I got one of these in the Aliexpress sale ,good price , but still good at the regular price.
I also found a couple of the things you mention needed changing , A clip I had hanging around from another project fitted and made it carry slightly deeper in the pocket.
I got it to tail stand by fitting a nylon washer/spacer in the tail cap before all the switch/button parts effectively lowering the whole assembly below the tailcap raised sections and allowing it to tail stand quite stably.
Also I think it must throw slightly better than the specs suggest, see wall beam shot of it on right with a BLFA6 on left , I think I read A6s throw to about 150m
“I’ve had the bezel off – it’s immediately removable by hand. …. I haven’t looked to see what the MCPCB is made of, or what it’s sitting on, because I’d have to desolder it, and I’m not ready to do that yet. ”
I bought the flashlight during the flash sale on Aliexpress for $8.67. The unit I received had the bezil glued tight (but with a monkey wrench it was easily removable). The driver itself was also glued in but a pair of pliers did the trick. The leads on the drivers are long and the driver itself is coated in a red plastic like material. I really like the flashlight driver ( the mode spacing and double click for strobe) So I order a second one after the flash sale for 9.37 (still a great price). I will only replace the led to a warmer tint.
I bought one in December and mine has a definite greenish tint to it. Other than that I like it and have it in one of my cars where the green tint doesn’t bother me
Anything out there similar to this but a little less tactical and a little more warm/white?
Seems like Nitecore is the only other option and they are pretty much identical. UltraFire UF-SET9, Nicron 3W are cool but are
older models compared to the 450LM Sofirn SF13 v3.
I found two others that look interesting, but again are dated, the 4Sevens Quark Mini 2AA and the Lumapower Connexion X2 2xAA. Both have a more streamlined look to them and not quite as tacticool.
I actually have 4 of these in which I have put a 3500K SST-20 in one and a Luxeon V2 In another. Other 2 are still stock. The V2 is wonderful. Great little lights.
I just received mine in the mail today. For the record, it’s the first light I’ve ever bought online, and it’s the latest version of the Cree LED I’ve had any experience with. Other than this one, my best 3 lights are an Energizer 2AA with a Luxeon Rebel at 130 lumens, a no-name spotlight that runs on 4AA and uses a Cree XR-E and puts out 220 lumens, and a Nebo Redline 3AAA that has a Cree XR-E that claims 220 lumens, but I have my doubts about that. I did side by side comparisons between the Sofirn and the Energizer since they’re most similar.
The brightness of the Sofirn is said to be 420 lumens, which may or may not be accurate. My eyes thought it wasn’t that bright, but it’s possible. Hard to tell for sure. I think distance and other circumstances make it easier/harder to tell. Definitely greener than expected, as SIGshooter mentioned.
The overall build quality is really nice, and far beyond anything I’m used to seeing in brick and mortar stores at similar prices (I paid $9.60 for the Sofirn, $22 for the Energizer and $25 for the Nebo many years ago). The pocket clip is rather shallow, but seems strong enough to hold it in place.
The shipping time was something I was impressed with. I was expecting to wait around a month, or even 45 days to get it, but I ordered it on Feb. 9th, and got it today, which is the 23rd. That’s exactly 2 weeks. The latest tracking info. showed yesterday that it was going to come on Monday, so I was surprised to find it in my mailbox today (Saturday).
Now it’s becoming a habit to see what else Sofirn has to offer. Their prices seem almost too good to be true. The Sofirn SF13 reminds me most of the old Quark 2AA tactical that used to cost $78, and wasn’t anywhere near 420 lumens.
I’ve tried, but haven’t been able to by hand. The head itself unscrews from the body easily enough, but the head itself doesn’t disassemble. I’ve heard it can be done if enough force is applied with a wrench. I haven’t tried that.
The instructions of my SF13 says that it’s glued on and that opening up the head could void the warranty. Probably not worth taking a chance on messing anything up by opening it, although I notice while looking at the LED from the outside using a strong magnifier, there’s a speck of dirt on the LED dome that I wish I could wipe off.
I don’t think that voiding warranties bother many on BLF
The problem with gluing the head is that one can’t change the led, say for example to get rid of the green tint, or even replacing the lens if it cracks at some point. My SP10 has some sort of film on the inside of the lens but I can’t easily get to it because of the glue :cry:
The second unit I received had more glue inside and was a lot harder to open. I changed the led but not because of green tint (I had ordered the 320lm version). Did you guys order the “420 lm” version?
