Medical flashlight 1-2 AAA /AA
50 posts / 0 new
MascaratumB
MascaratumB's picture
Last seen: 7 hours 17 min ago
Check if you can get one Manker E21.
See here: http://www.mankerlight.com/manker-e21-2x-aaa-flashlight-200-lumen-nichia...
From Manker AliExpress Store (the light is not for sale there anymore):
Quote:
Emitter: Nichia 219B
Battery: 1x AAA or 2x AAA (compatible with rechargeable and alkaline AAA battery)
Working voltage: 0.9-4.2 volts
Maximum Output: 200 lumens
Output & Runtime:
Moonlight: 0.5 lumen, 100 hours
Medium: 17 lumens, 13.5hours
High: 200 lumens, 35 min
Maximum Beam Intensity: 880 CD
Maximum Beam Distance: 60 Meters
Driver: Most efficiency constant current driver with a long runtime up to 100 hours
Body Material: Aluminum alloy
Clip: Stainless steel clip
Lens: Double coated anti-reflective coating lens
Reflector: OP reflector
Waterproof: IPX-6(1.5 meter under water)
Impact resistance: 2 meters
Dimensions:
Length: 128.5 mm
Diameter: 16.6 mm
Weight: 30g (without battery)
Accessories: Stainless clipx 1, Spare O-ringx 2
(Kindly note: the package is not included any battery)
Operation:
There is a stainless clicky switch on the tail-cap.
Two kinds of pressing methods:
1. Half press: half press for momentary on, continue half press(within 10 seconds) to modes circle: Moonlight – Medium – High – Moonlight – Medium – High – Strobe – Moonlight……(Over 10 seconds the light will turn on in moonlight)
2. Single click: single click for constant on, continue single click(within 10 seconds) to modes circle: Moonlight – Medium-High – Moonlight – Medium – High – Strobe – Moonlight……(Over 10 seconds the light will turn on in moonlight)
[REVIEWS] AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// ACEBEAM: H20 / TK16 /// BLITZWOLF: BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 / E10 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// KLARUS: XT1C /// LUMINTOP: Tool AA V2.0 + Tool 25 /// LIVARNOLUX: 314791 /// SKILHUNT: M150
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2 /// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
GIVEAWAY: 1
jon_slider
jon_slider's picture
Last seen: 6 hours 56 min ago
LightObsession wrote:
jon_slider wrote:
the IYP low spec I saw is 1.5 lumens (all lumens levels Im talking about are for the High CRI), and Boaz informs it drops if fed with only 1 battery that suggests that a Tool body with the IYP head would be below 1 lumen whereas the Tool is 3 lumen
That’s interesting, I’m pretty sure that my IYP365 (about 2 years old) low is 4 lumens, they must have changed the spec after feedback from the medical profession.
this page says the low is 3 lumens in low cri and 1.5 lumens in high cri
http://www.lumintop.com/iyp365.html
MascaratumB wrote:
Check if you can get one Manker E21. See here: http://www.mankerlight.com/manker-e21-2x-aaa-flashlight-200-lumen-nichia...
MascaratumB, you provide excellent info!
Thumbs Up
sequence: Moonlight – Medium-High
Docy
Last seen: 4 days 11 hours ago
This manker looks like this is it. ! I contacted nextorch, will see what they propose, but still this manker is way more versitile
LightObsession
Last seen: 5 min 50 sec ago
Isn’t .5 lumens too low for a pupil check?
Docy
I have found manker in regional store, a bit more expensive but warranty included so i think it will be it. What you think Jon? You told me not to listen to you but what you suggest ? Its cooler white than lumintop i think but i dont think it will be such a difference.
Docy
I dont know how you can check it but belive me it doesnt have to be strong
jon_slider
I like the 0.5 lumen low, and the N219b, I dont know what makes you say it is cooler than the lumintop
I dont care for the aggressive bezel, thats a pocket tearer to me
also,
https://darksucks.com/collections/foursevens/products/preon-p2
this is a 1 lumen low, and I think it starts on low, although its 219c, and I prefer 219b because it is less green tinted
were getting closer Smile
now you get to think about body styles, my vote would be for a smooth body, the manker body unfortunately is not my personal preference
Docy
Yeah i saw preon also cool with Warm price.
I meant that manker has cooler light colour, more like 5k
To be honest, when u mentioned agressive look, im thinking again to give up low-mid-high setup and stay with iyp365. Good quality, price, ok its not the top juyi etc. But do the job. You mentioned 219c and i see they are not making b now? Damn..
Docy
Modder told me that aaa size driver are a weakspot and its better to use classic 18650 size. That’s interesting. I will analyze all those we have and compare, good to have free weekend. Thanks everyone !
Docy
All in all, after comparing and some thinking, i stay with IYP365 brass option. + To check i ordered BLF Juyi Twisty. Clemence was out of my budget. Zebra a bit too agressive, same manker. Thanks everyone for everything. Hope all of you will find your best light.
Nichia
Last seen: 21 hours 58 min ago
 NEXTORCH Doctor K3 ENT Penlight for teeth inspection and ENT Care by Nextorch https://www.amazon.com/dp/B01LFLZIOK/ref=cm_sw_r_cp_api_i_wgBzCb9Z9CF8D
Am Breathing Nichia 219B
Tumbleweed48
Last seen: 39 min 52 sec ago
I’m a bit late to the party, but I’ll add my comment anyway. I’m a ‘penlight’ nut, and have several.
I just tried comparing the Thrunite Ti4 (neutral) with my IYP365 (219b) – the Thrunite has a far better low, and it’s ‘first in the sequence’. I tried looking into the emitters as if I were doing an eye exam; the IYP is downright painful, while the Thrunite is quite tolerable. This was in a normally lit room, so my pupils would already be somewhat smaller.
The tint of the IYP is undeniably more desirable when compared side by side, but the Thrunite isn’t really all that bad.
I also have some FourSevens Preon 2A’s. One in particular has their briefly offered warm emitter, which is a remarkably pleasant tint, but again low is not nearly low enough.
If I were doing eye exams, I’d have to choose the Ti4. If it were graced with a 219b, it would be as close to perfection as one could find.
Docy
Thank you i will think about thrunite too. IT just Hurts since i payed like 18 $ for iyp365 but for thrunite i would pay same only for shipping cost. Sad
Boaz
Boaz's picture
Last seen: 18 hours 38 min ago
The heads swap either way  on the tool and the iyp365   I like the smooth heads better on the tool which I use much more often then I use the iyp.  I like a bunch of people am sad that they went 219C vs the 219B. IMHO it's a neat little trick to get a better low mode and  makes the Nichia Tool a more useful light .I've edc'd a Tool like this on and off for that past few years.Super light weight ,good feel in the hand,firm snappy clicky . You get used to the  M/L/H driver  the more you use it and it's obviously much better in a clicky vs a twisty light
ActiveAl
ActiveAl's picture
Last seen: 5 hours 33 min ago
djozz wrote:
This is the first light to check out, could just be the light you are looking for and it is just $10 (it used to be cheaper but it is still a good price)
https://www.gearbest.com/led-flashlights/pp_554388.html?wid=1433363
Thanks for the heads up. Purchased one just to add to my collection.
guardior
Last seen: 32 min 36 sec ago
Hey doc, still around? Working extra as bouncer and security guard I’ve built a ton of flashlights but I’m also studying medicine and recently got tinkering with making a doc-light for use with pupil check and ENT. Would a Convoy S2 work? It got a pretty deep reflector so beam could be focused enough!? The warmest tint I got at home was a xp-g3 3a 5000k led but I got xp-g3 5c 4000k on order from fasttech too. Never built Nichia so will have to investigate a bit more about that. Found one at kaidomain that could fit if the usual attiny13 7135 drivers work with Nichia.
Docy
Hi there Smile
Well i used few times my solarforce mod with 3 tir optic nichias. Was good enought. It has nice tint and super weak moon mode like 0.04 lumens. I assume you have smo reflector? I bought S2+ with nice tint and yes it could do the trick since the beam IMO is not a big deal. You may just change the direction to examine oral cavity. Big deal is to cut the power down. My S2+ on lowest mode is still too strong to directly shoot the eye for me ofc. 4000K should be ok Smile Excuse me od there is an error somewhere but headache is killing me today
guardior
Docy wrote:
Hi there Smile
Power is not a problem as I build the lights myself. Running the xp-g3 at around 10mA seems to work fine. Never used Nichia but think I’ll order some. The Convoy S2 got a deeper reflector than S2+ so the beam is more focused. So S2 would be better than S2+ right?! And my S2 bought on fasttech got op reflector meaning the beam will be better I think, less rings and more even. Should be better right? I don’t got equipment for getting lumens so I’m only checking current. Was thinking around 10mA for pupil check and 40mA for ENT. Dunno if that helps? Smile
Edit: From what I could find Nichia219c work fine with 7135 drivers so I think I’m ordering a few of these.
Nichia219c
Docy
For your convenience Beam should be small enought to not hit both eyes. That’s would be Perfect Smile yes Beam should be better in OP reflector. Smile you have your own pupils, in my humble opiniom it should be weak enought to be tolerable to see. Pupil reflex needs very little light to work. Specialy im darkness. No need for lightthrower
