it if 2nd mode weaker
Check if you can get one Manker E21.
See here: Manker E21 2x AAA Flashlight 200 Lumen Nichia 219B LED
From Manker AliExpress Store (the light is not for sale there anymore):
