Thomas you can look this https://e-neon.ru/spetssvet/svetodiodyi-2/sphrd1l3dh00a4r2d2
And many red LEDs at bottom of page in “похожие товары”.
Paypal sent! I hope my slow response was no trouble.
I’m looking forward to putting one of these in an S2+ to compare to another S2+ that has a 219C in it. Also, I will probably try slicing one like Djozz has discussed to see if I like that better.
Thank you Andrey and Barkuti!
I checked all known sources for XP-E2 photo red and far red but I was unsuccessful with E-Neon, Mouser, Digikey and Arrow. The one and only source I could find was cutter.au which is an Australian supplier and I have no idea how reliable it is and how much shipping would be just for some LEDs. The Samsung LH351H (deep red) is very much like XP-E2 red, i.e. 1A maximum current, probably peak at around 1.75A max.. Anyway, thanks for you help.
Has anyone tested the LH351C yet in comparison to 351B and 351D?
Cheers
Thomas
The only one I’ve found is the XP-E in the far red spectrum:
https://www.mouser.ca/ProductDetail/Cree-Inc/XPEFAR-L1-0000-00701?qs=Rt6VE0PE%2FOeUVLT3F7NPxQ==
The LH351C is more or less in a middle ground between those two, maybe closer to the LH351B:
Samsung LH351C 5000 K CRI90 color and output test by maukka.
@ BlueSwordM
Yes, that one I found, too but I'm wondering why Cree states order codes for the XP-E2 far red and photo red but these are nowhere to get.
@ Barkuti
Alright, gracias! The 351D 4000K 70CRI with a top flux binning and same great characteristics as 351D 5000K 70CRI W6 would be a dream to come true. :-D I'm sure that one would also sell great even without HighCRI but instead with tremendous high current capabilities. Just thinking of a D4S with 2x 4000K 70CRI and 2x 5000K 70CRI for a great neutralwhite 4500K beam and 5000+ lumens.
On a side note:
I really really like BLF but working with quotes in the text editor is a real nightmare. No matter what I try when quoting something, it all ends up as an entire quote with my reply....aaaaarrrrghhh.
There is also Deep Red (~660nm) and Far Red (~730nm) from Luminus (they can be driven to 1.5A as the doc says, maybe a bit above that), but that needs a different soldering mask, as the contacts are not in a 3.25mm sided square area as the SST-20W has them, but 2.7mm, so I don't know, where one could get a board, which fits that.
Check Led4Power's catalog adam7027, they have some alternative smaller layout MCPCBs:
Oh, really, I forgot about those
Mountain Electronics has the older 660nm XP-E, and I believe they ship internationally:
In case you don’t already have this info from the datasheets, these should be the relevant prefixes to search for XP-E and XP-E2 respectively:
XPERDO = Red-Orange (610-620nm)
XPERED = Red (620-630nm)
XPEEPR = High Efficiency Photo Red (650-670nm)
XPEFAR = Far Red (720-740nm)
XPEBRO = Gen 2 Red-Orange (610-620nm)
XPEBRD = Gen 2 Red (620-630nm)
XPEBPR = Gen 2 Photo Red (650-670nm)
XPEBFR = Gen 2 Far Red (720-740nm)
It looks like 1st gen XP-E is a lot easier to find, even though I think they’re discontinued by Cree.
I did turn up the following XP-E2 links from Cutter, but I don’t know where they ship:
This link for some reason has the photo red part number, but lists the far red wavelength:
Price drop for remaining 351D 5000K. 1.6$/pcs 1-9pcs, 1.5$/pcs >10pcs.
Because it is discussed here, I read on the Cree site that they updated the 660nm and 720nm XP-E’s, with improved output.
Thanks for the information Jos! :THUMBS-UP: @AEDe: I hope you don't mind my intervention into your Samsung LED thread as this is about a totally different LED, not offered by you or e-neon. I don't mean to derail this groupbuy thread even though I admit I already did....sorry! :FACEPALM: :FACEPALM: :FACEPALM: Just one quick supplemental...
MRsDNF, a very helpful and friendly BLF member from Australia helped me to figure out what Cutter has on stock. In the first place there were some mistakes on Cutter's website but thanks to MRsDNF and Mark (Cutter) it has all been sorted. They seem to have the latest revisions of XP-E2 photo red (now called "deep red") with 660nm wavelength and XP-E2 far red with 730nm wavelength. I.a.w. the bin codes these seem to be top rank bins.
The order links are:
XP-E2 Far Red (730nm)
https://www.cutter.com.au/product/xpebfr-l1-0000-00901/
XP-E2 Photo/Deep Red (660nm)
https://www.cutter.com.au/product/xpebpr-l1-0000-00d01/
Maybe this could be a nice "add-on" for those who want to order the 3V XHP50.2 from Cutter?
I'd like to share some beamshots / whitewall-shots of modified Sofirn C8F lights. These were equipped with Samsung LH351D / LH351B emitters bought from Andrey ("AEDe"). Once again, Большое спасибо for these wonderful LEDs, Andrey! :BEER: All pictures were shot on iPhone 6S with manual settings. If you have any suggestions how to improve the beam quality comparison between those beamshots, I'd be glad to hear about it. My photography skills are very limited so far.
Distance to whitewall: 1m
Mode setting C8F: mode group 2, level 2 (700lm)
Aperture: f/2.2
Shutter speed: 1/125s
ISO: 100
White balance: automatic
Autofocus: automatic
LH351D 5000K 90CRI
LH351D 5000K 70CRI (W6 Flux Bin)
LH351D 4000K 90CRI
LH351B 3000K 90CRI
LH351B 2200K 80CRI
Cheers,
Thomas
Thanks Thomas for beamshots! Could you make one more with all of them simultaneously and in the same mode?
Yes, I think that should be feasible but it might take a couple of days until I get to it.
Nice pics! Those 5000K's look the worse to me as far as inconsistency. I got 3500k's in a few lights.
Do you feel these pics represent what you see?
As far as the rendition is concerned, yes - the pics reflect quite well what I saw with my own eyes. I agree that the LH351D 5000K 70CRI appears quite similar to the XP-L2 “fried egg” beam (yellow corona, blueish rim in the outer spill) but once you reach a distance of let’s say at least 3 meters you won’t recognize it anymore. From a farther distance both 5000K 70CRI and 90CRI looked the same on a white wall. It might has something to do with the SMO reflector in combination with the LH351D but I can’t tell for sure. I guess Djozz once tested the LH351D in a Convoy C8 with SMO and reported something similar.
Personally, I prefer the 4000K 90CRI most or - even better - a quad of 2x 4000K 70CRI / 2x 5000K 70CRI would be just perfect to gain a 4.500K beam profile with best efficiency (e.g. in an Emisar D4S or a P60 quad pill). Unfortunately, the 90CRI has less output than the 70CRI.
If you’re a fan of incandescent light, the LH351B 2.200K 80CRI is just fine. You get about 1,900 lumens on turbo with three of these emitters in the C8F 21700. Another benefit of the LH351B is its small die size, resulting in a more concentrated spot (= better throw).
I prefer the 4000K range myself, but the 3500K SST-20's are looking ok to me so far, and I've been using an EDC, SWM C20C, with triple XPL HI 2700K's with a nice incandescent feel that I like in this light. Few years back I recall comparing indoor looks at first a 3C/3D, then 4D, then 5D, and it just got better and better, but if I went to a 7A/7B level, it was too much, and my preferences are still there.
