Battery bank that can jump a car?
36 posts / 0 new
stolikat
stolikat's picture
Last seen: 1 day 14 hours ago
My car battery died recently and it was a hassle. I wonder is there a battery bank powerful enough to jump a car?
AguassissiM
AguassissiM's picture
Last seen: 22 min 41 sec ago
@stolikat
Have a look here:
https://www.amazon.ca/car-jump-starter/s?ie=UTF8&me=A21BN97ZLZ79FQ&page=...
There are others and cheaper however this brand is the one that I trust, have few of their power banks and they are quality build units, have one mounted on my bicycle powering the lights for 2 years without a problem.
However I do not have one of these since I am lucky enough not to need one yet.
Bike Headlight by Megulla
Bike Light by Evolva
Rofis MR70 - just perfect
TurnRaise - Cree XM-L2, T5, 5C1 (4000K)had to replace led it quit....
Catapult V6 - awesome
BLF Q8 - spring mod
Haikelite MT09R
Convoy C8
and few others on the way...
Funtastic
Last seen: 4 days 7 hours ago
Keep in mind that if the battery is dead flat, a power bank isn’t going to be of any help
sbslider
sbslider's picture
Last seen: 2 hours 17 min ago
Elaborate please. I would have thought once you get the car started it would run until you turn it off independent of the battery condition.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
WalkIntoTheLight
Last seen: 7 hours 38 min ago
A lot (most??? all???) boosters work by giving your regular 12v car battery a charge. Then, when you start your car, most of the current comes from the car battery, not the booster.
If you look at the connections from your car battery to your engine, it’s likely using short 4 gauge wires, which offers very low resistance needed for the high amperage used to start your car.
The thinner wires from booster cables or the wires from a portable booster just don’t have the low resistance needed for a couple of hundred amps to flow over them. Hence, that’s why most of the starting power comes from your car battery.
But, yes, once you get your car started, then you’re good to go. The problem is if your car battery is really dead and can’t take a surface charge from your booster, you may not be able to start your car.
sbslider
sbslider's picture
Excellent explanation, I should have figured that one out. Thumbs Up
The batteries linked above advertise 400A and 600A peak capability, which they may be able to deliver, but likely not through the connectors and cables provided with the product.
wle
wle's picture
Last seen: 3 hours 40 min ago
==not exactly true – my instructions specifically say they do not charge the battery.
you are supposed to attach to the battery, then immediately try to start it.
the cables and insulation may melt if you try too long.
they have many ways to screw it up.
they also will not start a dead battery or a battery with a cell shorted.
==they can do it for about 20 seconds
==true
wle
wle's picture
==they can typically do that for very short periods
—-but it is also easy to burn or melt cables or insulation
i made the mistake of testing one on a 200A load, it destroyed the battery in about 2 minutes
battery puffed up and would no longer deliver over about 5A
only at 200A
it couldn;t really go over about 300A though it was rated at 400 or something
it was about a $50 one from amazon
they can have circuit breakers but they are just for dead shorts, cables can melt and the breaker does not trip
to their credit, the batteries seem to built to not explode etc, they just puff up and they go high impedance, preventing further overloading
—-wle
fireblade893
fireblade893's picture
Last seen: 4 hours 48 min ago
I had a 400amp booster from Costco and when my van went flat (not fully Flat but enough not to start) I tried the booster, I put it on the battery the LED went from red to green , I turned the key and it just went click. The van needs a certain voltage before it will even attempt a start, and the booster couldn’t supply enough.
The li-ion booster went back and I bought a caterpillar lead acid booster, it’s much bigger and heavier but it will start it no problem. It has started it 5 times on one charge ok. It even started a Mercedes sprinter van that was so dead none of the dashboard lights would come on. Best £60 spent in ages as when the li-ion failed to jump start I had to push the 2.5 ton van up a slope to bump start it on my own pushing 2.5 tons on a slope is hard work.
samgalax
Last seen: 4 days 19 hours ago
Which displacement is the engine you want To start? Diesel por gasoline??
Please SUBSCRIBE to my youtube channel (flashlights, electronic gadgets and various stuff..)
https://www.youtube.com/channel/UCCF3RcoQ3Ff05Cr4-Gg5qAw
I am a beginner. So please help me to make the channel "grow up"
Thanks!!
samgalax
I think that a proper lead acid battery is better, cheaper and safer.
Thanks!!
ryukin2000
ryukin2000's picture
Last seen: 59 min 59 sec ago
Tagged for interest. I just helped my father in law boost his SUV with a motormaster eliminator 800. -30C here in Calgary. It worked fine.Its bulky and old though. When full, it loses its charge within a day. Needs a new battery. Anyone have experience/opinions on the battery-less super capicitor boosters? They are expensive but catch my interest.
flydiver
Last seen: 10 hours 54 sec ago
Had an old Honda that did not turn off lights automatically, so a couple times/year would come back to a dead(ish) battery, dead enough to not start, but maybe…..barely…..light the dome light.
Got one of those jumper packs. I completely disconnected the Pb battery and the jumper pack would start the car. I never needed it after that but I did use it a couple times on friend’s cars and it worked fine.
If a battery is really dead, and the vehicle has a pretty high cranking requirement, even a full jump with huge cables from another running car may require several minutes of pre-charge before the jump will actually work. You may need to do the same thing with a jump pack.
Note- the better ones of these use LiFe cells. They will take a lot of abuse. MOST of them use Li-on (cheaper), not as rugged. I made an insulating/reflective jacket to put mine in to hopefully moderate the heat impact of sitting fully charged in a black car trunk, in the sun. Don’t KNOW it’ll help, but it sure won’t hurt.
texas shooter
Last seen: 30 min 54 sec ago
I got my mom this years ago because I don’t want her using jumper cables. https://www.amazon.com/Wagan-EL9796-Quick-Jumper-Jumpstarter/dp/B00005OWK2 Best when time is not an issue.
chinooker
chinooker's picture
Last seen: 8 hours 42 min ago
I bought this on Amazun in 2016. (No longer available there) Has started my riding mower many times and my 5.9L Dodge Ram even when the dome light wouldn’t glow, and it was 32 degrees.
The compressor is very handy and works a treat.
jerm03
Last seen: 4 hours 37 min ago
A year ago I gave my SIL this.https://www.amazon.com/Bolt-Power-D29-Motorcycle-18000mAh/dp/B01N3SEJIJ/...
He has needed it to start daughter’s SUV a couple of times and it worked fine.. I have one, but have not needed it.
Although larger ones might be better the size becomes a problem. These small starters can be carried and used by women and people who no longer have the strength to lift a battery.
I would recommend the small jump starter, and the Bolt is one I know about.
Jerry
RobertB
RobertB's picture
Last seen: 5 hours 32 min ago
I’d ask a dealer mechanic that question. Not so sure thats true with newer vehicles. One way to find out is, start your car, and disconnect the battery and see what happens.
edit… Actually, don’t do that, it’s bad advise. From what I just read, you could damage the ECU, and diodes in the alternator.
Lightbringer
Lightbringer's picture
Last seen: 2 hours 8 min ago
I just replaced my 6yo battery. Froze in the cold wx we had a coupla weeks ago, ironically while I was taking my other car back’n‘forth to work to charge its battery. Figured the battery was nearing its end-of-life anyway, getting weaker and weaker that it’d function fine under good circumstances but croke when I’d need it most.
Anyhoo, sure, you could jump a dead battery and have the alternator do all the heavy lifting charging it, but it puts a continuous heavy load on the alternator, not just running the car and all its electrojunk, but also trying to top off the cell from zero. Nice way to pop a diode-pack, fry a winding, etc.
On top of that, once the cell gets too depleted, its internal chemistry can get ruined just like running down a Li cell to nothing. Might even end up with a “leaky” battery, that self-discharges over time even with no load, and worse, puts a heavier strain on the alternator possibly taking the alternator down with it.
There are probably ways to test the cell to see its “internal health”, but in general, Pb-acid cells can be ruined if drained too low, even once.
stolikat
stolikat's picture
I have decided to replace the battery just to be on the safe side. I looked around and found that Costco sells interstate batteries for far less than anyplace else. I an going to look at all these chargers and see which one I should pick up. Thanks for all the good info.
Btw the vehicle I am trying to start has a 3.8l V-6 engine.
renton83
renton83's picture
Last seen: 1 min 29 sec ago
i got a engergizer lithium jumper pack on sale and it started a car that had just died but if the battery is completly dead it wont do much. I wish they were more clear about that on the package. It’s better then nothing but I would rather have the big jumpers that use a lead acid battery even if they weigh a lot. Only benefit to the lithium pack is it keeps a charge forever but the others have to be topped up often.
chinooker
chinooker's picture
they all have to be topped off from time to time
actually you can start most cars with the battery disconnected with the one I have
and with the low/dead battery not taking juice from the jumpers, it is easier to start.
then just reconnect the battery and the alternator starts charging it
you might have to reset your clock and my Ram needs to reprogram its brain automatically to my driving habits.
itsonlyme
Last seen: 4 hours 20 min ago
Had no issue starting a 2.0 diesel Audi with a completely dead battery. Ignition lights came on but wouldn’t even attempt to crank
ZoomieFan
ZoomieFan's picture
Last seen: 2 days 5 hours ago
https://www.anker.com/ca/products/variant/car-jump-starter-and-portable-...
This one outputs 200 amps and 400 amps peak.
Considering it’s small (44.4 Wh) it will only help when your car starts well if the battery isn’t flat.
If you usually have to try to get your car started for minutes until it fires up, this pack isn’t sufficient.
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88, LiitoKala: 3x100 4/5, 2x202 5/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: BLF Q8 4/5, DQG Tiny III 26650 5/5, FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Sofirn C01 BLF 3200k/5600k, Zebralight H600Fc 3/5.
Powerbanks: EasyAcc 26800 mAh 3/5, Xtar PB2 4/5.
Waiting for: (DQG Tiny) 21700 EDCs. Xtar powerbank that (also) takes 20700, 21700, 26650
Pöbel
Pöbel's picture
Last seen: 8 hours 32 min ago
It is possible to jump start a car with no battery connected other than a smallish (like 2000mah) 4S lipo. Sure, the lipo won’t like it but it works. Yes, the cables are “thin” but they are also very short.
Deputy Dog
Deputy Dog's picture
Last seen: 3 hours 48 min ago
I work part time at a car auction that moves 7000 used cars (in one sale day) a week. This is the one we use: Clore Booster PAC ES5000 https://www.jumpstarterreviews.org/booster-pac-es5000-jump-starter-review
It will work all day (10 to 15 cars) without a recharge.
jerm03
Hi Deputy Dog,
I have no doubt that that jump starter willl work, but the size and weight take it out of the range of some women and elderly. The small ones work fine and can be easily carried and handled.
Jerry
Deputy Dog
jerm03 wrote:
Hi Deputy Dog, I have no doubt that that jump starter willl work, but the size and weight take it out of the range of some women and elderly. The small ones work fine and can be easily carried and handled. Jerry
How old is elderly? You can’t carry it in a purse, but… I’m 61. Many of the guys and gals using them are 10 to 20 years older than I am. It only weighs 18 pounds.
Edited to add: If you’re not able to lift 18 pounds, how are you going to get the hood up?
jerm03
There are elderly who can lift much more, but also those who have trouble walking. The small ones can easily be kept in your auto without taking up much room. Let folks take their choice.
I am 86 and had a staph infection in my lumbar spine in 2008, and some days I have trouble walking without a walker. In addition I am now having hip problems. While I can handle the 18 pounds I find it simpler to use a lighter one. I don’t think it takes 18 pounds to lift the hood of my Toyota Sienna, but never had a reason to find out.
I was hunting in the mountains and carrying deer out on a packboard at your age, but it only takes a heartbeat for big changes to occur.
I change my car batteries about every 4 years. I don’t consider it very wise to try to get the last 6 months out of a battery since today you have no warning like the old days. I do the same in the case of tires, especially since I can no longer change a tire.
Regards, Jerry
Deputy Dog
Regards, Jerry
I got your point the first time. Maybe I should have included, it would be better (for safety reasons) for the disabled (like my wife who needs a walker) to call AAA, instead of trying to jump a car in the first place and save the cost of the jump box.
jerm03
To each his own, but the jump starter does well for those who have it. Better than waiting sometimes. If the cost is more than one wants to pay AAA is the way to go. When I travelled I always had a jump starter with me, although I never needed it. There were no small ones in those days. Today If I travelledt I would carry the Bolt.
Regards, Jerry
jigsaw
Last seen: 2 days 43 min ago
Deputy Dog wrote:
I work part time at a car auction that moves 7000 used cars (in one sale day) a week. This is the one we use: Clore Booster PAC ES5000 https://www.jumpstarterreviews.org/booster-pac-es5000-jump-starter-review It will work all day (10 to 15 cars) without a recharge.
I have used that exact booster to start cars and forklifts that had NO battery of their own. Just clamp onto the cables and it works fine, plenty of power. My local NAPA store carries that model.
