Lumintop GT micro
703 posts / 0 new
teacher
teacher's picture
Last seen: 7 months 4 weeks ago
gtxxl wrote:
Hello Teacher thanks for your Info, Thumbs Up
Unfortunately the Windyfire 14500 IMR 600mAh cells is not Available in Germany, (Germany (NO BATTERIES) | Germany has been temporarily suspended.)
That’s why I ordered these cells. Enercig (Tensai) TN1450HP – 650mAh 3,6V – 3,7V Li-Ion-Cells. – 6,5A/13A
https://www.akkuteile.de/lithium-ionen-akkus/14500/enerpower/enercig-tn1...
My pleasure gtxxl. Smile . The ones you ordered should work great. Thumbs Up
Smokecutter
Smokecutter's picture
Last seen: 2 weeks 5 days ago
Interested please.
dotBLF
Last seen: 2 weeks 4 days ago
Definitely in for one or two, imagine this with a White 1 Cash
lotrbfme
lotrbfme's picture
Last seen: 2 hours 3 min ago
Any update on this ?
lmcmann
Last seen: 1 month 6 days ago
teacher wrote:
gtxxl wrote:
Hello which 14500, 3.7V Li ion cell is best suited GT micro feeler, how much mA is good ?
I am going to use THESE, by Windyfire …. because I have them. But mostly because they are great cells. They come flattop or button top… I have some of both.
Windyfire 14500 IMR 600mAh – Flat Top
Unprotected, flat top. This is one of the best “high drain” 14500 cells available, outperforming even the venerable AW and Efest 14500 cells—check out the discharge comparison picture!
I tried searching in here and didn’t see an answer. Should we get flat or button top for this light?
Thanks for the suggestion on a cell.
Larry
teacher
teacher's picture
Larry
I can’t say for sure, I would ‘think’ either one would work. Maybe M4D M4X can answer that question.
M4D M4X
M4D M4X's picture
Last seen: 5 hours 21 min ago
 the driver has a raised button with 5mm diameter - so i think most cells would work
but if the shrink does cover the button ....
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
gtxxl
gtxxl's picture
Last seen: 7 months 3 hours ago
I think a Flat Top Cell, on the driver can work.
lmcmann
gtxxl wrote:
I think a button flat Cell, on the driver can work.
From the looks, a button top is safest. That might be large enough to go off the edges of a flat top contact. There’s enough room in the spring travel for a couple mm of length?
DB Custom
DB Custom's picture
Last seen: 1 day 5 hours ago
That’s a 5mm button on the driver, a flat top cell is easily 8mm inside the wrap, no problem. Wink
The cut offs on the via’s are at a minimum 8.6mm, and they should be below the level of the button anyway….
gtxxl
gtxxl's picture
Smokecutter wrote:
Interested please.
look here Lumintop GT micro interest list
http://budgetlightforum.com/node/63871
mortuus
mortuus's picture
Last seen: 8 hours 22 min ago
Saw on facebook that according to Neal its ready to order from him now..
https://www.nealsgadgets.com/products/lumintop-gt-micro-led-flashlight?f...
...where Frugal meets with Flashlight!
M4D M4X
M4D M4X's picture
already updated in the sales thread :
http://budgetlightforum.com/comment/1464385#comment-1464385
dotBLF
SWWWWWEEEEEEEEEEET
Thanks Martin!
LouieAtienza
Last seen: 10 months 4 weeks ago
Ordered already… cool white and 1000mAh battery (because I don’t have 14500s around)
Rdubya18
Last seen: 3 hours 10 min ago
Ordered , thanks Martin .
fluke
Last seen: 4 days 4 hours ago
Will these do for the GT Micro?
Enercig (Tensai) TN14500HP- 650mAh 3,6V - 3,7
LSX
LSX's picture
Last seen: 6 hours 46 min ago
Is anyone able to tell me what size MCPCB and driver this light uses?
I’m keen to try a white flat in it. Having not used a white flat yet, would it be ok with the stock driver in this light or would I need to swap it out with a lower current regulated driver?
djozz
djozz's picture
Last seen: 7 hours 40 min ago
Ideally you want a 12×7135 driver with e-switch control and those are not common. The stock direct driver could work fairly well because 14500 batteries show more voltage sag than 18650 batteries.
Texas_Ace
Texas_Ace's picture
Last seen: 1 day 9 hours ago
I did not measure it but it seemed a little smaller then a normal 16mm mcpcb. I think you could sand down a 16mm mcpcb to fit though.
A white flat was donated to me recently. Once I know I am done with the prototype I plan to install one in the GT micro if I can make the mcpcb fit.
M4D M4X
M4D M4X's picture
14mm mcpcb
17mm driver
(on my prototype)
komeko
komeko's picture
Last seen: 2 weeks 1 day ago
Wow, will anyone sell me the driver?
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, K1, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
djozz
djozz's picture
I estimate exactly 100 kcd, a bit higher if the reflector is really good.
ToyKeeper
ToyKeeper's picture
Last seen: 2 hours 24 min ago
Somehow, I hadn’t read about this light until now. It reminds me a lot of the BLF X5. It was cute, and the copper version is pretty, but ever since getting a D1 I haven’t had much use for the X5 or X6.
Anyway, a quick spec comparison of similar lights…
GT Micro: (manufacturer’s specs)
  • 36 mm wide
  • 105 mm long
  • 600 mAh Windyfire 14500 cell recommended
  • ~400m throw
BLF X5:
  • 31 mm wide
  • 108.5 mm long
  • ~333m throw
Emisar D1:
  • 34.8 mm wide
  • 74.8 mm long
  • 1150 mAh 18350 cell recommended
  • ~400m throw
I usually leave the D1 in my purse, soft-locked. It’s small enough I can forget about it until I need it… and it’s not often I need something with more throw. I have it flashed with Anduril, and configured to run in stepped mode with a high enough floor that I often don’t even need to unlock it to take a peek at something in the distance.
djozz
djozz's picture
Rationally the D1 is the better light, an improved GTmicro with a superior battery, but I really like the shape of the GTmicro, and maybe it helps a bit that it is a bit slimmer and more lightweight.
-X3-
-X3-'s picture
Last seen: 10 hours 8 min ago
Well… let’s hope that the GT Micro reflector is better than D1 one
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Nev
Texas_Ace wrote:
I just got my prototype GT micro in yesterday and I have to say, I like it. A nice little pocket thrower.
The throw ratings they gave are spot on what I got, I got 52kcd and 457m of throw on my sample.
Although the lumens are a bit lower, I got 900 lumens dropping to ~800. They are using VERY thin LED wires right now though and the tailcap springs could be a bit lower resistance.
I told them to use 24awg wire on the LED, that should bump the output up some so it could be rated at 850-900 lumens (technically it could now but that is not how I do things).
The thermals are surprisingly good as well, Took quite some time for it to heat up enough to thermal throttle and by that point the cell was at the point of LVP, so not sure which one it was that caused it to step down but think it might of been the LVP.
I have to say, it looks pretty good for a prototype.
the Emisa D1 is 43000cd & the gt micro is 52000cd ,so in theory the gt micro will throw further?
if that’s true ,then for how long (time) will the gt throw further ? the d1 will run on a 30q @3000mah & the gt run on a high drain 600 mah 14500.
Texas_Ace
Texas_Ace's picture
An 18650 will slaughter a 14500, no question. It was never meant to compete with an 18650 based light, the GTmini is for that. This is a smaller version for fun as much as anything.
Although having used it some, I can say it is actually a nice light overall all things considered.
ToyKeeper
ToyKeeper's picture
It’s a nice form factor. Small, comfortable, generally sleek. It’s physically pretty similar to a popular Maglite model, and that model was popular for a reason.
Looking back at the X5 though, the #1 request was that people wanted it to use an 18650 cell, to increase power and runtime. The head is wide enough that the wider cell would probably be a nice fit.
On a related note, one of the top feedback items on the D1S (and the GT-Mini) was that it should have maybe used a 21700 cell, for similar reasons.
Texas_Ace
Texas_Ace's picture
Yes, I like the idea of 21700 based lights as well, sadly they did not heed my suggestion that the GT mini should be made into a 21700 light.
I think it would of been a great combo.
I really like the Sofrin C8F? that is 21700 based.
